Question about HP Compaq Business d530 Small Form Factor PC Desktop
Compaq Presario SR1123WM w/blinking green light. Will not shut down or start up. Just froze this way.
The power went out while the pc was running. This happened once before, so I unplugged and left alone for about a month. When I pulled it out again to check on the light, low and behold, it had stopped. Restarted it and everything was perfect, until it happened again. I now use battery backups, but am still waiting for this pc to come back to life. Is there something I can do that will be faster than waiting for a month or two?
  • 2,427 Answers
Yep
you can flash the bios
open the side panel and locate a jumper called jcmos or jp1
its a pin jumper its currently set to 1 and 2. switch it to 2 and 3 wait ten seconds and switch it back to 1 and 2.. when it boots enter the bios and load optamised defaults then save and exit..
if you cant find the jumper , remove the memory and battery for 1 minute , replace and boot .. enter the bios and load optamised defaults save then exit...
IF the above fails then you have hardware failure.. reply here for further assistance
Posted on Jan 11, 2008
6ya staff
SOURCE:
Green light flashing but computer is dead. what to do?
The green light on the motherboard? Your Computer has a few miles on it. It may be the PSU needs replacing. Also replace the CMOS battery and reseat/replace the Memory Mods, if you haven't already. If you unplug and plug in does the computer try to start? Fans spin? LED's blink? Anything? If it starts and shuts down in a few seconds that would, most likely, be a Power Supply issue. Their is a chance, of course, that it's just done.
Mar 19, 2013 | HP Compaq Presario SR2150NX PC Desktop
After power outage compaq presario SR1123WM desktop wont turn on
cHECK THE ps IF GOOD CHECK THE mobo COMMN BECOME DEAD AFTER POWER SURGE.
Nov 06, 2011 | Computers & Internet
System was up an running then, Then shut down
It sounds to me like it overheated and something burnt out, but I could be wrong. The main pieces in a desktop computer are: power supply, motherboard, cpu, ram, and video card (which is on the motherboard for lower end systems.)
Each one will need to be properly tested to find out which part(s) is(/are) failing, and the failing part(s) will need to be replaced.
Apr 19, 2010 | HP Compaq Presario SR1110NX PC Desktop
Presario sr1130nx desktop, lost power, won't start up now
there is problem with u'r SMPS. repare it or change a new one
Nov 03, 2009 | HP Remanufactured Compaq Presario SR1130NX...
Turned off compaq presario desktop and now it wont turn back on. I used the start menu to shut down. Everytime I press the power button a light flashes over a symbol that looks like a lightbulb. Help
Try the following:
1. If connected to surge protector, make sure it's on. If it is, then...
2. Try plugging computer directly into wall and turn on...if no then...
3. Unplug and plug the power cord back in and then try to turn on...if nogo then...
4. If there's a switch on the back of your pc that has 120/240. Switch it back and forth back from 240 back to 120, turn on again...if no go then...
5. Unplug everything from the back of your pc except power cord, keyboard, mouse, and monitor. Try again. If it still doesn't turn on.. let me know. By chance, has any power outage occured or any change been done to pc since it was last turned on?
Dman
Jan 08, 2009 | HP Compaq Presario SR1123WM PC Desktop
Compaq Presario SR1123WM PC Desktop will not start up.
try starting it in safe mode, when click the power bottom press f8 repetitively then select safe mode. then restart it again.
Dec 03, 2008 | HP Compaq Presario SR1123WM PC Desktop
Compaq presario sr1115cl wont power up
dont u dare ever use 220 line on thes eon usa power u blow it ever time u turn it on at 220 v dont u dare do that not no reset switch erther u must now buy new power supllly ok
Oct 12, 2008 | Compaq Presario SR1120NX 2.66GHZ Tower w/...
Green light flashing after shutting down computer to relocate office.
if its by the power button the led just indicates power after u have removed its source and reconnected it........this is normal nothing to worry about.
Sep 13, 2008 | Compaq Presario 5000 PC Desktop
Open Questions:
See all HP Compaq Business d530 Small Form Factor PC Questions
HP Compaq Business d530 Small Form Factor PC Desktop Logo
525 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
