Question about Actiontec GT704WG Wireless Router (gs583ad3-01)
Not letting me on the ip address to set up
I read the previous post about this, and I'm using 192.168.1.1 to try and get the thing set up, but my computer isn't connecting to it. I noticed they've switched the ip address once before - did they change it again? My internet is working for everything else right now, just not the one I need.
I don't know if this will help you or not, but I've been trying too and not connecting. Then tonite, I tried and I got it! http://192.168.1.1 Good Luck! Jan 22
Posted on Jan 22, 2008
I think the default address is 192.168.0.1
Posted on Jan 18, 2008
    Novelist:
  • 139 Answers
You may be able to verify the router's address by checking the Default Gateway setting on your computer. For example, at the Windows command prompt, type "ipconfig" to display your current ip address settings...including the gateway (router) address.
Posted on Jan 11, 2008
After upgrading to Windows 10, my router needs to be reset (unplugged and then plugged back in again) everytime I want to use my computer. This is getting old!
You don't say exactly WHY this happens, or what message you get when trying to connect. It is most likely, from the sounds of things, an IP address conflict. Your computer may be set for a static IP address that is in a range that is assignable as a dynamic one. If the router gives your static IP to another device, then you won't be able to connect. Unplugging and restarting the router with your computer on and waiting to connect frees up the previously assigned IP address and lets your computer have it. You should check your PC to make sure that you DON'T use fixed IP unless there is a necessity for it. If that is the case, then you should, in the router table, assign the PC (using the MAC address from your machine) the IP address you want it to have every time it connects. That way you don't have to set your PC to a static IP and the address you want (or need) is always reserved for your machine when you connect to the router.
Dec 20, 2015 | Computers & Internet
How do I set up network scanning?
Hi Kenneth,
I saw your name on a previous query.
This best ting with this one is to follow any information on the www.Xerox.com website.
Good Luck.
May 22, 2015 | Xerox Phaser 3635MFP/X Multifunction...
I keep trying to hook to my wifi and it wants to change my IP address continuously. I had to change the settings to "static" and type in my IP address. Unit connects initially and then reverts to an
Keep the router to supply IP address using dhcp mode. Increase the lease time to 24 hours and don't forget to bind your device mac address with the dhcp IP in the router. This way it will always get the same ip from the router.
Dec 30, 2014 | Computers & Internet
How do I changed the IP address on Zebra 105SL Thermal printer? I need the steps on how to do it.
To enter Setup Mode, press SETUP/EXIT.
Press (+) or (-) until you get to IP RESOLUTION and then press NEXT/SAVE
Press the (+) or (-) key to display Dynamic or Permanent.
Select Permanent to give set it up for Static.
Go back to the previous menu and go into IP ADDRESS.
Press the (-) key to move the next digital position.
Press the (+) key to increase the value of the digit.
**The IP will not take if it is set to Dynamic**
To leave Setup Mode, press SETUP/EXIT.
"SAVE CHANGES" will display.
Select PERMANENT by using the (+) and (-) keys and then hit NEXT/SAVE.
You should now have the IP you put in configured on the printer.
Mar 02, 2011 | Zebra 105SL Thermal Label Printer
Imagerunner 210S. I have a network card in this used printer but my computer does not see it. How do I install this printer on my home network? Is there an adapter to plug into the ethernet jack to...
  1. You need to set a Static IP address in the printer:
  2. Press the "Additional Functions" key on the Canon Imagerunner 210N keypad.
  3. Tap "System Settings" and enter your administrative ID number and passcode if prompted.
  4. Tap the "Network Settings" button and tap the button next to "TCP/IP Settings."
  5. Press the "IP Settings" button.
  6. Highlight "IP Address" and use the keypad to enter the IP address you want to assign to your Canon Imagerunner 210N.
  7. Fill in the "Subnet Mask" and "Gateway Address" fields with the appropriate information.
  8. Press the "OK" button to save the network settings and enable the new IP address.
Read more: How to Set the IP Address on Canon Imagerunner 210 N ' eHow.com http://www.ehow.com/how_7427700_set-canon-imagerunner-210-n.html#ixzz19ZSyEw8N Then install the driver and poit them to the IP address.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Dec 30, 2010 | Computers & Internet
I have a linksys wireless-G model wrt54g and i'm trying to connect two computers at the same time wirelessly to the router. The problem is they keep kicking each other off the connection and i need them...
The most common cause for this problem is that the wireless settings for ip adresses at these computers are not set to auto; they are set to manual with the possible conflict at the wi-fi connection.
This procedure has to be done at both computers, one by one. Let's check some settings for the network connections. Click on "start" - "settings" - "control panel" - "network connections".
First we'll check the ethernet connection. Right click on "local area connection" - "properties" - choose "Internet protocol (TCP/IP)" - "properties". In case of not at automatically settings, click on both buttons to "obtain an IP address automatically" and "obtain DNS server address automatically". Your screen has to be like this:
Click on OK at both windows.
Now we'll check the Wi-fi connection. We are at the "network connections" window (Click on "start" - "settings" - "control panel" - "network connections" in case you close the window from the previous step). Right click on "Wireless connection" - "properties" - choose "Internet protocol (TCP/IP)" - "properties". In case of not at automatically settings click on both buttons to "obtain an IP address automatically" and "obtain DNS server address automatically". Your screen has to be like the previous one; the only difference has to be reffering the "connect using" line.
Check the results and in case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Nov 15, 2010 | Linksys Wireless-G WRT54G Router
I have problem setting up my wireless network and redirecting my wireless client to my local webpages before they can access to internet.   see this diagram below :...
you need to replace your modem with a router that is capable of running Network Address Translation. You are trying to route private IP's (192,168.x.x) over the public IP (internet) network.
Jan 31, 2010 | Microsoft Windows 2000 Professional for PC
Change the IP address
There are a couple of things you could have done. Did you turn DHCP off? Are you just trying to use this as a WAP? The easiest thing to do is plug your computer into one of the ports on the Belkin, and nothing into the LAN port, do an IPCONFIG release and an IPCONFIG renew and let the computer get a new IP address. Then try logging into the gateway address displayed.
If you're doing a WAP, set an SSID, set the IP address to your 235 and gateway to 1, turn off DHCP, or let it pass through, because you're going to let the Linksys give out all IP's, then plug the linking cable into network, NOT USING THE WAN port. From the network, you should be able to ping 192.168.1.235 if you can, point your browser to that address and see if you can now log into the Belkin.
If you run into trouble, comment back and I might actually download the manual :-)
Carl
Nov 07, 2009 | Belkin F5D7234-4 Router
I have netgear wpn824 wireless router and it works fine until I try to connect to my work server through their Sonicwall VPN. If I unplug the netgear and go straight into my computer through the DSL modem...
Two routers on two different sets of internal IP addresses will cause all kinds of conflicts. A VPN router is even worse. VPNs (virtual private networks) are designed to create encrypted tunnels between two computers. The computer its set to connect to must be authorized either as a user or a device with proper credentials. If your VPN authorizes devices based on MAC addresses, then unless your router's MAC address was previously authorized, youre not going to connect. Lets take the router out of the equation for a second. Do you have a working broadband connection from the sonicwall that the router can be plugged into? If you do, then you can treat this connection to your router like its a cable modem or DSL. If this connection has manual settings (such as IP address, default gateway, and primary and secondary DNS addresses) you will need these settings too. Post back and keep us updated...
Jan 17, 2009 | Computers & Internet
Adding additional computer problem
Yes, the xp machine connects to the net. DHCP is not enabled. The ipconfig/all command brings up the correct static ip address, subnet mask, and default gateway. But it does also say under the ip configuration that ip routing is not enabled. I did have the 2000 machine connected when I first set up the router yesterday, but I booted up my laptop to try to set up a wireless connection, and then I had to reinstall the entire router set-up.
Jan 12, 2008 | Linksys Wireless-G WRT54G Router
Actiontec GT704WG Wireless Router (gs583ad3-01) Logo
83 people viewed this question
Top Actiontec Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you an Actiontec Computer and Internet Expert? Answer questions, earn points and help others
