Question about Refrigerators
I DO HAVE A SUB-ZERO 601F AND I CAN'T KEEP THE SET TEMPERATURE -5 AND THE FREEZER BUILD A LOT OF ICE IN THE BACK PANEL, MAYBE THE DEFROST SYSTEM R DEFECTIVE OR...?
    President:
  • 2,702 Answers
No,,its more likley to be the thermostat thats set to high, try turning it down a little,,
Posted on Nov 19, 2009
Subzero Freezer ice keeps building behind coils
in 601 model. really common problem is the drain hater. watch close the ice maker for a BIG long ice. on the cotton psrt of the back wall. some models have 1 some 2 depends in the serial num. ask you tech for replace the DRAIN TUBE HEATER. that way your cover. really helps a lot the code number...................good luck................. leave a comment...........thanks
Sep 28, 2009 | Sub-Zero 19.3 cu. ft. / 547 liter Upright...
The temperature won't go down below 48 degrees
Maybe be defrost problem. If there is ice build up in back of freezer then its not defrosting and blocking air flow. also made sure fan is working on inside and outside coils. May need to call in a tech if any of the 3 problems are present. can also be freon, compressor or control problem.
Jun 29, 2009 | Sub-Zero 690 Side by Side Refrigerator
Ice Maker stopped working
You need to defrost the freezer. By the door being ajar, there was excessive ice build up on the coil that was not removed during a system defrost resulting in a blocked coil. This caused the temperature to rise in the freezer above twelve degrees that is why the ice maker stopped.
May 19, 2009 | Sub-Zero 561 / F
Sub zero refrig - ice forming inside
The solution posted previously is TOTALLY WRONG. A Sub Zero ref doesn't have a heating element in the fresh food section. Only in the Frozen food section. It has 2 totally separate systems for each section. 2 Compressors and 2 evaporators. They share a condenser. If you are having ice build up in the refrigerator then the problem you are having is a refrigerant leak in the fresh food evaporator. You need to have a certified tech come out and replace the evaporator in your refrigerator section of your Sub Zero. Not sure what you are asking about the thermostat.
Oct 12, 2008 | Sub-Zero 661/F Side by Side Refrigerator
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 06, 2008 | Sub-Zero 650 / O Bottom Freezer...
Cannot open the bottom freezer door anymore; it seems stuck
sounds as though the defrost system has failed or the freezer defrost drain is blocked. take off the back panel of the freezer and see if excess ice build up. if so, defrost carefully with a hairdryer. at bottom is a drain. check if blocked with ice and if so melt off with hot water till water flows away freely. if i'm right, appliance will start to work. if fault re-occure then defrost system is at fault
May 06, 2007 | Sub-Zero 611 / O Bottom Freezer...
Refrigerators Logo
75 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
