Question about Garden
Husqvarna 14' Model 141 Chain Saw
Husqvarna 14' Model 141, after cutting for approx 10-15 minutes the engine revs to extreme rpms amd using the on/off switch will not cut it off - must use the choke and choke it down. Any solution?
  • 169 Answers
THE IMPULSE LINE FROM THE CARB TO THE CRANKCASE HAS POSS FAILED, CHECK THE FUEL LINES FOR CRACKS AND PINHOLES, MAKE SURE THE INLET SCREEN INSIDE THE CARB IS NOT BLOCKED, WORSE CASE CENARIO THE ENGINE HAS A BLOWN CRANK SEAL CAUSING THE ENGINE TO RUN VERY LEAN WHICH WILL IN TIME "COOK" THE SAWS RECIPROCATIONG PARTS. AS FOR THE SWITCH ISSUE THE SWITCH ITSELF IS PROB BAD OR THE WIRING HAS COME UNPLUGGED OR IS DAMAGED......GOOD LUCK!
Posted on Nov 19, 2009
Testimonial: "Sounds very technical - too much for me, but I will pass this info on to a repairman. Thanks very much for your response and help."
How do i adjust the metering arm in the carb of a model 141 husqvarna chain saw
All adjustments made to the fuel are screw adjusted, three screws are low ideal, high ideal, throttle stop. A flat he'd screw driver should do.
Sep 04, 2013 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Where can i find a tool to adjust the high and low on the carb of a model 141 husqvarna chain saw
Stihl have a small orange screw driver- a tuning screw driver, it has an arrow on the end to show how many turns you have done when tuning your saw
357xp 359 After 15 to 30 min. of cutting engine gets extremly hot and cuts off. Checked spark plug,air filter, and made sure all cooling system components are cleaned. I was told it may be the...
The ignition coil is attached to the spark plug cable.Also check the spark plug number for the chain model.As the chain get older you can put a cooler spark plug and try before change the coil.
Nov 08, 2010 | Husqvarna Chain Saw Maintenance Kit 357xp ...
Saw starts but engine cuts out after less then one
i think you really need fresh fuel, clean out tank as much as poss with new oil also. will probably take a while to pump fuel through
Mar 06, 2010 | Husqvarna 450 e-series 18" Chain Saw
Husqvarna chain saw Model 141 running at high rpm's
You may wnat to inspect the intake manifold/boot that mounts inbetween the cylinder and the carb. Also, the impulse tube that comes from the bottom of the cylinder to the carb manifold or carb itself. Sounds like you are running a lean condition. You need to locate the source very quickly, or continued operation will permantly damage the saw. I have listed a few other things to check.
Please let me know what you find. rwvanlue
Basics to check:
1) Spark plug - brown or dark brown - OK
a) is it carbon or fuel fouled (black and carbon deposits)
b) is there spark
2) Muffler remove for inspection
a) exhaust screen clean or plugged
b) inspect cylinder wall/piston as the flywheel is slowly rotated
3) Check cylinder compression
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
Nov 13, 2009 | Husqvarna Garden
Cuts out on high revs 240 chain saw
Many saws made today are using electronics for engine control. If the engine rpm's starts to rev to high, the electronics in the coil will start to 'cut out' some of the spark. This is normal in this senerio.
But, now the real problem causing the senerio;
1) spark plug
Remove Carburetor
5) replace gaskets/diaphragms
b) use a spray carb cleaner to clean jets, holes, and body of carb
Nov 10, 2009 | Husqvarna Chain Saw 20" Bar
Chain saw not oiling properly
the oil outlet is plugged
Aug 17, 2009 | Husqvarna Garden
Husqvarna Model 141 Chainsaw Carb adjustment
The tool you need is available from Randy's Engine Repair, on his E-Bay store. The price is about $10., plus $3. shipping. Phone for Randy's is (937) 927-5665. It is usually busy.
Ebay item number is: 390025452838. Buy it online. I got mine about a week after I ordered it.
Jul 18, 2009 | Husqvarna Forest & Garden No.967012396 345...
Need true chain/bar size for my husqvarna Model 254 chainsaw
Maximum bar size of 20" but would recommend 18", if it is running sluggish, check compression, if low replace the piston, if it is 135psi or more then make sure the airfilter is clean and then tune the carb and make sure you get good revs and throttle response throughout the rev range, use the typical carb adjustments from the owners manual from the Husky web site. This is a 5hp saw and is capable of cutting some big lumps of hardwood so no excuses on the power front
Feb 25, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Garden Logo
174 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
