Question about Lexmark E332n Laser Printer
We use a Lexmark E332n laser printer at work. When someone attempts to print something, the printer jams with a problem with the paper feed coming out of the tray. It essentially folds up on itself and will jam sometimes 5-6 times on the same piece of paper. Nothing we have tried has helped. This is becoming a very big inconvenience. Any suggestions?
  • 320 Answers
Try cleaning the feed wheels with a arisole electronic contact cleaner these get a glue composite build up on them and contact cleaner will remove it with out leaving behind any residue and make sure that the paper guides in the tray are not set against the paper to tightly. i have also seen these pick wheels (the rubber tire) be so loose on the shaft that they slip causing this problem.
Posted on Nov 22, 2009
My envelopes will not print -
Did you remember to specify envelopes in the printer properties dialog box? Click the button that says Preferences. Then click the Paper/Finishing tab. Under Paper Size, select your envelope size.
The printer will not feed the envelopes correctly without specifying this. The Lexmark printers adjust feed tension based on paper size settings.
Oct 15, 2014 | Lexmark E260dn Laser Printer
Paper feeds about half way and then stops. All of the indicator lights come on.
If you get a paper jam, the Paper Jam indicator light promptsyou to clear the paper path. If the paper has just started to feed from thepaper feeder when the jam occurs, pull the paper straight up out of the paper feeder. Open and close the printer cover toresume printing. If the paper jam occurs inside the printer, remove the paper from the output bin. Turn the printeroff, then on. If this doesn't clear the jam, open the printer cover.Remove the print cartridge and cover it.For additional assistance, please contactLexmark Technical Support
Apr 11, 2011 | Lexmark Optra E312L Laser Printer
My Lexmark E332n (b/w laser) has worked perfectly for 3 or 4 months, then started jamming, creating a concertina effect on paper stuck between the output rollers. The upper of these is the heated roller...
Hi there maximum time we found it is a the head problem. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage. Now Remove the ink cartridges from the print head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head. Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now
If that does not work then follow the next step.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
Dec 22, 2010 | Lexmark E332n Laser Printer
Lexmark E332n- Changed toner cartridge and now off alignment How do you cartridge align
It is fairly common in this model for the paper size guides in the paper tray to shift outwards, allowing the paper to skew feed as it is being fed into the printer,
Pull out your paper tray, and make sure the adjustable paper guides on the left and right sides of the tray fit up snugly to the paper in the tray.
try this, good luck.
Dec 16, 2009 | Lexmark E332n Laser Printer
Lexmark E332n won't pick up paper from tray
There are rollers inside which you can replace and they NEED to be replaced after a certain time. Part number looks like 56P1820 but i would contact the Lexmark technical support to be sure of the part number and how to order them. It's easy to install, usually it's just clips to pull it out, and you put the new one there.
Jun 10, 2009 | Lexmark E332n Laser Printer
Paper jams . changed cartrage still jams
Hello, I called a tech friend. He says it is VERY likly it ids the printer fuser that is preventing printed material to complete path.
I have exchanged said printer with a exchange service. I will followup with you for resolve of fuser .
gcoll3
May 11, 2009 | Lexmark E332n Laser Printer
Lexmark T640 won't print on label sheet a SECOND time...
try changing feed rollers. For a quick fix, remove the rubber rollers and flip them inside out. It should work
Jan 28, 2009 | Lexmark T640 Laser Printer
Lexmark E332n printer only prints half way but test page prints fully
Click on Printers & Faxes, right clisk on your printer then Properties, then Device Settings. Check the paper sizes in Form to Tray Assignment (I use A4, think USA uses letter, you Yanks do strange things)
Also check Installed Options - Printer memory (make sure it matched the installed RAM).
Make sure you have installed the correct printer driver for the version of Windows operating system.
Dec 02, 2008 | Lexmark E332n Laser Printer
Allignment
One possible cause could be -
The Form Size setting in the
printer driver is different than the
size paper that is loaded in the
tray. For example, you inserted A4
size paper into the selected tray
but did not set the Form Size to
A4.
Sep 01, 2008 | Lexmark E332n Laser Printer
My printer jams frequently
More info is needed where does it jam ie. going to print from paper tray or coming out of the fuser in back before it comes out on top?
Feb 26, 2008 | Lexmark E330 Laser Printer
Lexmark E332n Laser Printer Logo
251 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
