Question about Encore Software Kawasaki Jet Ski Watercraft for Windows
2002 Kawasaki Jet Ski - no gas through fuel filter
Water got inside the engine. I rebuilt the engine for 2002 Kawasaki jet ski 1100 ZXI and replaced new fuel filter. When I tried to start, there's no fuel coming through the fuel filter. Please help.
  • nsoupharath Aug 11, 2010
    I replaced the fuel pump but the carb fill with sand corroded. I would like to know if I can replace the carbs year 2000 for my 2002 Kawasaki jet ski 1100 ZXI.
  • 11,800 Answers
When the water has entered the engine it most likely entered the fuel tank. In a normal fuel pump the gasoline has a lubricating effect that the water can't do so when the pump run on water it got worn out completely. Unfixable, the pump must be replaced.
Posted on Jul 15, 2010
  • 2 more comments
  • nsoupharath Jul 15, 2010
    Thanks for the advise...Before I order the new fuel pump, is there a way to check if the fuel pump is working or not?
  • Azrael SRL Jul 15, 2010
    Take it out, put it in a bucket of gas, connect it directly to a battery and you will see if it's working. But since it didn't sent any fuel to the filter you already know the answer.
  • nsoupharath Jul 21, 2010
    I also have another question. How about the oil pump? Does the oil pump need to be replace too? Can you tell me how to check to see if the oil pump is working or not? About the electrical unit, I think it should be fine right? Because, the engine turned when I tried to start up but no gas coming through the filter. I do not know how the oil connect/pump mixed with gas. Please advise...Thanks
  • Azrael SRL Jul 21, 2010
    No problem with the oil pump, separate almost completely sealed circuit so even if a little bit of water got in it didn't do any damage. BTW the oil circuit is completely separated from the fuel circuit.To test it is dead easy, just take it out of the motor, turn it  with a power drill while submerged in a bucket of oil and see if oil is squirted out.
    The electrics are most likely ok - as you said if it weren't ok you wouldn't get a spark.
Jet ski troubleshooting
damaged impellor or housing , grabbing air !
Dec 19, 2013 | WSM 1995-1997 Kawasaki 750 Zxi Cdi...
After seating for 3 years would not run
clean injecters and replace fuel ! compressions 100psi or more !?? sparks on all 3 cylinders ?
Aug 25, 2013 | WSM 1996-2003 Kawasaki Zxi 1100cc Jet Ski...
What are the flywheel torque settings for a 1998 kawasaki jet ski 1100 zxi?
You might want to post this question in a different section. This is the computer games section.
Aug 22, 2012 | Encore Software Kawasaki Jet Ski...
PlZ PLZ HELP kawasaki jet ski with fuel issues
Take your carburetor apart and clean it. There is moisture corrosion that is keeping the needle from moving. Be careful not alter the little teeter totter spring in any way.
May 15, 2010 | Encore Software Kawasaki Jet Ski...
I have a 1995 kawasaki zxi the bolts on top of
The numbers on the head are the torque pattern/order. Two stroke motors generally use a torque value of 18 to 22 foot pounds on the head bolts/nuts.
Feb 01, 2010 | Encore Software Kawasaki Jet Ski...
Type of gas
regular or unleaded are fine if it is a four stroke engine but if it is a two stroke engine you will need to fill an oil tank also with two stroke oil, or you may have to mix it in a can , see manufacturer for mix ratio.
May 30, 2009 | kawasaki Full Suspension Mountain Bike Men
Jet Ski Will not start when cold
If the teeter/totter needles are gummy or covered with moisture corrosion it could be the reason the machine is so hard to start. When storing the jet ski's syphon all the gas out and burn it in your car or truck. Even if you stabilize it it wont be good fuel in the spring. Your plastic tank will not rust so remove the fuel. You may be able to clean them up by running a tank of Chevron Techron through them. Before riding we charge are batteries and start are jet ski's on the trailer/lift before dropping in the lake. This saves the battery. It takes more juice to start the boat in the water.
May 25, 2009 | Encore Software Kawasaki Jet Ski...
Encore Software Kawasaki Jet Ski Watercraft for Windows Logo
799 people viewed this question
Top Encore Software Video Game Consoles & Games Experts
James Wishart
Are you an Encore Software Video Game Console and Game Expert? Answer questions, earn points and help others
