Question about Hyundai L91A 19" LCD Monitor
Its going blank say analog d sub
I turn it on and about 5 minutes later it says analog (d sub ) and goes blank? what do I do to stop this?
HD52W59YX38 GOES BLANK
Yes, the model indicated is prone to bad solder connections (among other things) at the high voltage transformer--that would be first thing to look at.
May 02, 2012 | Televison & Video
Toshiba tv screen goes black every 5 minutes with sound still on
Is it ok when you watch regular TV thru the cable or sat?
Jun 16, 2009 | Toshiba 46HM95 46" HDTV
Nokia 3230 screen goes blank after a few minutes of turning on.
hello !
replace the LCD theres a posibilty of it being foulty , the IC on the lcd is damaged and please check the lcd socket on the MB .
Thank you
May 28, 2009 | Nokia 3230 Cellular Phone
the problem on it is the crystal IC on the display,, replace it
Apr 04, 2009 | Nokia 3230 Cellular Phone
Lights blink and machine beeps
Check the flat connector that goes to the indicator lights the edge of the keyboard sometimes wears into itand causes a reset sequence.
DickyO
Oct 06, 2008 | Lexmark Wheelwriter 1000 Typewriter
LCD PROJECTOR GOES BLANK
Check the cooling fan/ air ducts - sounds like it's overheating and shutting off to prevent damage.
Mar 12, 2008 | Computers & Internet
Problems with keeping the projector on!!
if it is blanking orange:1- if any objects are blocking the air inlet or outlet grille remove them.2- do not expose the air outlet to hot air emitted from heating appliance.3-check whether the filter is clogged with dirt-clean the filter if clogged.
if it is blanking green:-after status indicator stop blanking press power.if you unplug power cord while the fan is rotating the lamp may be not turn on for one minute next time you plug the cord.
press power button several times.
Dec 08, 2007 | Mitsubishi HD4000U Multimedia Projector
Making Loud noises
Got the same problem with my second TX-S3082WH Slimfit...the first had the same problem...it was deemed unrepairable and I was advised to return it to Circuit City...now a year and five months later Samsung support has been less than helpful as I am 5 months out of warranty...don't know what I'm going to do...any advice would be appreciated
Dec 02, 2007 | Samsung TXR3079 TV
Screen goes blank after 5-6 minutes but sound continues
It may be overheating, check fans and or obstructions of the vents
Sep 02, 2007 | Runco CL-410 Multimedia Projector
Hyundai L91A 19" LCD Monitor Logo
123 people viewed this question
Top Hyundai Computers & Internet Experts
Tom Stevenson
Level 1 Expert
Randy Schumann
Randy Schumann
Are you a Hyundai Computer and Internet Expert? Answer questions, earn points and help others
