Question about Vizio VP322 32 in. Plasma TV
For the past week the set cycles on-off-on.........numerous times,as many as thirty when first turning on. Now it does nothing.
  • 834 Answers
Sounds like you have a bad cap in your power board the power board is the one where the AC cord plugs into these can like devices will be puffed up on the tops from venting the values are on the side replace them and your good to go
Posted on Nov 19, 2009
Battery was disconntected to replace a connector now computer is 'not ready' and failed emissions test. driven it over 600 miles since then. Tried to follow steps to complete a 'drive...
Do you have a service engine light on or does the smog station tell you that the monitors are set?
A drive cycle won't clear a service engine light if the reason for it was not fixed. Normally a drive cycle or a 25 or so mile drive will be enough for the PCM to run through its test, and if all is well, clear the monitors.
Now some shop scanners and code readers can clear the monitors. Actron is one of the code readers that I know of that will clear monitors (the newer models. older ones did not). They are about $75 for the basic code reader and may be a worthwhile investment for the do it yourselfer.
Auto Zones also have code readers and if theirs is capable may do it for you. Though if you're in California I have heard they don't do that any longer due to people getting codes cleared just before a smog test without fixing the issue first.
Sep 09, 2011 | 2000 Saturn Ls 4dr Sedan
I purchased a Marco Max watch with day, date and moon phase. How do I set each of the dials to match the correct day of week, month and hour?
The crown has three positions. The A position is when it’s pushed all the way in. You can’t set anything in this position. The C position is when it’s pulled all the way out. The B position is the click between all the way in and all the way out. My biggest problem is that I read the directions to mean that there were FOUR positions. I didn’t realize A was all the way in. I thought there was three pulled out positions.
To set the day of the week (Sun, Mon, etc.): Pull the crown all the way out (position C) and turn the time to just after midnight. The setting will click to the next day. To advance it an additional day, you don’t have to turn the hands another twenty four hours. You can turn the hands backward to before midnight (you will see the day of the week setting click a little, but not go backwards), then turn the hands past midnight again.
I recommend setting the day of the week setting to YESTERDAY. You’ll see why later.
To set the date: 3341598183_60e77d12e5.jpgPull the crown one click out (position B) and turn the crown away from you (clockwise). This will advance the day indicator (it looks like a second hand). To set the month, you have to keep turning until you get past an entire year. There is no separate way to set the month. To make the correct month show, you must keep turning the crown past every day of the year until you get to the correct day.
I recommend setting the date to YESTERDAY. I’ll explain why later.
To set the moon phase: Pull the crown one click out (position B) and turn the crown toward you (counter clockwise). To find out what phase the moon is currently in, here are a couple of websites:
Once again, set it to the moon phase for YESTERDAY.
To set the time: Pull the crown all the way out (position C) and turn the crown either away or towards you to set the time. Keep turning the time away from you (clockwise) until you get past midnight. Once you get past midnight, ALL the settings should change (day of the week, date and moon phase). Now you KNOW you’re on today’s date at just after midnight. Set the correct time and your Luar watch is ready to go!
Review 3342440924_5fa48ca4fe.jpgMany of the Swatch enthusiasts were disappointed that the Luar is a battery powered watch instead of an automatic. With a price tag of approximately $450, it’s a little much to expect an automatic with a real moon phase. I’ve talked at length about what I desire in a watch here:
My desires have changed a lot since that day nearly four years ago when I went looking for the perfect
To set the date: Pull the crown one click out (position B) and turn the crown away from you (clockwise). This will advance the day indicator (it looks like a second hand). To set the month, you have to keep turning until you get past an entire year. There is no separate way to set the month. To make the correct month show, you must keep turning the crown past every day of the year until you get to the correct day.
To set the time: Pull the crown all the way out (position C) and turn the crown either away or towards you to set the time. Keep turning the time away from you (clockwise) until you get past midnight. Once you get past midnight, ALL the settings should change (day of the week, date and moon phase). Now you KNOW you’re on today’s date at just after midnight. Set the correct time and your watch is ready to go!
Aug 11, 2010 | Watches
For the past 4 days or so when I turn it on it will cycle on/off numerous times before powering up and staying on. Today, however (5/26/10), it would not power up at all - nothing, no light in front, no...
Ur tv the power supply board before it have those parts call capacitors it have gas leakage,that why u turn on/off numerous times it powering up.The power supply board,the board the a/c power cord go into it.that ur power supply board.Now all those gas leakage capacitors are bulges up on it top or puff on it top are total dead now.U know basic electronic's and soldering?Searches all around the power supply board and it supporting boards.Replaced all those defective dead capacitors that bulges up on it top or puff on it.Ur tv power well return and work.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
May 26, 2010 | Vizio VP322 32 in. Plasma TV
Just been given an Audemars watch - don't know how to set it.
I was unable to find any instructions on their web site, so if you haven't got the instructions, then I suggest you try ringing them on one of the numbers below. (You might ask them for a set of instructions as well as how to solve your problem).
Toll Free: (800) 595-5330
Phone: (239) 262-4545
Jan 31, 2010 | Audemars Piguet Watch
The clean lite came on, I held down for numerous seconds & it blinks, but nothing happens--I have tried unplugging &hitting the on button--nothing seems to make the cleaner vinegar go thru the...
The cleaning cycle takes about an hour. Unplugging, or turning off only delays the process. Place your solution in and set the self-clean, then walk away for about an hour. If it has not completed after an hour, call the GE service numbers found on the front of your user's manual.
Jan 04, 2010 | GE 106591 Coffee Maker
Dryer starts to run on its own
Some dryers have a touch up cycle that runs automatically to keep clothes from wrinkling if they are left in the dryer.
Some touch up cycles are selectable. Some are automatic.
Mar 07, 2009 | Whirlpool GEW9250 Electric Dryer
My phone keeps on switching off and then it doesnt switch back on. to switch it on i have to put it on charge even though it is full charge.
Try this simple solution first, if not, I will provide additional solutions.
1. Turn off your phone.
2. Take the battery out.
3. Take the sim card out.
4. Wait thirty seconds.
5. Replace sim card.
6. Replace battery.
7. Turn phone back on.
That should fix your malfunction. I've had that problem numerous times in the past. I hope it helps! If not, let me know and I will do my best to come up with other solutions for you.
Please rate FixYa!
Dec 28, 2008 | i-mate JASJAR Cellular Phone
Anne Klein chronograph watch
The button advances the numeric day. After the numeric day is advanced one full month, the month dial advances to the next month. I just about got a blister pressing the button enough times to advance the month from January all the way around to December. Then I had to advance the numeric day to the current numeric day. The previous person told you by turning the dial 24 hours you can advance the alphabetic day of the week by one day (Sun, Mon,etc.).
Sep 04, 2008 | Casio G-Shock G7100D-1V Wrist Watch
Light flashes, bulb fires, no LCD!!
Sounds like the ballast is faulty or else your lamp is getting close to needing replacement. Hope this helps.
Jan 16, 2008 | Zenith E44W46LCD 44" Rear Projection...
Vizio VP322 32 in. Plasma TV Logo
107 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
