Question about ASUS Intel 845 Chipset P4B (P4B WOA) Motherboard
My hardware monitor found an error how do i fix this.
    President:
  • 1,149 Answers
Hi:
Usually the hardware monitor is trying to tell you something, like a fan is failing or something is getting too hot. You need to open the hardware monitor page and see what the actual error is. On boot up, you either hit Delete key or F1 and then tab over to the hardware monitor page.
Posted on Nov 19, 2009
I got this error massage after i install the new AOC 19" Class Slim E970Sw monitor
Get the original disc / driver from the website.
If using windows 7. Let windows update the driver by going to device manager.
Make sure you video adapter drivers are also up to date.
Mar 25, 2014 | AOC Computers & Internet
How can I fix an "Out of Range" display?
Please reduce display resolution of computer/ laptop to solve "out of range" error because laptop is producing high resolution video signal and monitor hardware is unable to show that much higher display resolution so causing that error message.
Let me know what Windows version (XP, Vista, 7) is running in laptop to provide you more info or check Display Properties in control panel and change it to lower resolution to get picture in monitor.
Thanks.
Feb 09, 2011 | Westinghouse L1975NW Monitor
Out of range set monitor to 1024 x 768 @75mherz
Your monitor probably does not support this frequency. 60 Hz is most likely correct for a monitor of this size and resolution.
Oct 21, 2010 | HP Compaq 1501 15" LCD Monitor
I have a deel monitor E772p its no open power fixed the error and call me
is hardware problem, the power supply is malfuntion, needs to be checked by a tech.
Aug 08, 2010 | Dell E772p Monitor
Hardware monitor found an error enter power setup menu for detail
some error happen in your electrical pal, go to bios monitor the voltage or you can disable bios to monitoring voltage 5+ 12+
May 10, 2009 | ASUS Intel 845 Chipset P4B (P4B WOA)...
Diagnosis: Lack of P.S.U. fan speed report indicates P.S.U. fan sensor damaged by overheating. This was caused by cooling fin blockage since the Sony design on this model cools the C.P.U. THROUGH the P.S.U.
Expert level fix: Remove P.S.U. Remove C.P.U. fan and vacuum. Remove C.P.U. cooling fins from C.P.U. and cooling fan mounts from fin box, vacuum. Reassemble C.P.U cooling system. Replace P.S.U. with O.E.M. part only since in this case it is proprietary to the unit.
Jul 31, 2008 | Computers & Internet
Video hardware error
with another monitor uninstall anything related to your Sharp LCD, boot up a couple of times, then reinstalled as instructed.
Hope That Helps!
Dec 11, 2007 | Compaq Presario 5000 PC Desktop
ASUS Intel 845 Chipset P4B (P4B WOA) Motherboard Logo
466 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
