Question about Viking Ovens
The light on my VIKING model DEDO 201SS oven wnet
The light on my VIKING model DEDO 201SS electric oven control panel went out. How do I replace it? Is there a bulb behind the cover that I can replace?
Thanks, Roger
Rotu
  • 175 Answers
SOURCE: Oven light flickers on and off rapidly
I have seen several problems with the touch pad (membrane switch assembly) causing weird problems with the lights. also something to check is the door hinges. I have seeen several cases where the door hinges wear out and the door does not close completely and doesnt quite push the door switch in. The easiest way to check this possibility is to push in on the door while the light is acting up and see if it quits. If it doesn't, the problem most likely lies in the mebrane switch (touch pad). Good Luck!
Posted on Oct 07, 2006
  • 161 Answers
SOURCE: Viking electric range
There is another fuse or circuit breaker inside the range. House fuse is at least 50 amps which would be way too large for 110 volt things. Your instructions will tell you where it is. Frigidaire used to hide it under one of the burners. I don't know where it is on a Viking.
Posted on Jun 29, 2008
SOURCE: thermador oven control panel light is not working
Please see post by bonanzsapilot on 14 March 2009; he gives exact & easy to follow directions for making this repair for <$10. It's listed uner 'Thermador SC301IT oven - FixYa'. In a separate post I added the correct capacitor numbers from Newark.com. I made the fix in abt 30 min & it's good as new. Thermador no longer makes control panels for this oven & no wiring diagram is available to help. Shop price was estimated at $500.
Posted on Apr 13, 2009
  • 4 Answers
SOURCE: Can't remove the oven light cover to change the bulb
clean it with wd40
Posted on Jun 30, 2009
SOURCE: how to remove the control panel on Whirlpool double oven Model RBD305PDS14
Emge & Associates is investigating gas and electric ovens manufactured by Whirlpool, including such popular brands as Whirlpool, Jenn-Air, KitchenAid and Maytag.
The firm is investigating reports that the electronic control panel on certain models is subject to failure after a limited number of uses of the appliance’s “self-cleaning” setting. While most foods are cooked at temperatures reaching 375 degrees, the “self-cleaning” setting raises the interior oven temperature to 1,400 degrees. Due to defects in the design and or manufacturing, the electronics contained on many ranges are damaged by extremely high heat. Repairs to damaged control panels typically cost in excess of $300 per replacement.
If you have experienced failure of the control panel in your range after using the “self-cleaning” setting, you can join this investigation by contacting Emge & Associates at (800) 629-3409 or (619) 618-2974.
Posted on Dec 19, 2009
No power on double oven after a storm
I have a RBD275PRS00 built in double oven. Had an electric
www.fixya.com/support/t8971528-rbd275prs00_built
Apr 16, 2011 - Had an electric storm the other night and ever since the oven won't -Whirlpool ... Question about Whirlpool RBD275PR Electric Double Oven ... For an oven to require parts after 2.5 yrs of service and 2 self cleanings tells me ... fiest press the on key see if the display comes if not the turn the power off for 5-8 ...
Whirlpool panel buzzing Ovens Questions & Answers - Fixya
www.fixya.com > Forum > Tags > panel buzzing > Ovens
Whirlpool ovens panel buzzing related questions and answers. ... the control panel on my Whirlpool electric double oven Model is RBD305PDS14? ... No power on control panel During self clean cycle the power to the panel went out. ... panel the instrument panel on an oven won't change time because of a storm problem.
Jan 01, 2016 | Whirlpool RBD275PR Electric Double Oven
Viking double oven control panel labels rubbed off
The control panel face can be ordered from Viking Range unless the unit is very old, then I would suggest partstown.com, You will need the model and serial number from the rating plate on the unit. These parts are usually not very expensive and are really easy to replace.
Hope this helps....GOD BLESS...Randy...
Feb 02, 2012 | Viking Designer DEDO130 Dual Double Oven
I have a Viking double wall oven model DEDO130. I have terrible baking results in the upper and lower. Mostly burning the tops (pizza, biscuits, etc) while the centers aren't done. A tech from the...
Home > Cooking Parts > Wall Oven Parts > Control Panel Area > Oven Thermostats >
G50012998 DESO SERIES T/STAT KIT Viking Electronic Part. ALL SALES ARE FINAL.
Viking Thermostat Replacement Kit
btn_emailafriend.gif pbox_border_left_top.gif clear1x1.gif pbox_border_right_top.gif clear1x1.gif G50012998 DESO SERIES T/STAT KIT Viking
List Price: $189.14
Our Price: $133.83
You save $55.31!
Return Policy Electronic Part. ALL SALES ARE FINAL.
Availability:: Usually Ships in 1 to 2 Business Days Subject to Stock Availability - Call to be sure.
Product Code: G50012998
The part is not that hard to replace. but it is expensive. In my opinion it should correct your problem since you have that much difference.
clear1x1.gif pbox_border_left_bottom.gif clear1x1.gif pbox_border_right_bottom.gif
Jun 08, 2011 | Ovens
My control panel went dim at first and eventually wnet completely out. Oven still works and so does oven light. Whirlpool suggested thermal fuse or control panel problem. Any thoughts?
I would replace the control panel...
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy
Appliance Parts Online
heatman101
Jan 19, 2011 | Whirlpool RBD275PD Electric Double Oven
The control panel went dark. Can only read it
Not sure on the make but it appears that the timer clock display is failing. Replacement cost is typically £80 but without the make i cannot give you a accurate costing. Fitting would be extra.
Regards
Aardvark Repairs
Nov 16, 2009 | GE Profile JTP56 Electric Double Oven
Wehre is model number located on viking oven?
It is usually on the stove at the bottom of the oven door. you might have to remove it to read it properly
Sep 18, 2009 | Viking Ovens
Whirlpool electric oven problem
thermal fuse to board blows, relays turn fans off, the thermal cut out on rear of oven kills element. change both fuses, install new style oversized blower.
Sep 22, 2008 | Ovens
Viking oven won't turn on
I had same problem (twice) with my Viking dual fuel range. In my case a relay that supplies power to the oven heating elements failed. The convection fan would run. The elements were warm to the touch. If you have a free standing range, it may be that relay (part number PM010026) which is located in the front of the stove. Remove a long narrow stainless steel panel (1 screw each side) located under where the door hinges. You can hear the relay click when you turn up the oven thermostat. That will help you locate the relay.
Note: Viking does not sell parts. You have to find their parts distributor for your part of the country.
Sep 20, 2007 | Viking DEDO205 Stainless Steel Electric...
Ovens Logo
75 people viewed this question
Top Viking Ovens Experts
Dan Webster
Dan Webster
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Viking Oven Expert? Answer questions, earn points and help others
