Question about AudioBahn A2300HCT Car Audio Amplifier
POWER TERMINAL MELTED - AudioBahn A2300HCT Car Audio Amplifier
    Novelist:
  • 92 Answers
MOST TIMES THAT A POWER TERMINAL MELTS, YOU WILL FIND THAT THE POWER CONNECTION WAS LOOSE AND AT HIGH CURRENT LEVELS, IT WILL ARC AND HEAT UP ENOUGH TO CAUSE IT TO EITHER MELT THE HOUSING AND DISCOLOR THE METAL OR SOMETIMES GET SO HOT THAT THE SOLDER CONNECTING THE CONNECTOR TO THE PC BOARD WILL GET HOT ENOUGH TO MELT AND BURN FROM THERE. IF IT IS DAMAGED ENOUGH AND YOU CANNOT MAKE A NEW CONNECTION, YOU WILL HAVE TO HAVE IT SERVICED AND SIMPLY PAY GREAT ATTENTION TO THE TORQUE OF THE SCREWS TO INSURE THAT YOU HAVE A GOOD CONNECTION. AFTER IT IS TORQUED DOWN, YOU SHOULD BE ABLE TO PULL QUITE HARD ON THE WIRE WITHOUT DISLODGING IT FROM THE CONNECTOR. IF YOU DISLODGE IT FROM THE CONNECTOR WHEN PULLING QUITE HARD ON IT, THEN IT WAS NOT TIGHT ENOUGH. LET ME KNOW IF YOU NEED FURTHER ASSISTANCE....V
Posted on Jan 06, 2010
Why does the terminal block keep melting on my kenmore range left front burner.
Brother Jeff, this happens all the time because the connections are not perfect, causing arcing at the point around the connection. This arcing makes for excessive heat and melts the block. I replaced the connections on my Mothers stove top with crimped connectors and it lasted a lot longer. They didn't burn out any more, she just needs a new stove. So your best bet is to use crimp on connectors instead of the OEM block that's melting from a loos connection.
Dec 01, 2014 | Kenmore Kitchen Ranges
Yamaha r15 positive terminal and negative terminal have joined together ...and the power supply is stoped what is the fault
You have shorted out the battery and most likely melted the wiring. Check all wiring for signs of heat and replace, check all fuses and replace blown fuses. Recharge battery or replace, you are lucky it didn't go up in flames.
Oct 02, 2014 | Yamaha Motorcycles
Fan not working...my car is overheating
The fuses are located in the fuse box under the hood, but could be the fan motor too, check if you have power at the motor
Mar 28, 2013 | 2004 Pontiac Grand Prix
The terminal block that the power cord plugs into sparks
The part is called the terminal block and is part number 5304409888
It gets burned due to not being connected tight when the oven was installed or worked on last.
Replace the block and repair any burned wire ends. Make sure connections are tight and you will be good to go
May 07, 2010 | Frigidaire FEB27S5A Electric Single Oven
Terminal Block
terminal was loose started arcing like a welder causing heat to melt the block
Apr 09, 2010 | Ovens
1996 NISSAN ALTIMA, CAR DIED WILE DRIVING, BATTERY TERMINAL HALF MELTED, WONT JUMP START, EVER AFTER REPLACING TERMINAL
well if the battery was half melted off,, then it must have been sparking,,, witch meens the cars cpu took a lot of power surges,, my gess is its finaly packed up on you, get the cpu sorted out and it will go again
Nov 15, 2009 | 1996 Nissan Altima
Terminal connector to the door switch overheated & fuse blown
Just cleaning is not enought.The terminal is loose and that isusually the problem most of the time.Replace them with new ones and I think you be happy.
Mar 12, 2009 | Panasonic NN-P794SF Microwave Oven
1995 300 Diesel
replace battery ..melted anode will leak noxious gases and KILL you.....i am inclined to think that a bad or melted ground line is the culprit to the weird dash light situation look from battery terms to main ground strap and clean and tighten..also dash area ...(headlights have their own connections separate from other wiring systems in car)
Nov 10, 2008 | 1991 Mercedes-Benz 300 Diesel
AudioBahn A2300HCT Car Audio Amplifier Logo
119 people viewed this question
Top AudioBahn Car Audio & Video Experts
Colin Stickland
Colin Stickland
Jerry Naidoo
Robert Rankin
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
