Question about GE Profile GCG1580LSS 15" Built-In Trash Compactor with 1.4 cu. ft. Capacity, Hidden Controls & Remo...
Trash compactor problem
The door is open about 2" and the unit is totally dead. I can see thru the crack that it appears the ram is stopped and about 2" still into the trash can.
  • 1 more comment
  • Dcskyview Apr 23, 2008
    We have the same problem the door opens 2 " and the compactor is stuck in the bin and won't come back up. I am trying to find the manual but i fear it is broken
  • lparker May 02, 2008
    I have to same sort of problem. The door is stuck open about 1.5" & I have tried everything to get it to close. I have the GCG1580 model. Any suggestions? I don't see paying $70-$100 just to have someone come out to tell me it's broken & then charge me additional money to fix it.
    PLEASE HELP...
  • bizmail4us Jul 11, 2008
    Just the same problem. The compactor will pull out enough that I can see the worm(?) but not enough to do anything about it. The compactor was repaired about a year ago ($120 service call).
I have had this problem on my GE Monogram. The 'smasher' is near the bottom and does not move anymore, even though the motor is working.
What I did was to get a crowbar that would fit through the crack and hook the underneath side of the bottom plate. You also have to hold the switch so the motor runs with the door open and pull up on the plate until the drawer can be slide out. The trunnion nut (a plastic nut) was cracked. I replaced it 3 years ago, and it just cracked again. They now make it out of metal, so maybe it will last longer. Ordered it from appliancepartspros.com.
Posted on Apr 26, 2008
Pull out the compactor. Remove the back panel. You will be able to lift the ram by hand. Have someone open the draw slowly once you do this. Then lower the ram. What has occurred is that the trunnion nut that is on the steel worm drive is stripped. It happens. Order and Buy a new nut. Re-install.
Posted on May 03, 2009
Compactor wont shut off. is all the way up
Check the upper limit switch, you may only have an issue with the contact arm to sense the rams position. Look there first before buying anything. Good Luck
Jul 20, 2014 | KitchenAid P Series Trash Compactor -...
Tip
Trash Compactor Problems Why it Does Not Work
Trash compactors can be a very nice feature and addition to your kitchen. However they can also be very hard to work on if they go bad. There are 20 some brands of trash compactors available, but the KitchenAid trash compactor is one of the most common.
If your trash compactor does not work at all here are some things that you will need to check.
First off make sure that you are getting power to the unit. Many are plug into by code a GFCI wall socket. These outlets do a great job of protecting against shock, but do a terrible job of staying on, especially when used on a motor that pulls a high amount of current when starting. It is not uncommon for them to go bad and trip for no reason at all after a few years. If the outlet is tripped, try to reset it by pushing in hard on the reset button in the center of the outlet.
If you have power at the outlet, then you will need to check through the circuit in the compactor. This can include a door switch, micro switches that sense the position of the ram, and possibly a key switch. Make sure that there is nothing stuck behind the drawer that would keep it from going fully shut. Check the position of the ram to see if it has returned all the way up.
If your ram is stuck down or if it will not go down, check for broken drive gears, belt, of chain. Make sure also that the switches that sense the ram position have not move and come out of place.
Your trash compactor will also need to be clean periodically. Food spilling on the tracks or glides can cause the drawer to slide hard or even become stuck. Clean all the slides or glides, wheels tracks and such with warm damp cloth and the re oil everything with a household lubricant. With time and use the wheels and bearings may also need to be replaced to keep your trash compactor operating well.
on Feb 28, 2010 | Kitchen Appliances - Others
Ge compactor stops after just starting
the running cycle for this type of trash compactor is a max of about 30secs. The fuller the bag is the shorter the cycle. However, if this is not how yours is running try checking to see if there is any trash stuck between the ram and the basket. Or make sure that the foot peddle is still staying in the "up" position.
Feb 27, 2012 | GE Stainless Steel Built In Trash...
GE profile trash compactor makes loud noise and pulsates
sounds like you have a bad ram bushing on unit... you will have to pull out and watch operation ...there is also a differential switch that tells unit when to stop that sometimes gets worn and needs replaced... it generally is at the top or on the side of bin ....most likely it is one of the two items that has failed...
Jan 05, 2011 | GE Profile GCG1580LSS 15" Built-In Trash...
My ge profile 15" compactor stopped compacting. I
The "wheel" has a cracked center that you can not see unless you take the whole gear off.( I am assuming the "wheel" is off the motor and should be driving the chain that goes to the side gears ) There is a tension washer looking thing that holds it on and you can force it off with a flat screwdriver. Once off, I'm sure you'll see the center of the gear( hex shaped) is not engaging the hex gear shaft for being broken somewhere. An appliance repair store should have that part for less than $50. Sure beats the $85 the service people start with for just a service call.
Dec 11, 2010 | GE Profile GCG1580LSS 15" Built-In Trash...
Compactor ram stuck partially down & door open 2 inches. How do I get the ram to go back up & get the door closed?
We just had this same problem. Your problem is most likely abroken plastic gear found at underneeath the bottom of the compactor. Pull out the compactor and turn it upside down. Remove the bottom panel and that is where we found the broken gear. We were able to retract the ram and open the drawer by manually turning the drive chain using an ajustable wrench. Clockwise is compact, counter clockwise is retract.
Feb 03, 2010 | GE Profile GCG1580LSS 15" Built-In Trash...
GE Profile trash compactor is stuck
This has happened a couple times to me and the fix is fairly simple. The problem is the trash ram is pushing down on the edge of the metal of the trash compartment because the door is partially open. The solution is to back-up the ram the the door will close.
To back-up the ram, you will need to pull the compactor out from under your cabinets and unplug it. Turn the compactor on it's side to expose the bottom. There is a plate on the bottom that covers the motor gears. Remove the plate and turn the large gear counter-clockwise to back-up the ram screws (at least this is how it works on my model works). The gears are a little greasy so you may need to add some after messing with the gears.
Good luck.
Oct 21, 2008 | GE Profile GCG1580LSS 15" Built-In Trash...
Have a Viking trash compactor VUC181 that will not open. Appears latch is broke. How can I get it open?
I have had this same problem and found two causes. Latch was never the problem.
#1 - Ram not in full up position. To check remove top plate and attempt to run compactor - depressing microswitch when ram is at the top. If compactor will not run you can check the ram position by turning the primary screw drive with a ratchet wrench. When ram is at the top position attempt to open the compactor drawer. The stop microswitch seems to frequently bend out of alignment - check the microswitch positioning before resecuring top plate and adjust if necessary.
#2 - Can (or other debris) is wedged in between ram and drawer. Remove back cover and carefully inspect insides of the unit - use a flashlight. Pry out any debris that may impede the drawer from opening. Attempt to open the compactor drawer.
Good luck,
Jon B.
jbroccoli@aol.com
Oct 10, 2008 | Viking 24 in. Professional Series VUD141...
Had a similar problem with mine. I took it apart and found that the nut that is on the bottom end of the ram screw was loose. I tightened it and it fixed the problem. That was about a month ago. Now it is doing it again. I'm going to tighten it again this weekend and apply Loc-tite to the threads.
To get to the nut, you have to lay the compactor on its side and remove the plate from the bottom. You'll see a chain that goes around the motor sprocket and both ram screws. You need to tighten the nuts on the ram screws.
Hope this helps.
Steve
Nov 20, 2007 | KitchenAid 24 in. KUDS02FRSS Stainless...
GE Profile GCG1580LSS 15" Built-In Trash Compactor with 1.4 cu. ft. Capacity, Hidden Controls & Remo... Logo
834 people viewed this question
Top GE Kitchen Appliances - Others Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Sal De
Are you a GE Kitchen Appliances - Other Expert? Answer questions, earn points and help others
