Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
When in the spin cycle it sounds like the ceramic drum is hitting the back of the washer, is it off balance?
    Scholar:
  • 60 Answers
Also try running it empty. If you have a single heavier item in the machine that gets worked to one side of the drum, it can swing it out of whack and cause the knocking noise. If you get the same issue when its empty, then its a mechanical issue with the machine and you need to adjust the balance of the drum or level the machine
Posted on Nov 19, 2009
    Sergeant:
  • 172 Answers
Make sure it is level and if thats correct then tilt the washer back and look up under it you will see springs and support arond the drum see if maybe on has come off or broke and that is causing the problem...
Why is my washing machine Miele w404 making thudding noises on spin Plse?
Unbalance load???
When in spinning cycle, does your drum start shaking violently and hitting the washer outer walls. Out of balance load.....
Is your machine on level floor. Does it have a play on legs while sitting doing nothing???
Happens for every load, then may be your washer shocks and/or top coil springs have come out or broken..
Or machine drum counter weights broken and drum going out of balance.
Apr 25, 2015 | Miele Washing Machines
Final high speed spin very noisey
Something is causing the drum to be way out of balance. Does it bang and make noise when it's spinning empty? Probably not. Is something stuck on the side (inside of course) of the drum, causing it to shake when spinning? If not, a spring or shock absorber (connecting drum to sides, bottom or top of machine) has broken or come loose.
Nov 23, 2013 | Malber WD1000 Front Load Washer/Dryer
Will Only Rinse/Spin with little to no clothes in drum
sounds like unit is activating out of balance lever thats y it works with no load in it .possible faulty suspension rods making bowl move too much.out of balance lever is at back of inside bowl to the right. try adjusting back feet to make them about half an inch higher than the front feet .that will move the bowl away from lever giving more tolerence. see how u go please reply 4 more help
Mar 26, 2010 | Fisher and Paykel GWL11 Top Load Washer
Model #fwtr647ghs- It washes fine bu there is a clunking sound that happens on spin cycle, like somthing is being hit
Hi I am Vortash the most likely cause of your impact sounds are the drum as it hits the side of the machine on spin .. this is a result of an uneven load and the fact that the suspension springs for the drum and support rubbers may be worn . The load evens itself out eventually and the banging stops I assume , as the centralfugal force evens the load and the drum spin becomes more balanced . Replacement or tightening of the springs is adviseable but it depend how old the machine is as to the economics of this .. regards Vortash
Jul 14, 2009 | Frigidaire ATF6000ES Front Load Washer
Maytag Performa Washer spins out of balance
There was a recall on the washer base, which caused the unbalanced problem. Find Technical Buletin TDL-0050B-B issued by Matag.
Jul 05, 2009 | Maytag Performa PAV2200
I have a frigidaire gallery front load washer need help
Run the machine on a cycle with no load in it (no soap powder either)
If it makes the same noise when there are no clothes in it then the suspension legs have given way or the counterweight has come loose.
You will need someone who knows what they are doing to repair it
May 23, 2009 | Frigidaire GLTF2940ES Front Load Washer
Loud noise(not jet whirring sound) during rinse & spin cycles.
the rear bearing is bad the bearing is press in to the outer tub the outer tube is like a **** shell you need the rear half and new seals it is a big job if you are going to do it you will need a manul
Dec 02, 2008 | Maytag Neptune MAH5500B Front Load Washer
Drum off balance
It's either a bad suspension spring or you have a crack in the tub support.
Jul 15, 2008 | Whirlpool LTE5243D Top Load Stacked...
Drum off balance
how do I tell if the drum is off balance or the bearings are out in the inner tub of this front load washer?
Jun 30, 2006 | Whirlpool GHW9150 Front Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
101 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
