Question about Maytag MDE308DAYW Electric Dryer
Dryer will not come on motor ohms out good replaced timer switch nothing happens
  • 87 Answers
SOURCE: Kenmore Dryer Timer does not advance
Timer resistance is way too low. You may have misswired the new timer. Basically, when the dryer motor is running, the timer motor gets voltage 115 volts.
Posted on Jun 13, 2007
exspert
  • 55 Answers
SOURCE: Dryer not turning on
ok " the timer has points that act like a switch , they get burt and will not work after a long time
replace time , it's just a plug in unit
Posted on Jan 21, 2008
  • 1122 Answers
SOURCE: WON'T COME ON AT ALL.
you have not said anuthing about ohming out the start knob,and have you checked both legs on the power cord are getting 120 volts each?let me know what you find-mike
Posted on Oct 02, 2008
SOURCE: replacing timer switch
maytag dryer/ will not stop runing
Posted on Jan 06, 2009
aasc
  • 1606 Answers
SOURCE: LER8648LW0 Dryer. Not heating, runs continuously
One side of the element powers from the timer and the other side from the motor . Remove one wire from the element , and check which wire is not getting 120 V . Trace the wire NOT getting 120V and it will lead either to the timer or the motor , providing that the small t-stat looking piece (thermal cut-off) located close to the top of the heater box , shows continuity . If it does not , then pt # 3392519 is for it and the hi-limit t-stat . If you replace it , then replace both that come in the kit .
Posted on Jul 19, 2009
When I try to set the timer and push the start button nothing happens. The trouble seems to be with the time st spinner
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
https://www.youtube.com/watch?v=sTRP6kHqAFs
Hey GOD IS GOOD !!!! WHICH IS WHY MY ADVICE IS FREE
What to Test When Whirlpool or Kenmore Dryer Won Start or Run
Dec 04, 2016 | Dryers
Roper electric dryer wont start
Feb 09, 2016 | Roper Dryers
Doesn't come on at all, new start button still nothing. how to bypass clock/timer mech just to start the dryer. fuses all test good.
Apr 28, 2015 | Dryers
Wont' come on at all, replaced start button with new unit, nothing still. was wondering how to bypass the timer control just to start the dryer.
Apr 28, 2015 | Maytag Dryers
Troubleshooting m460g timer
you should have power across the two wires to the timer while it is running . Power needs to be on the timer for it to work. One wire should be low ohms to the ground or metal surface and the other wire should be the power wire to the timer motor. if no power on the other wire to timer follow it back and you may find an open in a door switch or temp switch. good luck
Nov 04, 2013 | Maytag Dishwashers
Samsung dryer will not spin.
you must check the timer might not have contact in the terminal although it was starting to count. then you check if their is a voltage that is coming from the motor, and check weather the starting capacitor has resistance or worn out.
Aug 16, 2012 | Dryers
Push the start button and nothing happens - no noise nothing.
check both thermal fueses, door switch, power relay, timer contacts if good, replace motor, do you have 220 volts at plug
Jun 26, 2009 | Kenmore 62602 Electric Dryer
Kitchenaid superba dryer won't heat Where is the heater fuse located?
Q - My electric dryer runs but will not heat, what could stop my dryer from heating?
A - Things that could stop a electric dryer from heating:
- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug.
A ohm meter test for these parts is here.
Q - My gas dryer will not heat, what could stop my dryer from heating?
A - Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
Meter testing and usage tips.
1. Power supply-check power supply at terminal block where cord enters the dryer. Should read 240V. If you read 240V here, tested with a volt meter, unplug dryer and test components with ohm meter.
2. Thermostats-Cycle and safety thermostats-read them with an ohm meter. Should show continuity . How common thermostats work.
3.Timer-The timer has a set of contacts that pass voltage to the heaters. If you can not determine by wiring picture what they are, check across the two terminals with the largest wires on them. The heater wires are almost twice as large as the others. You should read continuity with timer in heat mode.
4. Thermal fuses-In recent years the makers of dryers are using thermal fuses to let you know something is wrong with your dryer. They are generally non resetting and have to be replaced. The thermal fuses are located on the heater element housing and should read continuity if read with an ohm meter. Most blown thermal fuses are the result of vent/air flow problems or a grounded heating element.
5. Selector Switches-Read the wiring picture and determine which switch is closed. You should read continuity across closed switches.
6. Safety Switch on Motor-There is a safety switch on motor to insure that heaters can not come on unless motor is running. It is normally open when the motor is idle/not running, and closes when motor runs. In order to check with an ohm meter, remove the two large wires on motor switch and make them electrically safe. Tape them. Plug the dryer in and start motor. Check continuity across the terminals on the motor switch you removed the heavy wires from. If it is ok you should read continuity. Remember that the smaller wires in a dryer carry the 120V and the large wires carry 240V. There is no voltage on these two terminals with wires removed. It is ok to test with ohm meter.
7. Heat elements-Test heater element with an ohm meter. You will read continuityacross a good element ( 8-12 ohms is an average element ).
But darn it, I don't have a Ohm Meter....
To check the thermal fuse  - You can bypass the thermal fuse (just connect the 2 wires together) for testing purposes only.To check the thermal cut-out  - You can bypass the thermal cut-out (just connect the 2 wires together) for testing purposes only.
To check the thermostats for continuity -  - You can bypass the thermostat (just connect the 2 wires together) for testing purposes only.
To check the Element: Try removing element and physically looking at the element wire for a break in the wire.
How to take apart information for GE style dryers
How to take apart information for Inglis - Whirlpool - Kenmore dryers
How to take apart information for Maytag dryers
How to take apart information for Frigidaire and White Westinghouse
How to take apart information for Admiral, Norge, Magic Chef and Crosley
Mar 30, 2009 | KitchenAid Dryers
Whirlpool dryer
Yes it can at times. It has been my experience. This thing may be falling apart on the inside. Just replace it before it gives you further problem. There is more heat and resistance there at the contacts. While you are replacing it, check the other things as well. It seems like you have a good eye for this anyway.
Feb 01, 2009 | Whirlpool LER5636P Electric Dryer
Sep 09, 2008 | Whirlpool LER4634J Electric Dryer
Maytag MDE308DAYW Electric Dryer Logo
26 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
