Question about Kodak EasyShare C533 Digital Camera
I have a samsung s1070 and i just brought a 4gb SD card and the camera won't accept it.It keeps upcoming as card error?any ideas
  • loveland88 May 11, 2010
    I've heard that there is a difference between the formatting of the 2GB and smaller, and the 4GB and larger SD memories. My wife's Panasonic accepts up to 8GB without any problems. Hers is 2 years old and yours is only 1 year old ?? I recommend trying a different brand of SD 4GB, trying to reformat the memory, or contacting Samsung Support on the internet about the problem. Sorry , that's best I can do.
    Genius:
  • Kodak Master
  • 1,099 Answers
S1070 SD card support:
SD Card (up to 2GB guaranteed) MMC plus (up to 1GB guaranteed) SDHC (up to 8GB guaranteed)
So if your SD card is a 4G MMC you will have to downgrade to 1 or 2G.
Good Luck
Posted on Nov 20, 2009
How do I get my camera to accept my sd card? It will go in, but my camera will say card error, and won't do anything.
You don't say what exact type your camera is, but the most likely problem is that your camera is only compatible with SD cards, not SDHC cards. You bought a larger card for your older camera, not noticing that it was SDHC (or not knowing that it mattered). The new card doesn't work, not because it or the camera is broken, but because it's not compatible.
Cards up to 2Gb are generally SD.
Cards of 4Gb are generally SDHC.
Cards over 8Gb have to be SDHC.
(There are exceptions. Sometimes, manufacturers make 4Gb SDHC cards but some have errors; they disable half of the chip and sell it as 2Gb, but it's still SDHC. 4Gb cards are almost always SDHC because they're cheaper, but 4Gb SD cards do exist. They are so rare that I've even seen a guru on this site claim they don't. I did own one once, but it was very expensive and turned out to be so unreliable that I had to return it. I don't recommend looking for one, because of the problems.)
Your solution is to go find a 2Gb card, and be extra sure that it doesn't say "SDHC" on it.
Mar 06, 2011 | Samsung Cameras
I bought an 4gig SD (HC)? card for my Camera. On start up, the Camera reads "FORMAT SET:OK" but when I select OK it Says CARD ERROR!. I've traded the "defective" one in for a...
The A402 works with MMC and SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible. You need to use cards 2GB and smaller.
Jan 15, 2011 | Samsung Digimax A402 Digital Camera
I can't get the camera to accept a sd memory card. It keeps saying check sd card, but it's brand new. Why is this?
Are you using a 4GB or higher "SDHC" card with your camera? Note that the S800 can only use "standard" SD cards (those 2GB or less). Fortunately, these are very inexpensive these days, recommend checking on Amazon.
For those that encounter this problem, there are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. Other causes include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Jan 05, 2011 | Samsung Digimax S800 Digital Camera
My Kodak P850 do not accept SD cards 4 or 8GB, error message state that memory must be replaced. No way to format the SD in camera. How can I do that camera accept the SD card
Technically speaking, SD cards only go up to 2GB. (Actually, some very rare 4GB SD cards exist, but I doubt you have one of those.) Cards 4GB and up are SDHC (Secure Digital High Capacity) cards. Your camera was designed before the SDHC specs, and thus is not compatible with SDHC cards. This is not something that can be changed in firmware, since there is a hardware compatibility issue.
SDHC devices will accept SD cards, but the opposite does not hold true. SD devices will not accept SDHC cards.
Jan 18, 2010 | Kodak EasyShare P850 Digital Camera
Inserting either a 4Gb or 8Gb SD card results in a "Memory Card Error".
The S4 accepts SD and MMC cards. SD cards max out at 2Gb. The 4Gb and 8Gb cards are actually SDHC (Secure Digital High Capacity) cards, not SD cards, and thus will not work in devices designed for SD cards. Compatibility goes only one way--SD cards will work in SDHC devices but not the other way around.
Dec 27, 2009 | Pentax Optio S4 Digital Camera
Camera will not accept any memory card over 2GB. Keeps saying "Memory Card Error"
Most new 4GB and larger cards are SDHC cards (look on the card). Although they look exactly the same as a standard SD card, they are not. Unfortunately, there is no way that these cards will work with your camera, as it was designed before the SDHC format came out. As you've dsicovered, 2GB and less are standard SD cards, and will work with your camera.
There were a few standard 4GB cards produced a few years ago, most notably by ADATA (I have one that I use in my A620). Unfortunately, these are rare now, and are somewhat expensive if found on eBay.
Oct 11, 2009 | Canon PowerShot A620 Digital Camera
Cannot install 4GB card into TL220. Do I have the
According to Samsung's page on this camera, the following memory can be used:
External Memory(Optional) : Micro SD (up to 4GB)
Micro SDHC (up to 8GB)
4 GB is acceptable, but I think you do not have the correct type of card. You should be using a Micro SD or "Micro Secure Digital" (up to 4GB capacity) or a Micro SDHC or "Micro Secure Digital High Capacity" (up to 8 GB capacity) card. This is very different from an SD or SDHC card. These Micro cards are very small (smaller than your thumbnail) and are often packaged with an SD adapter card. Regardless if sold with or with out the adapter, the package should say Micro SD or Micro SDHC on it somewhere.
Oct 02, 2009 | Samsung Cameras
Samsung 4010 camera wont accept a 4g sd card
The camera will only accept true SD cards i.e. up to 2Gb. Your 4Gb card will be an SDHC which is not compatible. See here http://en.wikipedia.org/wiki/Sd_card#Compatibility_issues_with_2_GB_and_larger_cards for further explanation.
Feb 03, 2009 | Samsung Digimax 4010 Digital Camera
Kodak EasyShare C533 Digital Camera Logo
98 people viewed this question
Top Kodak Cameras Experts
Tony
Jerry Greenberg
Jerry Greenberg
Are you a Kodak Camera Expert? Answer questions, earn points and help others
