Question about Moultrie GameSpy 4.0 Digital Camera Deluxe
Where does the external power supply plug in ? The system uses 6- 1.5 volt batteries , This equals 9 volts ..... Does this mean that the system is 9V ? Can I use a 6volt power supply with a solar panel? Your advertised external power supply is 12V..... How does this work on a 9V camera ? Looking for a way to leave the camera long term with out having to make a 200 mile trip to change batteries every few weeks.
  • 300 Answers
SOURCE: Compaq V2000 Dead
I also have a v2000 which has suffered the fate in the passed, unfortunately as i'm sure you've already read you will probably require a replacement system board.
Posted on May 25, 2008
SOURCE: Cobra PR3850WX will not recharge batteries
There is a contact in the upper left hand corner of the batt compartment.This has to touch the metal of the last batt.If your batts have paper around them scrape it off where it contacts that contact point.
Posted on Nov 18, 2008
michigan man
  • 3533 Answers
SOURCE: 02 escalade, vehical stalls at low idle
if it has over 40,000 miles on it change the drive belt and have the alternator tested and also make sure all of the vaccum lines are on and in place
Posted on Mar 06, 2009
  • 303 Answers
SOURCE: Can't find a replacement 10.5V DC power cord
You can buy a new car adapter by clicking on the hyperlink:
buy replacement car adapter power charger cord for Durabrand DUR7 DUR-7
Posted on May 31, 2009
motor1258
  • 6674 Answers
SOURCE: 93 stang fuel pump wont run
I'll dig into some schematics and see if I can get more info for you. Be back as soon as I can.
Posted on Aug 09, 2009
Which setting should I use? Please see 'added details, below.
3 volts, if that doesn't charge the battery then select 4.5 volt. No higher
Feb 28, 2017 | Iomega Computers & Internet
Tip
Olympus E-10/20
I have been on love with my Olympus e-20n since the day I bought it. Yes, it's only 5 mega-pixel but the SLR design and full manual functions out weigh the limited resolution. I was very disappointed when I tried to buy a replacement high capacity battery and Lithium Polymer 8400ah battery was not only discontinued but totally not available (except for some used ones on Ebay and I'm just not brave enough to buy a used battery)
So crafting a replacement became my Memorial Day Weekend project. One quick trip to Fry's Electronics later and I had the solution. A 6-cell AA battery holder, 6ea AA NiMH 2600ah rechangeables and a 9-volt battery clip with pig tail is all I needed.
Crack open the external battery add-on (looks like a power winder on a 35mm SLR) 4-screws on the botton, one inside the battery well and 2 under the rubber hand grip. Locate the battery connector and un-screw the RED and BLACK prime power leads from each side. Cover the connector with electric tape or an insulated cover, your done with it, forever.
Solder the pigtail 9-volt battery clip to the RED and BLACK leads (red to red and black to black, duh!). Extend the 9v battery clip outside the case and re-assemble the case.
The 6 AA-cell battery holder will fit nicely into the battery door cup and if you pack the vacant space in the battery well with sponge or an old gym sock the battery will not slide around.
Fill the AA battery holder with the rechargeable batteries you have freshly re-charged and hook up the 9v clip. Thats it, new life for the my old companion.
on May 31, 2010 | Cameras
Where can I find an adaptor to fit a Hohner Keyboard PSK75 9 volt
You can actually use any 9 Volt adapter, as long as the adapter's Amp rating is higher than what the keyboard requires, and the polarity of the plug corresponds to that of the keyboard.
The keyboard consumes 7.7 Watt maximum, which means any 9V 1A (1000mA) adapter will do, but check the polarity on the plug.
Dec 31, 2015 | Computers & Internet
6 AA Batteries generate how many amps
If this is a battery powered CD player,
we are talking mA not amps.....6 x 1.5volt batteries give you 9 volts
I would recommend something like this:-
http://www.ebay.co.uk/itm/New-AC-DC-Universal-Travel-Adapter-Input-110-220-Volt-7-Output-500mA-/251316939793?_trksid=p2054897.l4275 This will have more than enough power for the CD Player.
Feb 06, 2013 | Sharper Image Audio Players & Recorders
I had a power failure, wiyh power off about 6 hours. Since power ws restored, I hav a low battery alarm for about 3 days. The system is about 11 years old. It currently has a hard-wired rechargeable...
The charge circuit probably only supplies a tiny charge current to prevent overcharging of the main battery and I suspect the original is a NiCad and has likely lost a cell or two (shorted; it's common with them) over that fairly long period.
Replacing it with either Lithium Ion or NiMh rechargeables with a honest voltage rating (*some aren't) is a good move; neither of these are as prone to failure as NiCad is. Don't be surprised if you still have a 'low battery' alert for several days since these batteries rarely have a full charge when shipped.
*So-called '9V' block batteries are, except for rare batteries, actually 8.4 or even only 7.2 volts. I have some instruments that indicate 'Low battery' with either of these even when fully charged.
Apr 08, 2011 | GE Iti Simon Burglar Alarm Home Security...
It wont power on, no matter being plugged in correctly, I think someone might have used the wrong ac adapter, would this have recked er up? lol
Yep. Plugging a 9 volt transformer into a 6 volt device wil recked er up ... so would using a 9 volt DC in a 9 volt AC device. Test the power supply before you trash it. Make sure it is putting out what it is rated to put out.
Thanks for visiting today.
Jan 28, 2011 | D-Link DIR-628 Wireless Router
What voltage are the koss 'older' computer/CD speakers that would take 3 'C' batteries each. I have a variable voltage adapter and am not sure if I should switch it to 9 volt or another setting for AC...
C cells are 1.5 volts each. If the speakers use three of them that means you'll need a 4.5 volt supply. If each speaker needs batteries, you'll need to feed that voltage to each speaker, and the supply should have enough current for the total load. A 1-amp rating is probably fine.
Dec 24, 2010 | Koss HD 50 Computer Speakers
Batteries
I think you will find that one 9 volt battery would not last any time at all. the 6 AAs have a big capacity and that's why they use them, a little 9v battery is intended for low power equipment.
I see it is supplied with a 12v AC adaptor, if you connect a 12V battery via the adaptor socket you may get a longer run time if its a rechargable battery even better.
Jan 22, 2010 | Meade NIghtView NIght Vision Monocular
BellSouth caller ID -- CI-26
There are 6 AA batteries connected in series so that = 6 volts.
Nov 30, 2007 | Lands Phones
Moultrie GameSpy 4.0 Digital Camera Deluxe Logo
49 people viewed this question
Top Moultrie Cameras Experts
Steve
AZBen
AZBen
Are you a Moultrie Camera Expert? Answer questions, earn points and help others
