Did you mean your Samsung S8000 Jet phone displaying invalid Sim card?You need to unlock it from current network lock,to use other network sim card.Visit the site Mobileunlocksolutions.com get unlock code and unlock it easily.Then use with any GSM network sim card.Check whether unlock code is available for your network and country.If it is available get it and unlock it.You can unlock only GSM network locked phone.You cannot unlock CDMA network locked phone.After unlock your phone you can use any GSM network sim card in it.You cannot use any CDMA network sim card in it.
You need to unlock the network lock of the Samsung sgh-e250 to use it with other network Sim card. You can use unlock code to unlock the network lock. You can get the unlock code from Mobile-Unlocker.com . There you have to give your Country and current network name along with your IMEI number to get the unlock code. They will give you the unlock code along with instruction on how to unlock. Follow the instruction correctly and unlock your Samsung sgh-e250 .
while u start calling its gives u options like network one or network 2 the network 1 means it runs in mode of sim one in network 2 it can run with 2 sim
try to do these steps: 1. switch off your phone, remove battery, sim and memory card. 2. reinsert your battery and switch on your phone. 3. on your keypad menu type this code to make a hard reset. *2767*3855# 4. after hard reset, reinsert your sim, battery and memory card and check.
you may also want to try these. 1. remove your sim and have it check with other phone if it's receiving a signal. 2. insert another sim to your phone and check if it will receive a signal . 3. check your phone profile settings, press menu, select settings, select phone profile, select normal mode and check if it will give you a signal.
if you found out that your sim has defect, you may buy new sim and replace it, but if your phone has the problem after all of the above steps, go to your nearest samsung service center and have it check. if it's still under warranty, you may want to consider returning it your phone dealer, where you bought it, and have it replace with new one.
it might b the problem in urs sim.
sir, when u can change ur sim then ur mob is showing the network.
becoz the problem in ur sim! not in mobile.
thnxxx
it can be unlocked by calling your carrier and they will give you the infomation unlock code as long as the account is current and not delienquent if canceled it will cause some of the features not to work on the device
1)first go to setting on your ph.then select ph.setting.2)select network selection.3)show in your display automatic or manual select manual then show in your mob all service provider then .contact your nearest mob.repairing centre tell them problem in your network IC.
You need to get the correct and full data settings from whatever network provider the sim card is registered to, then make sure when they arrive to your mob. that you go into options of the data txt and install. This should/will sort out your issues.
