Question about Sony 20x Dvd Rw +And -Dru-190a Burner
My drive can not read the cds please give me a suggestion i need to install some software now
    President:
  • 414 Answers
Do it only if u r a professional..
open it up, with the lens assembly there is a small preset, turn it using a screw driver a little anti-clockwise..clean the lens with clean cotton using isopropyl alcohol..
if not done, replace the lens assembly..
or else, replace the drive with a standby n see..
i gotta know: is ur drive pata/sata and the device make n model..
assuming that ur drive is pata, n u r a professional n aware of bios/cmos setup utility handling..!!
open up ur system cabinet and see if all the data cables n jumper settings at the back of the drives (master/slave selection)..itz most important..!!
however, at the bootup (0.29sec) start pressing briskly the key to enter cmos utility or bios setup (eg. F1/F2/F10/Del as applicable)..glance in the standard settings if r detected individually..change the 'Mode' if m/b is hybrid type(both SATA+PATA) : Native/Compatible/Enhanced (as applicable)..
see if ur device needs any additional driver or not, if so try downloading..
also try checking itz data cable for loose or faulty..
above all explanation is applicable only if itz not being detected by the m/b or system..(not for reading or writing problem)..
contact ur system admin/vendor....
Posted on Nov 19, 2009
    Sergeant:
    Champion:
  • 273 Answers
If the sony drive your talking about is the most common one. It usually comes with a black or white case that flips back or forth on installation to match your computer. Make sure you had it installed with the instructions? Did you also install the software cd that came with it?
  • 746 Answers
Hi, If your drive does not work anyone means any cd, you should chek your data cable or reinstall its driver and if it is old you should replace with new one.
Good Luck
Purchased and installed LG GH22 Super Multi DVD Rewriter. It reads/burns data CDs perfectly and burn/plays back music CDs. However, video files come out with choppy picture and badly distorted audio. Have...
get the dvd rewriter to record at its slowest speed.you do this through the software,which im not familiar with sorry.also usr quality media eg verbartim or tdk
Mar 27, 2011 | LG Electronics 16x DVD and 48x CD-ROM...
I have trouble loading CDs. There is a place to
Make sure you are placing the CDs in the drive with the label side up. If the computer can read DVDs, it can certainly read CDs as well. Once the cd is inserted, wait and the autoplay should start the installation program for the software.
Dec 01, 2009 | E-Machines eMachines T3830 PC Desktop
I have purchased a tsst ts-t633a external dvd +-RW drive to link with an acer aspire a0531 netbook. The drive will read and write CDs but not recognise DVDs. Can anyone help?
You need a software made for DVDs which you can use for the CDs to.
To read DVDs (and CDs) use Power DVD.
To burn DVDs (and CDs) use Nero DVD. You may purchase them almost to any PC shop.
This is just an example. You may find some free software on the Internet but if you are not used with this I suggest to ask a friend to help you or to buy a software as I have already said.
Oct 06, 2009 | Acer Aspire One PC Notebook
My cd drive will read cds but not dvds i try to istall somethig it wont work
Hi dkush29306,
while the other two posters have pointed out the obvious, that CDROM drives only read CDs, and that you need a DVD drive to read DVDs, i would like to add something to this.
I will asume you have a CDROM COMBO Drive, that *should* play CDRs and DVDs.
if you find it does spin CDs up and read them, but not DVDs then i might be able to offer some suggestions.
firstly, make sure there is no software conflicts (like two CD Writing softwares trying to use the CD Drive at the same time.. ). you shouldnt have to worry about drivers for the CDROM, as the default OS ones should suffice. but they may be corrupt. you could goto Device Manager if you are on Windows, and uninstall and reinstall the driver for the CDROM. it should find it automatically in the install wizard.
ok at this point i don't see how software could cause any other issue , so we should look at it being a hardware issue:
if you have the ability, try changing the IDE Ribbon Cable that connects the CDROM to the Motherboard. if that doesnt work, try changing which plug in the IDE cable the CDROM plugs into. these plugs usually have a blue plug at one end (motherboard end), and there is two plugs at the other end, or master and slave. keep the jumper pin on the CDROM set to Cable Select, so you dont need to change it to slave, when its plugged into the slave port, or master pin if set to the master port.
finally, if none of that helps (and it probably won't ) you might find that the actual fault is due to the laser in the CDROM not focusing tightly enough and therefore cannot read the data on a DVD ROM because of this. the only way to tell if this is ok or not, is to plug it into another computer and see if it can read DVDs.
you might just be better off spending 20-50$ and buying a new CDROM Combo drive from your local computer hardware store.
Jul 17, 2009 | Computers & Internet
No read any cds
Hi there, as per your information the device working well. But not read CDs. So i suggest you install a CD/DVD Reader or rewriter software.
Because, with out the software your DVD/CD device can't able to read CDs. You can use Nero Express software for solving your problem.
Thanks & waiting for your feedback.
Mar 18, 2009 | LG (GCE-8527B) CD-RW Burner
My laptop still cant read cds or dvds
Try going to the site for the manufacturer of the cd/dvd drive and download/ install the latest driver. Also look in devive manager to see if you have any conflicts (yellow ?)
Feb 11, 2009 | Toshiba Satellite A135-S2386 Notebook
HP Pavillion dv6121tx 15.4" notebook problem with DVD
Hi
It sounds like a hardware fault on the drive itself. The laser and focussing mechanisms are different for CDs and DVDs. The fact that the drive can read DVDs fine suggests that the laser and lenses can no longer focus correctly to deal with CDs.
Replacement of the drive would be the only fix, although you might find it a lot easier to buy an external USB DVD drive.
Dec 31, 2008 | HP Pavilion dv6000z Notebook
Will not read DVD-ROM
Computer DVD Support.
Good Luck, Please dont for get to Vote, Follow instructions.Thank you.
Dec 26, 2007 | Compaq Armada M700 Notebook
Not reading DVD
It's common problem with combo drives in notebooks, they don't seem to last long. Try this:- Go to my computer>properties>hardware>device manager and look down the list for your cd/dvd drives and click the '+' sign then highlight your dvd drive and right click to delete. Restart the pc and windows will find the drive again automatically and install the drivers. If the problem persists the laser is faulty in the drive and the drive will need to be replaced.
Mar 07, 2007 | Sony CRX830E CD-RW/DVD-ROM (Combo) Burner
Sony 20x Dvd Rw +And -Dru-190a Burner Logo
190 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
