Question about Kenmore 24032\24036 Top Load Washer
Kenmore washer, model #110.27802690. Intermittent spinning (sometimes it works, other time it does not and sounds like it is just not ingaging). If I move the cycle selector to spin after it has completed its cycle it will spin every time. Please help. Thank you
    President:
  • 1,937 Answers
You have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.27802690
The Kenmore / Whirlpool top load uses a reversing motor to initiate the pump for draining and the transmission to spin.
If you cannot hear the motor trying to turn the pump, (but the washer will agitate) the problem points to the Timer, or the Lid Switch.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
Following is a description of how to release the console for access to the pins.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part.
If the problem isn't in the switch, and the Timer continues to move, the problem is likely in the transmission.
If the timer doesn't move, try a different cycle. If it works completely in a different cycle the problem is likely in the timer. Since you've already tilted the console back, you should have access to it.
If it still doesn't work, or only works when the timer is moved to the spin cycle (essentially turning the washer off and then on) OR If you lift the lid, put it down again and the washer begins to spin, the problem is likely in the transmission "Neutral Drain Assembly".
Those cams/gears etc. in that assembly keep the washer from spinning until all of the water is pumped out and then go into spin mode. Apparently, by opening and closing the lid, torque from the motor starting throws the cams into the right gears so that the washer will spin.
Ours had the same problem, no spin unless the lid was raised and lowered or we shut off and re-started the cycle.
After looking at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) we noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Found the part number for a kit (Whirlpool part number 388253 Neutral Assembly) for $15.00 and replaced the cams and gears.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators. The top agitator uses a plastic 1/2" drive bolt (a 1/2" socket extension works well).
You don't have to remove the drum.
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside,
remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission.
Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft, remove the 8 screws carefully the transmission holds 14 - 15Oz of oil, remove the clip holding the main spin gear on and check the plastic cams.
If the cam that should have a spring doesn't, or the others look damaged, the washer won't go into spin mode.
If that's the problem, install a Neutral drain kit, put everything back together carefully and the problem may be solved.
As an aside, fixing ours cost less than $30 including 80-90 weight gear oil vs. $170 for a new transmission.
Posted on Nov 19, 2009
I have a front loader washer Kenmore Elite Model #796.40311900 that spins SLOW, not FAST as it should on spin. The digital readout works normally.
sounds like maybe drain filter is plugged and unit is not draining fast enough. if you have drain access in front pull it out and clean it.
May 08, 2017 | Kenmore Washing Machines
Ref: 2008 Kenmore Elite Washer Model 110.28032700 Sub: Intermittent spin problems Machine gets stuck between wash and rinse ( confirmed no water in tub ) and sometimes between rinse and spin (
If this machine has a mechanical motorized dial (old style), then it might have worn contacts or a defective motor in the clock. If it's electronic, then it could be a computer related issue.
Dec 29, 2014 | Kenmore Washing Machines
Kenmore washer model #21302 lock on light is flashing, will not start
Kenmore top load washer 21302, the sensor light is on and the lid lock light is on with a clicking noise. What could be wrong with it and how do I fix it?
May 21, 2012 | Kenmore Washing Machines
Kenmore top loader automatic washer problem
First, see the Sears Parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.92272100&pathTaken=partSearch
Then see the Whirlpool / Kenmore Service manual for these washers.
WHIRLPOOL TRANSMISSION DESCRIPTION AND SPRINGS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2550f737b3129b0c85256b0600504738/$FILE/787772%20%234.pdf
It does sound like a Timer problem BUT, before replacing it I'd test it using the Service Manual procedures AND:
Often the problem can be an intermittent Lid Switch malfunction.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet.
May 01, 2010 | Kenmore Washing Machines
Some times the washer machine will spin and then
sounds like your clutch is slipping,,,,you can put a #10 washer in one of the clutch spring caps and that stops the slipping! thats a low on cash fix or just replace the clutch ,cost about 40 bucks!
Mar 30, 2010 | Kenmore 22422 Top Load Washer
Spins slowly in stackable washer dryer
sounds like your spin brake is not releasing when the spin starts
Jan 07, 2009 | Kenmore 98702 Stacked Washer/Dryer
Kenmore washer 90 series Washer will not spin
  • Check that the water supply valves are turned on
  • Inspect the filter screens
  • Test for overheating
  • Inspect the water pump
  • Test the water inlet valve.
  • Test the motor
Dec 11, 2008 | Kenmore 24032\24036 Top Load Washer
Intermittent spin cycle on Kenmore 90 Series washer
You may try the speed selection switch.....Ive had problems with these.
Jan 23, 2008 | Washing Machines
Kenmore 24032\24036 Top Load Washer Logo
677 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
