Question about Honda Garden
No spark 5.5hp honda washer - Honda Garden
  • 486 Answers
1) How have you determined that there is no spark?
2) Have you used a type of spark tester?
3) What is the condition of the plug. Brown or dark brown is OK. Black or silver is NOT Ok.
*If you do not have a spark tester,
a) remove the plug, and with it connected to the wire,
b) find a portion of metal around the cylinder that you can ground it on, and then pull the rope.
c) If the plug is black, you may see spark, but you should replace the plug.
*** PLEASE NOTE ; if there is excess fuel in the cylinder or on spark plug,
it can catch fire, so be carefull to cover the hole with a heavy rag so that any fuel
cannot be exposed to spark plug durning test !!!!
Get back with me on how this issue works out.
thanks, rwvanlue
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Posted on Nov 19, 2009
Honda gc160 engine on 2500 psi washer, no spark?
new spark plug? flooding may have fouled the old one.
Jun 05, 2008 | Karcher 2500 PSI Pressure Washer
How to fix a flooded engine.
Remove the spark plug and pull the starter rope several times to clean the cylinder, clean the spark plug and fit it back, try to restart the engine.
Aug 13, 2014 | Honda Gx390 Gx 390 13.0 Used Small Engine...
Want is the spark plug gap on a Honda GC160 - 5.0 model # wp2003omhb
usually honda uses 0.024in spark plug gap, if you are using new plugs they specifically say that they do not require being gaped, if you are maintaining old plugs use 0.024in as the Honda standard.
Apr 30, 2014 | Honda Garden
Black max 3000 honda pressure washer won't start
You need two things for the engine to start, spark and fuel. Pull the plug, hold it close to the engine and pull the starter cord- check for spark. If there is spark (most likely there wil be spark), then it is a fuel problem. Try a little startiing fluid into the breather and see if that gets it to start. If that works, then the problem is in the carbureator - it probably needs to be rebuilt if the engine has been sitting for a while.
Apr 13, 2014 | Honda Black Max 3000 Psi Pressure Washer
My 13.0 honda gx390 motor has no spark and will not start
try disconnecting the black wire which runs across under the fuel tank you should have spark.
Nov 15, 2011 | Simpson Taskmaster Industrial Gas Powered...
What is the spark plug gap?
Hi Mike,
If you can identify the model of Honda engine on the washer, you can download the service manual from this webpage:
http://engines.honda.com/models/application/pressure-washer
Hope this helps!
Apr 06, 2011 | Porter Cable PCH3200 Commercial Pressure...
Spark plug is fine but it doesn't fire when you pull the cord. Water hose is connected and turned on, pressure nozzle open per instructions.
did you check for spark,maybe a new spark plug but check for the spark. if not check coil or wire and boot
Sep 12, 2010 | Honda Pressure Washer PSI 3000
Honda Pressure Washer HP 5 not starting
You can try spraying some carburetor cleaner into the carb. If it starts for a minute, your carburetor need cleaning. When you added new gas did you remove the old gas first? Is the air filter clean?
Jul 18, 2009 | Honda 8 HP Engine
Garden Logo
160 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
