Question about Video Game Consoles & Games
My xbox 360 was pre owned and it has been registerd on xbox live by the first owner. how do i register it in my name?
Simply create a new profile (might be called "gamertag"), sign in with your new profile and delete the old owner's profile.
Posted on Nov 21, 2009
The game will not download to my xbox360 from xbox live
You must ensure you have sufficient disk space for the games to download. You can delete some unused DLC from your hard drive to clear space. No worries ... you can simply re-download them for free later if you need to from your account history.
Feb 10, 2015 | Navarre Darkest Of Days Xbox 360 -...
Having trouble connecting Xbox live. Have wireless router and wireless Xbox 360 adapter. Figured out where adapter goes. Now I'm stuck.
Is the router already setup and working? Do you have anything else that successfully connects to it "wirelessly", like a laptop or desktop or smartphone? If the answer is yes, here's how to setup the 360 to connect to your router:
1. Turn on the console and navigate to the wireless settings screen. On the Xbox 360, the menu path is "System -> Network Settings -> Edit Settings."
2. Set the SSID (network name) on the Xbox to match that of the wireless router. If your wireless router has enabled SSID broadcast, the SSID name should appear pre-selected on the Xbox display. Otherwise, select the "Specify Unlisted Network" option and enter the SSID there.
3. Specify "Infrastructure" as the Network Mode. (Infrastructure is the mode used by wireless routers.)
4. Set the Security Type to match that of the wireless router. If your router uses WPA encryption and the type of adapter connected to the Xbox does not support WPA, you will need to change your router settings to use WEP encryption instead.
5. Save your settings and verify the network is functional. On the Xbox 360, use the "Test Xbox Live Connection" option.
Tips: Even when your wireless connection between the Xbox and the router is working perfectly, you may still experience difficulty connecting to Xbox Live. These issues can be caused by the quality of your Internet connection or the firewall and Network Address Translation (NAT) settings of your wireless router. Additional troubleshooting may be required in these areas to achieve reliable Xbox Live connections.
What You Need: Active Xbox Live subscription (to access services)
edited from here: http://compnetworking.about.com/od/wifihomenetworking/ht/xbox2wifirouter.htm
Mar 05, 2011 | D-Link DI-624 Air Plus XtremeG Wireless...
The game disk I put into the Xbox 360 won't boot up.... It's says open tray on the screen every time.
Hi.
The lens unit has miss-aligned and may need to be readjusted so it will read the disks again. To do this you will need to open the Xbox360 up.
If the xbox is still under warranty then I suggest that you send it in to Microsoft to sort out. To do this please follow the instuctions below >>>
  1. Go to www.xbox.com and sign in with your Windows LIVE ID. Your Windows LIVE ID is the email address and password that you used to set up your Gamertag on xbox Live.
  2. Click the "Register a new console" button to register your xbox gaming console.
  3. Enter the serial number for your xbox console, which can be found on the back of the console, as well as your name and address. Click "Submit" when finished.
  4. Click "View Warranty Status" to view the warranty status of the xbox that you just registered. A pop-up window will open that will tell you if your warranty has expired and on what date it expired or will expire.
If is not under warrant then click on the link below for instructions on how to readjust the lens.
http://www.youtube.com/watch?v=TnVKjlpORYw&feature=related
Regards.
Jan 25, 2011 | Microsoft Xbox 360 Console
My xbox 360 says im connected to xbox live checked network setings and it says xb ox live is up and running...however when i try to play need for speed online..it says xbox live not working functionally?...
Turn on the console and navigate to the wireless settings screen. On the Xbox, the menu path is "Settings -> Network Settings -> Advanced -> Wireless -> Settings" On the Xbox 360, the menu path is "System -> Network Settings -> Edit Settings." Set the SSID (network name) on the Xbox to match that of the wireless router. If your wireless router has enabled SSID broadcast, the SSID name should appear pre-selected on the Xbox display. Otherwise, select the "Specify Unlisted Network" option and enter the SSID there. Specify "Infrastructure" as the Network Mode. (Infrastructure is the mode used by wireless routers.) Set the Security Type to match that of the wireless router. If your router uses WPA encryption and the type of adapter connected to the Xbox does not support WPA, you will need to change your router settings to use WEP encryption instead. Note that the standard Microsoft Xbox 360 Wireless Network Adapter supports WPA while the standard Microsoft Xbox Wireless Adapter (MN-740) only supports WEP. Save your settings and verify the network is functional. On the Xbox, the Wireless Status screen displays whether a connection has successfully been made with the wireless router, and the Connect Status screen displays whether a connection has successfully been made through the Internet to Xbox Live. On the Xbox 360, use the "Test Xbox Live Connection" option instead.
If you need more help post back! Thumbs and testimonial are welcome!
Jan 15, 2011 | Computers & Internet
Want to change e-mail address
You can change your email address if the email you registerd your gamertag with is NOT a @hotmail.com or co.uk
You can pay to change your gamertag over Xbox Live. But once an hotmail - email address is linked with a gamertag it is not possible to change it.
Hope this helps.
have a great day
Nov 20, 2010 | Microsoft Xbox 360 Elite Console - Black
How do i get xbox live??
If u have a credit card. connect your xbox to your network and enter the marketplace. there you will find the signup for LIVE icon and go from there. no credit card. purchace a Live membership from Target, Gamestop, Toys R us etc....Connect to LIVE with your xbox and enter the unlock code located on your purchased LIVE card. hope this helps.
Feb 15, 2010 | Microsoft Xbox 360 Elite Console - Black
I want to go on the internet through my xbox but dont know wat to go on to do it my xobox is connected to a network just not sure wat to go on
If you're talking about browsing the internet (like checking your email or going on websites), you can't do that with the Xbox 360. If you mean going onto the Xbox 360 online community known as Xbox Live then you need to register a gamertag (meaning your login/display name) from your Xbox menu.
Jan 07, 2010 | Microsoft Xbox 360 Elite Console - Black
Where do i register my xbox 360 to know if its
You need to go HERE You need a Windows Live account in order to register your console.Good luck.
Sep 01, 2009 | Microsoft Xbox 360 Console
Xbox 360 Cant update xbox live Susspended
You can go to www.xbox.com and log into your live account. In there you can add the pre-paid card to your account. There should be a way to do this on the console as well, but am not sure off the top of my head how to do so.
Jun 26, 2009 | Microsoft Xbox 360 Console
Will not see saved games
it might be your hard drive or memory stick try recovering it on a friends memory thingy P.S HAPPY HOLLOWEEN
Oct 29, 2008 | Microsoft Xbox 360 Console
Video Game Consoles & Games Logo
75 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
