Question about Nokia 1108 Cellular Phone
Screen is not working how to rectify - Nokia 1108 Cellular Phone
    Sergeant:
  • 297 Answers
Ur lcd is damaged get it replaced
Posted on Nov 19, 2009
Onida 21inch ultraslim screen small big problem
"Small Big" problem cannot be rectified. If it is extremely small, can be rectified. Very big too can be rectified. Contact any service technician; man!
Jun 13, 2015 | Televison & Video
Blank boot screen
It sounds like you have a faulty screen, if under warranty contact support for warranty, otherwise take to a local tech to see if the problem can be rectified.
Oct 05, 2013 | MSI Wind U100-030US Laptop
The touch screen has stopped working, all the buttons work and I can unlock the screen but the touch screen isn't working! Please help!!!
just you switch off your mobile for 1hour then switch on the problem if not severe will be rectified
Dec 02, 2010 | LG GD510 Cell Phone
Dir,sir my name is elsayed khatab working in power station my work depend on ups model ''400-cyberexwave'' but i have a problem when loading ups by select position bypass ,when i loading rectifier from...
I asked some clarification questions, but received no answer.
Because I see that your question is still standing, I will try to help you, but I am not sure, because I did not have your answers.
Your inverter I think is not CyberPower, but Thomas & Betts.
Your UPS has internal battery, which depends upon the type of the UPS.
If your battery is 270 V DC (which means 20 x 12 V batteries) 135 V will not be enough to charge them. But if you have 135 V DC (which means 10 x 12 V batteries) you can not give to them 270 V, because you can spoil them.
That's why you should measure the voltage on the batteries, not at the rectifier.
  1. If the batteries have the correct voltage for their number 135 for 10 batteries you can not adjust it to 270, you should adjust 135.
  2. If it is 270 for 20 batt's your rectifier did not get your order.
  3. If it is lower then the number of batteries multiplied by 11 V you may have a bad battery or completely discharged batteries and you need to charge them outside the UPS by other charger (One by one or in series) until their rated voltage is reached.
  4. Some of your internal breakers may not function well.
Jul 18, 2010 | CyberPower Dc/ac Inverter 400W
Hi iam is very critical situation my mobile is not working because this has align screen problem how to rectify this problem please give a help
what exactly is the problem..
the align screen message keeps showing up..
try hard reset?
or..
the screen is not in aligned properly?
start/setting/system/screen
Jul 11, 2009 | HTC P3300 Smartphone
I have 2 ViewSonic N2750w and and they both have black screens
i have repaired several n3750w viewsonics .. that may be similar to the 2750 .. in my case all the failures were caused by the same faulty part in the power supply .. the power supply has a 48 volt supply at about 7 amps .. the design uses a syncronous rectifier .. these are normally not used in supplies with that high a voltage out .. syncronous rectifiers make sense when the output voltage is low .. like 3 or 5 volts .. the parts are designed for that range .. but in this supply an IC is over stressed and fails frequently .. you might hear a chirping sound as the supply cycles thru an overload condition .. i modified the power supply to eliminate the syncronous rectifier and replaced it with a single shottky diode .. dissapation goes up slightly but reliability goes up a lot .. i have written an article on this. if anyone needs it i will try to find it . ..
Jun 05, 2009 | ViewSonic N2750w 27 in. HD-Ready LCD...
No picture
a bright thin line in centre is called horizontal line. first of all do not keep tv on unless it is rectified. BUT If you want to put on tv keep brightness minimum to protect your screen for any demage. now solution your problem is in vertical section. 1 check vertical supply. 2 check parts in vertical section or loose contact. 3 yoke connrctor loose 4 ic defective It is not serious problem can be rectified easily
Sep 19, 2007 | Toshiba 32DF46 32" TV
GE 35GT168
If you indeed have a line down the center of the screen that means the horizontal output transistor is working as it produces high voltage as well. The rectifiers are working otherwise you would have no power or sound. What you need to look at is either the horizontal windings of the deflection yoke are open or you have a open return from the yoke to the horitontal output stage.
May 06, 2007 | GE 35GT740 35" TV
Nokia 1108 Cellular Phone Logo
29 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
