Question about Albatron KX18DS Pro Motherboard
Kx18ds pro cannot boot hardisk ata or sata, but can boot from any OS live cd
  • 235 Answers
What is the size of the hard drive that you used before you upgade to 160 gb, if you used a smaller size and the motherboard is working properly, then the motherboard doesnt support large hdd like 160, sometimes an update on the bios will be helpfull in order to support these large drive, hope these help
regards
michael
Posted on Nov 19, 2009
Hi,I've an external case (diamondmax 11 Model:6H500F0)--500GB SATA 3.0GB HDD. And I wanna to activate it,but I Dont have the Installation CD,plz I need your help URGENTLY. (I've an widows XP for my...
Maxtor DiamondMax 11 is a SATA Hardisk and you need SATA External Case. After adding the Harddisk, all you have to do is connect it to the system via the cable of the external case. There is no need for additional drivers/ CD as all the external harddisks are 'plug and play'and the Operating System detects them automatically.
Hope it helps! Good Luck!
CreativeTECH
Apr 09, 2011 | Maxtor DiamondMax 11 400GB 7200rpm 133MBps...
A770E3 MOTHERBOARD 4 GIG RAM SATA 1 TERABYTE HD SATA CD/DVD NETBIOS SEE EVERYTHING FINE. BOOT SEQUENCE FOR CD ROM 1ST PROBLEM. WONT BOOT ANY OS. XP PRO ORIGINAL DISK LINUX UBUNTU...
You can get a manual here:
http://www.biostar.com.tw/app/en/mb/content.php?S_ID=450
Did you set the boot sequense in your bios ??
First your CD or DVD drive
Second you harddrive.
Harddrive must be in sata 0.
CD or DVD must be in sata 1.
Or look in the manual how the settings should be.
Good luck.
Feb 27, 2011 | Biostar A770E3 AM3 AMD 770 ATX AMD...
I have a HP Asterope Motherboard The Sata HDD or the Sata CD/DVD cannot in not detected in the BIOS and the computer can not boot-up When I use a IDE drive on the Ide port, It works But I have a...
Reasons a sata device might not be recognized in BIOS:
(1)Serial ATA disabled, enter bios and enable SATA.
(2)Serial ATA cable defective
(3)Serial ATA drive defective
(4)Serial ATA cable defective
(5)Serial ATA device not plugged into power.
(6)Serial ATA power adapter defective.
Feb 26, 2011 | Computers & Internet
Hi i have a portege s100-s1133, i try to install new os but the hdd cant not detected, but if i tried to boot into windows the hdd are detected. and im tried to go to bios settings because i want to change...
1.FIRST YOU DO ONE THING IF YOU USING XP OS MEANS CHANGE THE SATA MODE TO IDE OTHER WISE CHANGE THE SATA MODE TO AICH.
2.IF BOOT WITH CD MEANS CHANGE BOOT PRIORITY CD/DVD ROM
2.IF YOU BOOT WITH HDD MEANS CHOOSE HDD.
BIOS OPTION----CONTINUOSLY PRESS F2 KEY.
Nov 17, 2010 | Toshiba Portege S100-S1133 Notebook
When I connect my SATA dvd drive my comp continuously restarts. Without it, it runs fine.
hello !
Thats wired is it so  ? ok  go to your computer  set up and  see what's the booting order .
If it starts with cd  rom first  reset to boot from hard disk first  ie its should be in this order
1, hard disk
2, cd rom
3 floppy disk
good luck
Sep 17, 2009 | Computers & Internet
Msi 848p neo v motherboard problems.
Once you reset the bios everything goes to manufactures default settings. You will need to make some changes within the bios. You'll need the help of the manual. See page 3-20.
If your operating system is loaded on to the ATA IDE drive make sure you set bios settings as follows:
Connect the ATA IDE to MB primary master IDE port.
Connect the ATA SATA drive to the MB's first SATA port.
ATA Configuration
Set as, [P-ATA+S-ATA]
S-ATA Keep [Enabled] Set to [Yes] This enables the SATA controller.
P-ATA Keep [Enabled] Set to [Yes] This enables the IDE controller.
On-chip IDE configuration, "ATA Configuration = [P-ATA+S-ATA]".
Next go to Boot menu. Make sure the ATA IDE drive is chosen as boot device three.
First boot device [Floppy] (If you have a floppy disk drive connected.)
Second boot device would be [DVD/CD-ROM] drive. This should be connected to the MB's secondary IDE port & the DVD/CD-ROM drives Master/Slave jumper, set to Master.
Third boot device [ATA IDE drive]
If your boot drive is the SATA drive than set: third boot device to the SATA drive.
(Hard disk drive with operating system loaded on it).
Save your changes & exit the bios.
Keep in mind all ATA SATA drives are seen as Master drives. SATA drives are seen by the SATA controller & in order by their connection to the SATA port number.
Save & exit the bios. The system will auto restart. Windows should start.
Jul 25, 2009 | MSI Computers & Internet
Os istallation problem
Hi Prashant
This will apply is you are using a SATA drive and are attempting to install Windows XP:
In the box your motherboard came in, there should be a 1.44Mb floppy disk (Also called a stiffy). This will have the driver for XP to be able to read your SATA controller. If you do not have this "stiffy", either contact the hardware manufacturer or check their website for a download.
When Windows XP setup starts, and you are greeted with the blue screen, press the "F6" button when prompted to do so - to make XP setup allow you to install a 3rd party driver SCSI or RAID controlled. This you have to do within a few seconds of setup starting, so make sure to look carefully. The message will appear in the bottom of the screen.
This applies for IDE / ATA HDD:
Ensure that the HDD is being properly picked up by the BIOS. If not, ensure that all connections are good. If they are, test with another, known good, HDD to check whether your HDD is not maybe at fault.
Jan 07, 2009 | Tyan Tiger K8WE (S2877ANRF) Dual Opteron/...
Formating hardisk with sata connection
1) Be sure that your motherboard support SATA - See Bios
2) Using the Win XP installation CD you can format the drive. If you cannot load windows during the installation hit F6 to charge the SATA drivers.
If your sata drive is working like a second disk, you can format it directly from windows.
Start>> Control Panel >> Admistrative tools >> Computer Management
Or using any partition tools...
Sep 23, 2008 | Seagate Computers & Internet
Added ide hd and can't boot from ata hd now!
Ah, ok. According to the manual, on page 1-23...here's what you need to do.
According to this page, you need to set onboard ide operate mode to "Enchanced Mode", and Enchanged mode support on to "Sata".
Sep 17, 2008 | ASUS P4P800S Motherboard
Albatron KX18DS Pro Motherboard Logo
100 people viewed this question
Top Albatron Computers & Internet Experts
Iqbal Husain
Iqbal Husain
Mark Gough
Are you an Albatron Computer and Internet Expert? Answer questions, earn points and help others
