Question about Frigidaire GLTF2940ES Front Load Washer
E10 error and fabric softner
My washer will run for varying times then stop with an E10 error.Also the fabric softner will not dispense anymore ive tried cleaning the tray several times
    President:
  • 1,294 Answers
Close your inlet valve at the wall. Unscrew your washer hose to examine any blockage in the small filter screens; clean out thoroughly and refit carefully, check for any water leak on opening the valve fully. If you have 2 inlets for the machine it would be good to get an F or Y adaptor.
Pl rate if helped................
Posted on Jan 24, 2008
Washing machine beeps, doesn't run
1 Beep/E10--Error: Water doesn't enter Cause: Water supply problem, Check kinks and faucets
1 Beep/E10--Error: Water leaks Cause: Water connections loose,household drain clog,oversudsing. Correct problems.
1 Beep/E10--Error: Dispenser drawer is open Cause: Washer will not operate if drawer is open.
Jan 08, 2014 | Kenmore HE2 Plus Front Load Washer
KENMORE ELITE FRONT LOAD WASHER, NO DISPLAY IS ON AND WHEN YOU PUSH THE START BUTTON IT JUST BEEPS ONCE and that is it. Thanks Craig..
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 13, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore front load washer error code E 10 - washer stops and beeps periodically and needs to have start button pushed again to complete cycle. Seems to happen one minute into cycle and then a coupleof...
Jan 11, 2010 | Kenmore HE2 Plus Front Load Washer
I keep getting an E1 Error code on my Whirlpool Duet dryer. Technician came and didn't fix it. Any suggestions?
Aug 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Wash starts, then stops postin E10 and now soap does not dispense
E10 code indicates there is no water supply.This can be confirmed by :
  1. Shut off the faucet to stop water supply to the washer.
  2. Disconnect and pulling the supply hose off the washer to confirm the E10Code
    • Opening the faucet and watch for running water
E10 also means that your cold water is coming in too slow, disconnect the cold water hose and check to see if the screen on your washing machine is clogged. If the screen is clean and the hose has good pressure then you will need to replace the water valve on your machine--- this is the piece that the hoses directly connect to.
Aug 02, 2009 | Frigidaire GLTF2940F Front Load Washer
Whirlpool duet dryer-error code e-1?
Jul 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
E10 error code
1 beep and E10 is listed as the dispenser door is open. Try reclosing your soap dispenser door tight.
Jan 18, 2009 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
I have a Fridgidaire Front Loader Washer _ Affinity. It has an error message flashing. E10. What does that mean? What do I do to fix it?
I have a Fridgidaire Front Loader Washer _ Affinity that flashed the E10 error code. I also had the problem with the fabric softener dispenser not emptying, and staying full of water. The problem was the cold water filter on the back of the washing machine that was semi-plugged. Cleaned the filter and now works perfectly. My machine is no longer flashing the Error code 10. The dispenser works perfectly.
Oct 05, 2008 | Frigidaire Affinity ATF7000ES Front Load...
E10 error code
I had this problem, the washer/dryer stopped working while in the drying cycle and displayed e10 message. It was caused by a faulty three-way inlet valve. The solenoid controlling flow to dryer condenser proved to be open circuit. Pulled washer out from under counter top, unplugged, removed top cover, tested solenoid circuits with ohm meter and found one solenoid was faulty. The filter going into the unit was clear. Replaced whole three way component with one ordered on Internet and all now works fine. Noticed that during drying cycle, water to condenser is constantly being switched on and off, explaining why the green condenser solenoid is the one that wears out first.
Mar 03, 2007 | Zanussi WJS1265W Front Load Washer/Dryer
Frigidaire GLTF2940ES Front Load Washer Logo
97 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
