That usually indicates that your power supply has gone bad. The clicking sound you hear is your power supply not getting enough current to turn on your screen. Could be a simple fix as a bad capacitor but not sure? If you can pin point that problem being your power supply, it is some times cheaper to just replace the power supply board but it depends how old your TV is and if the power supply unit is available.
Ur power board is dead,know how to solders?Check the power board for Capacitors puff up or burst open replaced these capacitors.Or buy refurbish power board on Shopjimmy.com,Ebay.com.
i believe if you remove the steering wheel upper and lower covers, there will be a button to push to allow the removal of the key..as for the no start, the battery light is on because of the alternator. Its faulty. the clicking sound could very well be the starter not having enough power reaching to turn it over again unless you put a power pack on it...try a brand new battery, test the alternator and removed the key..it is possible the the key not shutting off the way, is drawing power from the battery not allowing to start that way, causing what they call a "parasitic drain". charge battery, remove key. try that
tv wont turn on when i hit power it makes the clicking noise like it is going to turn on, but never does and the red timer light next to the power button just flashes. help! trinitron kv29f1u only clicks and blinks
