Question about Facebook Social Network
My guy wont move and it wont let me pick crops
My guy wont move and it wont let me pick any of my crops i dont know what do to
    President:
  • 414 Answers
I guess ur using a licensed and updated antivirus (i prefer avg/kaspersky)..!!
this is a common problem now days, probably itz caused by a virus/trojan..
download microsoft kb890830, install n run
also possibilities of:
u may not hv java runtime/adobe flash player/shockwave player installed..
the windows firewall is limiting the site..
may b ur antivirus is doing so..
some spyware/trojan horse may b playing foul..
sometime it also depends upon the browser u r using..
may b it is black-listed or restricted by using 'content advisor' (in case of internet explorer) in ur computer by some user or the above..
may b it is being filtered by the 'phishing filter'..
there may b possibilities that the site may contain 'active content'..
contact ur system admin/vendor for more details..
Posted on Nov 19, 2009
While attempting to select a wallpaper from my gallery i accidentally selected the always crop option that appeared and now i'm forced to crop my wallpapers and i dont know how to remove that
You didn't say what phone is or Os platform! Supposing that is most popular and most used - Android this might help . The apps listed below put aside the cropping factor and let you set full-size backgrounds without cropping
1.Image 2 wallpaper
2.Simple image wallpaper
3.Wallpaper wizardrii
4.Wallpapyrus pro
:D
Sep 10, 2014 | Cell Phones
Just had transmission replaced in my 2000 chevy blazer replaced..now when i went to pick it up the guy tells me transmission is good but i can not get the shifter to move into gear..we can crawl under...
It sounds like this guy who installed your transmission dinn;t adjust the shift cable correctly or damaged a part that bolts to the drivers side of the transmission called the interlock switch Don;t get me wrong its not an easy job to replace the transmission in your vehicle But paid a lot and it should work I seggest you call the shop and explain you can;t shift the vehicle I have a feeling that its the interlock switch its hooked drectly to the shifting mecanisum its not easy to remove with out damageing and should have been replaced with transmission job its a 20 dollar part it could still be the cable adjustment but at any rate its sure not your fault
Nov 07, 2010 | 2000 Chevrolet Blazer
My HP Photosmart 2575 All-In-One InkJet Printer wont take paper and i dont even see the rollers moving inside. I dont know how to take it completely apart to get a good look inside but i dont see any...
Turn off the Printer
open the Rear Access door
Clean the Rollers with Lint Free cloth ( Upwards just like the paper is picked and rolled )
Close the Rear Access Door
Stack the Paper Tray properly and place the papers in the tray ( Scuffle the papers before placing )
Power on the printer and it should pick the paper
Jun 23, 2010 | HP Photosmart 2575 All-In-One InkJet...
1999 gmc jimmy. The heater control is stuck on HOT.
if the knob wont move replace it junk yard may have used part but if it moves and hot air keeps blowing out u may need a servo that opens and closes heater box door under dash i dont think that trucks system works off vacuum but if it does it probably electronic related problem inquire junk/salvage yard about knob and servo for heater box door and problem it may be common and u may get info if he,s a nice guy
Mar 28, 2009 | 1999 GMC Jimmy
Dodge ram p/u overdrive issue
Grinds as in slowly creeps? or grinds as in metal noise?
Not shifting into overdrive,could be the kick down bands need adjusted.Or the kick down cable.
The cable is on the Throttle body side and should be lined up perfectly with the lug it goes on. Make sure you are not pulling on the cable or you will get a false indication of where it is. It has to be lined up with in a 32nd of an inch.. This is the baseline of where it would be in stock form. If you have it set like this and it wont shift until you let of it a little bit, then you need to loosen the cable a little bit. If you loosen it too much, you will have other problems..such as shifting too soon/late. It takes a while to get it how you want it. Start with making bold adjustments, you wont hurt anything, and see what it does. After you have a grasp as to what it doesn when you move the cable in either direction, make smaller adjustments..
You dont need a "tranny guy" to do this for you. If you dont know how to adjust the cable let me know and I or someone else on here will let you know how to do it, its.
Please rate this a fixya with the blue button
Feb 09, 2009 | 2001 Dodge Ram 1500 Truck 2WD
Indesign Crop Mark and nudge
To crop or straighten images in Camera Raw
In the Camera Raw dialog box, select the Crop tool or Straighten tool .
(Optional) If you want the crop area constrained to specific proportions, click the Crop tool icon and choose a proportion from the pop‑up menu. Choosing Custom opens the Custom Crop dialog box, where you can specify the proportions or the dimensions of the crop. Click OK.
Do one of the following:
To crop the image, drag the Crop tool over the image.
To straighten the image, drag the Straighten tool in the preview image to establish what’s horizontal or vertical.
(Optional) To adjust the crop area, do one of the following:
To scale or rotate the crop area, drag just outside the bounding box handles.
To move the crop area, click in the bounding box and drag.
If you selected several images in the Camera Raw dialog box, they are all cropped to the same size, with the crop applied in the same position.
Note: To cancel the crop operation, press Esc with the Crop tool selected or click the Crop tool and choose Clear Crop from the pop‑up menu. To cancel the crop and close the Camera Raw dialog box without processing the camera raw image file, click the Cancel button or deselect the Crop tool and press Esc.
Click Open, Done, or Save to apply the crop and process the camera raw image file.
Oct 20, 2007 | Adobe InDesign CS2 for PC
Developed photo's aren't turning out well
I think it's the photo service. Check and see if there's a cropping option. I use shutterfly.com and if the top of a head is cut off in the preview, I just pick the crop option and change it. The service tries to crop the pictures accurately but sometimes you have to go in and force it to crop the way you want to. I'm sure Walgreens and Walmart's services will both have similar features.
Nov 13, 2006 | Canon PowerShot S2 IS Digital Camera
Facebook Social Network Logo
57 people viewed this question
Top Facebook Computers & Internet Experts
David Payne
David Payne
Are you a Facebook Computer and Internet Expert? Answer questions, earn points and help others
