Question about E-Machines T6524 PC Desktop
MY T6524, will not start I press the button and the hard drive light goes red then nothing comes on the monitor
  • kfmatrix Nov 19, 2009
    The monitor works through my laptop, and the Cd/DVd light does flash.
  • Mariano Pedro Bernacki
    Mariano Pedro Bernacki May 11, 2010
    Is the monitor on? Bloq Num led blinks when BloqNum key pressed? Does the CD/DVD drive light blinks?
  • 3,153 Answers
Disconnect all devices from the power supply EXCEPT the motherboard
Remove any extra cards including video etc.(plug monitor into the onboard)
If you hear any beeps these can indictate where the fault is.
either of these sites below will help you further with that
Beep codes P
c
More beep codes
Power up the pc and see if the fans are working.
If not then double check the power connections to the board.
If you still have no fans it is time to suspect the power supply as the probable cause.
If the fans worked then you should have gotten a display which told you there was an error and offering you a chance to go into the BIOS. ignore it and shut down the PC.
Now connect one drive only and boot again.
Repeat that until you identify the component that is giving you a problem.
Once you find the problem then remove or disconnect and carry on with the rest to see if another component might also cause a problem
If there is only one problem device then you may want to investigate that device further, Unless you don't mind replacing it
Posted on Nov 19, 2009
  • Project NOMAD
    Project NOMAD Nov 19, 2009
    DVD light flashing could just mean that the power supply has those voltages present but maybe not the others that it needs for the whole system to work.
    E-Machines are very bad for power supply failures. I can swear to that first hand.
    Again all I can suggest is that you identify the faulty components by doing as I suggested make sure that ALL the fans are running both the power supply and the one on the CPU if not I would suspect a power supply fault.
    They supply multiple different voltages and if just one of those voltages fails then for the most part so does the whole system
Green power light comes on goes off then on again stays solid, moniter says no signal, mouse lights up, and three red lights on key board flash then nothing why?
If the monitor power light is on or flashing, but nothing displays, borrow a monitor from a friend. If that works, your monitor needs replaced.
Nov 21, 2012 | eMachines EL1852G-52W
The motherboard is a MSI MS-7184 in a emachine model t6524 and what is happening is when you turn on the computer, it starts and the lights on the keyboard light up and shut off, then it brings you to the...
Hello
Try f2,then let the screen come up.This is your bios settings,dont change anything.
Next hit the esc key,answer yes or y key.Pc should reboot normally.
If this doesnt work hit the f10 key and select your hdd or hard drive in the options,and reboot.
Apr 29, 2010 | eMachines T6524 PC Desktop
BSOD after power failure during check disk-now I cannot reboot from recovery console or disk. How can I uninstall the OS then reinstall OS from eMachines T6524?
You need to enter the BIOS. immediately upon starting the computer start tapping either the F2 or the tab button. Once in the bios, go to boot order and set the cd/dvd drive as the first boot priority, hard drive second. It is ok to leave this permanently, save and close settings which will reboot the system and considering everything goes as planned you should be able to start up from a disk and then repair or replace XP. When replacing XP remember to delete partition and write a new copy. THIS WILL ERASE ALL INFO ALREADY ON THE HARD DRIVE!!!
Feb 23, 2010 | E-Machines T6524 PC Desktop
What does the red light mean next to the power button?
The red light next to the power button is usuall the hard drive led which should blink every time the hard drive is in use, there is normally a green or yellow light for the power that shoukld stay on constant when the computer is on.
Feb 09, 2010 | Intel Compaq EVO D500 (RBMDTCPQP42400) PC...
PC won't go all the way on.
Make sure the monitor is properly plugged in. Make sure that if you have more than one video signal on your computer, that you have it plugged in to the right one. (A video card overrides normally an on-board video connector). Make sure your monitor has power and has a power light on. Does your PC beep as it comes on? If so, it is indicating a very basic problem with the machine.
Requires more input to fully resolve.
Jul 02, 2009 | Computers & Internet
I ahve an emachine T6524 and when you start it up the hard drive light comes on yellow and the cpu keeps beeping. It never seems to boot up. Nothing appears on the screen
hello...the exact problem on the CPU/unit is Memory so you need to try clean the memory or try to replace a new memory...Thanks and Good Luck...
May 09, 2009 | E-Machines T6524 PC Desktop
T6524 Desktop will not come on
That could actually be tons of different things.
The first thing you want to start with is make sure that the cable from the computer to the monitor is plugged in.
After that, you want to make sure that the monitor is good. Try using either a different computer with that monitor or a different monitor with that computer.
If that doesn't fix it, let me know and we'll go from there.
Dec 28, 2008 | E-Machines T6524 PC Desktop
E-Machines T6524 PC Desktop Logo
224 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
