Question about Acer Aspire 5100 Notebook
I am trying to connect my acer aspire 5100 laptop to my HD tv i have olso a vga cable when i connect it and go to tv menu and connect computer the tv screen show there are no signal can some one help me please?
  • 458 Answers
Try adjust computer viedo for 800x600 60 HZ output
use keyboard Fn key + F6 (use manual ) copy to tv.....
Posted on Nov 19, 2009
  • 3,153 Answers
Make sure you have used the FN + F5 button to switch your laptop to external display.
Also is you are using VGA to component lead be aware that many of these dont work
Can my acer laptop play on my t v
Yes, but you need a few things.
1. First you need a VGA adapter on your laptop (you should have one if you have a model made within the last several years)
2. Next you need to see if there is one on your TV
3. Last, you need a VGA cable to connect the two.
4. After they are connected, you can enter the setup menu or input menu of your tv and select the VGA option to see your computer on your TV.
Note that this method WILL NOT also provide sound through the TV, just pictures. On newer models of laptops, HD connections are provided, and you could use an HD cable to connect your TV to the laptop. In this instance, sound would be able to come through the TV.
Hope this helps!
Aug 25, 2011 | Computers & Internet
Connecting laptop to hd tv
IMake sure that you have the laptop for an VGA OUTPUT. When you toggle between the function keys. When your laptop LCD goes out it is in VGA OUT mode....when you toggle again it should be in LCD/VGA OUT (both TV and laptop should display). You need to set the TV to VGA mode as well...otherwise you might not get an output. If you still have a problem then test on a regular monitor to see if you are getting an output to the monitor
IF THIS HELPS PLEASE VOTE.....GOOD LUCK AND THANKS..
Nov 12, 2009 | Acer Aspire 1640Z Notebook
I have an acer aspire 5100 laptop i need to hook up to my tv for a presentation tomorrow. there is no s-video output on it,. how do I hook it up to my tv?
If your TV has RCA jacks on the back or front. Input type. Then you can go to radio shack and get a vga cable to RCA jack converter. That is all you can do. Is the TV a flat screen if yes then you can hook up you pc with a monitor cable like your usine now in your house. Find out the type of TV.. Ask someone to check the tv for a computer port on the back.
Oct 09, 2009 | Acer Aspire 5100 Notebook
I have an acer aspire 5100 and am trying to vue my screen through my tv. I have a vga lead connected to both but my fn F5 button doesn't seem to switch my screen from 1 to the other? can you help
you need do
1) set your TV interface to PC port
2) connect the cable (you are sure it is a good condition) between laptop and TV
3) power on laptop boot system and then hold Fn and click F5(screen change), maybe click 1 or 2 times if you see LCD black and then next to TV screen.
hope help you do it well
May 11, 2009 | Acer Aspire 5100 Notebook
Trying to get my Acer Aspire 7720 blu ray player to play on my lg LCD tv. player plays fine on the laptop but not the tv. Connecting thru a VGA able for video feed. Help please
Hi there
You will need a HDMI cable, that is of course if the laptop has HDMI out and that the TV supports HDMI.
This is the only way you will be able to experience the full Blue-ray HD experience through the LCD TV.
Good luck and thanks for using Fixya!!!!
Feb 19, 2009 | Acer Aspire 5100 Notebook
How to connect acer aspire mini laptop to digital lcd tv?
You get the audio from PC: you must use a separate audio cable to your TV audio input.
Configure your PC Display properties to a lower resolution until you reach a format your tv can display.
If you use a flat digital screen check the manual to know the resolution to be used with VGA input.
Use Dual screen option or swittch main screen/external/both using FN key + blue key showing screen on your keyboard. (F4 or F7? check manual.)
Jan 07, 2009 | Acer Aspire 5100 Notebook
Hot to connect acer aspire mini laptop to digital lcd tv?
Press the Blue function key and toggle the screens. You can view, the Laptop, the Laptop and Screen, or just the screen.
Also you will need to flick through the channel button on the TV to get to the PC interface. Since you indicated you were using a VGA cable, this is likely the missing element.
Note: The VGA cable does not carry audio, you either had a separate audio interface to the TV or you were using RBG/Composite/S-Video/HDMI. So check to make sure you are using the correct cables.
CONNECTING ACER TO THE TV
Please tell me what operating system you have installed and what the specs your machine are,
Can you also discribe to me how you have the computer connected to the tv thanks
This will help me understand your problem better thanks
Sep 06, 2008 | Acer Aspire 5100 Notebook
HOW TO CONNECT SAMSUNG LCD TV TO ACER ASPIRE
Atlast I got some help from the right people (Samsung)! I would like to share it with others facing the same problem:
If you are using the D-sub 15 pin jack (VGA Monitor Cable: make sure its 15 pin and NOT 14 pins), follow these steps:
  1. Make sure your TV and computer are off.
  2. Using a 15 pin D-sub (standard) video cable, connect the Video Out jack on your computer's video card to the PC In jack on the back of your TV.
  3. Using an audio cable with a min-stereo plug on one end and two RCA jacks on the other, connect the Audio Out jack on your computer to the left and right PC Audio In jacks on your TV. (Note: If you have your computer connected to separate speakers, you can skip this step)
  4. Switch on the Notebook and Adjust the Resolution (800 x 600 pixels would do). You can go to Control Panel and Adjust the screen resolution. (Keep ‘Screen Refresh rate’ at 60hz in the Monitor Settings)
  5. Switch on the TV and try to Select the Source as 'PC' (you can do this by either pressing the 'Source' button several times on your TV remote or go to the Menu - Setup and Select the 'PC' as source there).
  6. In most cases, after following the above steps, the TV would start to show 'Auto Adjusting' message and it will start showing your Desk top on the TV. But incase it doesn't work, you can do the following:
a. Mostly the problem lies with the VGA cable. Make sure you have the right one (15 pin) and its securely attached at both ends. If you are not using the right VGA Cable, it means that there is no connection between your TV and Notebook. Your TV will show 'PC' in Grey in the Source Input list (Go to ‘Menu’ from the TV remote).
b. Both your Notebook and TV should be switched off when you are connecting the cable otherwise one of them might have a problem detecting the other one.
c. Try Pressing Fn + F5, F6, F7 (depends on which Notebook brand you are using) on your Notebook several times. At times, you will see some signs that the Notebook and TV are trying to connect. Select 'CRT' from list of displays available to you.
May 09, 2008 | Televison & Video
Connecting computer to tv
This answer is pretty late but all u need is an HDMI cable to make the connection. You can also use a projector cable to make the same connection but plugged in a diferrent port at the back or your TV. If your computer doesn't have an HDMI port u can still use the VGA(projector cable) to make the connection
Feb 14, 2008 | Acer Aspire 5100 Notebook
Acer Aspire 5100 Notebook Logo
372 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
