Question about Kenmore Elite 21086
Kenmore Elite Calypso model 11022064100 making whinning sound when washing
  • 15,935 Answers
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 30, 2010
Both the coupler and the lid switch have been replaced yet unless you lift and close the lid it won't engage the spin cycle
Search Results
    Why am I getting an FL error code on a Kenmore Calypso ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kenmore Calypso washer model 11022062100 and there is water in ... Why am I getting an FL error code on a Kenmore Calypso washing Machine?
    fl error code on calypso washer-need help!! - Home Forumsths.gardenweb.com > Home Forums > Laundry RoomJul 22, 2006 - An FL error code keeps flashing on my Calypso Washing Machine. I can't do laundry. Could someone please tell me what I need to do to ..."F dl" light come on - Kenmore Elite HE3 Washing Machinehttps://www.ifixit.com/.../Why+is+the+%22F+dl%22+light+come+o...iFixitThese are the errors for error code F/dL Door Lock Error Condition A Door Lock Error... The Kenmore Elite HE3 is a washing machine by Kenmore. ... On Amazon I was able to get the CCU (Kenmore CCU Central Control Unit .... and a dose of WD40 on those contacts should keep that from misbehaving in the future as well.Kenmore Elite Calypso FL error code - ApplianceBlog
Jan 27, 2016 | Washing Machines
During spin cycle it makes a high pitch whining sound and sounds like a button is loose in the tub
does it have a burning smell? is it belt driven? rather than direct drive. belt are known to emit a whinning pitch sound at times. could be bearings going out. and sometimes a pc of metal opr material can get stuck between hub and shell and make weird sounds?
Nov 08, 2014 | Kenmore Elite Oasis 27052 Top Load Washer
WHINING NOISE FROM WASHER
What is the model number of your unit?
When does it make the noise? Spin cycle, wash cycle?
Dec 02, 2012 | Kenmore Washing Machines
My Kenmore Elite Calypso wont stop washing
Nov 22, 2012 | Washing Machines
My kenmore elite calypso washer is making a buzzing sound one minute into the wash cycle. It is about 9 years old. Should I fix it? How?
Sorry you had the bad luck to buy a calypso washer,probably the worst washer ever made! I also had the misfortune of owning this washer from hell. My washer had the same sounds as you described and in my case it was the water pump, which in this machine is separate. It wont be to long before you will have a total failure and then the fault light will come on.I am on my third pump and looking for a new one. Good luck on this one.
Dec 02, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Model # 110.22064101 Kenmore calypso elite washer makes a whirring sound when washing and the washer tub doesn't always stop correctly when the cycle is complete. It will move around instead of being...
The motor coupling is about to completly go out on you and then it will not spin at all. This is common on these machines. the repair should be under $100.00. The motor brake may also be dragging.
Nov 10, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore elite calypso doesn't respond to buttons except cancel
I've had a similiar problem on my calypso. In my case the key pad would go dead after washing or pushing stop after a few minutes. If I unpluged the unit for a few minutes it would work again. This would appear to be in the controller board. I removed the board and inspected it finding no problems. After re-installing the board the washer appears to be working again. My conclusion is that there is a loose connector/connection. I'd suggest you remove and re-install all the connectors on the controller board. This is the board closest to the power chord.
Good Luck, George S.
Sep 10, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Calypso kenmore elite water level low sometimes
something is clogging recirculating pump inspected both pump that should fix
Nov 30, 2008 | Kenmore Elite 45986 Front Load Washer
Calypso
If you have already removed the outer washplate, the inner wash plate should just lift off the leveler and u-joint. The washplate dome refers to the center cone that fits on top of the outer wash plate. This piece comes off by inserting a screwdriver in the slots along the sides and gently prying to release the locking tabs. The mounting bolts that secure the outer wash plate also secure the inner wash plate to the u-joint assembly. There is a seal under the inner wash plate that may be holding it on. I don't know of anything else that would be holding it in place. Searspartsdirect.com has an excellent exploded view diagram of the wash plate and components that you may refer to provide you with a perspective on how everything fits together. I hope you find some of this information helpful. Please post back and let me know if you are still having problems.
PS You may have to resort to using a rubber mallet to lightly tap on the inner wash plate to knock it free.
Sep 28, 2008 | Kenmore Elite 21086
Washing Machines Logo
97 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
