Question about Pool & Spa
We have replaced a gas valve 3x and works fine for 2 mths then when ignitor tries to ignite, valve does not open and allow gas to burner manifold. Eventually heater quits operating.
  • 366 Answers
You need to have your gas pressure tested, it sounds like the gas pressure may be causing the failure. Should be around 14"WC or a little less.
Posted on Nov 20, 2009
Flow plug
even though the ignitor seems to glow bright orange,it still maybe weak,as in not enough current to open the gas valve,an easy test is to just swap out or interchange the broiler ignitor and bake ignitors and see if this takes care of your issue on the lower bake side as most units use the identical ignitor for each upper and lower manifolds and the gas valve supplies both the bake and broiler manifolds depending on which you choose to use bake or broil
May 28, 2012 | Jenn-Air Chef Gas Oven Range Ignitor Flat...
Oven does not light. Top ignitor glows red bottom
Since BOTH oven manifolds and surface burners are usually fed from the same source, this is probably the result of failed igniter(s) in the oven. This is assuming that your surface burners are working, or course. If you are trying to light the BAKE manifold, the broiler manifold is used on some model to speed up the pre-heat process. So, you may see the broiler attempt to light as well. If you have tried using only the broiler by itself and it still does not light, you may have a weak igniter on that manifold as well. Double check your symptoms.
If this is a GAS range, as these igniters age from repeated use, they can become weak and longer function. If you are experiencing ignition problems, the following link explains a little theory about how these igniters work and how to replace one:
http://www.fixya.com/support/r3575727-replacing_an_oven_igniter_on_a_gas_range
The burner manifolds in the oven each use a glow bar or electrode type igniter with a gas safety valve to ignite. Both oven manifolds are controlled by the Electronic Oven Control (EOC) board, which is your clock/timer on the control panel. If the surface burners work, but the oven does not, the problem is usually not a gas related issue. It can be a control board issue, but is usually a weak or failed oven igniter.
Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between these sites, so shop and compare. The first three sites listed also offer helpful exploded view diagrams to help you locate and properly identify the parts you need.
If you have any questions please post back with a complete MODEL NUMBER and let me know. I hope this helps you.
Jul 19, 2010 | Tappan TGF657 Gas Kitchen Range
Ignitor lights up bright, but no ignition,no flame and I don't hear the gas turn on like I normally do. Top burners work fine.
Hello, welcome to fixya ! Based on your description I suspect you have a faulty bake ignitor. This may surprise you, or it may not. I think at first it surprises people when the hot surface ignitor glows but the oven won't lite. Since the ignitor "glows" one figures it would appear to be working, that would be wrong. These ignitor's serve 2 functions, 1) need to maintain a set value to open/activate the gas valve, typically around 3.5amps... & 2) ignite the fuel once said gas valve is open. A poor/faulty ignitor may glow & and even ignite the burner intermittently for moments at a time ( thus giving off some heat but never the set amount or not lite at all ) but yet not reach the needed value to open the gas valve/safety valve consistently nor adequately, hence the need to replace the ignitor. Try this and I'm certain you'll be up & running and as they say " cookin' with gas" ! I'd suggest you should refer to your specific model when ordering the part locally or on-line. The most common hot surface ignitor part is #12400035 and it will work in your Whirlpool too. Try places like repairclinic.com, searspartsdirect.com, APwagner.com etc. Thank's for visiting "fixya" for your stove inquiries. Please take a moment while here to rate the solution provided or let me know if you require further assistance and good luck. macmarkus :)
May 23, 2010 | Whirlpool AKZ159IX Oven
Bryant Gas Heater goes into ignition lockout daily.
First of all try cleaning all the components inside the burner assembly, including the ignitor and the flame sensor.Try cleaning flame sensor well with steel wool or sandpaper. after cleaning check out.if the problem is same then, check out whether the manual gas shut-off valve is on and not off, and the gas lines leading up to and inside the unit all seem unmoved and undamaged. If everything is proper then remove cover from burner compartment and re-try. If ignition is successful, check for leaky ignitor gasket, or look CLOSELY for webbing inside far-right burner. It can also be caused if there is low gas presure, or a bad gas valve. That has to be checked.
To remove and replace/check the burner .follow this instructions
(These instructions apply to an upflow installation. Turn 90* in appropriate direction for horizontal orientation. Only perform these steps if you are sufficiently qualified.) Turn off power & gas supply, loosen nearest union BETWEEN gas **** & furnace. Remove wires from gas control, noting where each one belongs. Remove cover from burner enclosure & remove 2 screws securing manifold to enclosure. Lift upward/outward to disengage manifold from enclosure & carefully move aside. Remove screws securing burner set, remove burners. Inspect burners for debris in passage and runner slots. Check manifold orifices for blockage (ants?), particularly the one facing burner nearest to ignitor. If debris is present inside burner enclosure, CAREFULLY remove with vacuum cleaner. AVOID ANY CONTACT WITH IGNITOR. Re-install burner set and manifold, assuring that manifold brackets engage correctly in slots AND all orifices engage fully into burner entrance, replace manifold screws. Reconnect wires to gas control, reconnect gas supply & turn gas on. Apply liquid soap to union, check for bubbles (indicates leakage - correct before proceeding). Re-install cover on burner enclosure. Turn on power supply and check unit operation. Pay particular attention when re-installing manifold to assure proper alignment of orifices into burners.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Jan 10, 2010 | Heating & Cooling
I have a kenmore gas range model # 362.7275590 Burners work and i replaced the electronic igniter and it glows but gas does not come on. gas valve is on.
With gas stoves its either or...if your ignitor is weak it may not allow the gas valve to open...a new ignitor and it works fine././/now you have a defective gas valve....new ignitor but no gas....The gas valve is wired through the ignitor and makes it difficult to diagnose...especially on here :)
Nov 01, 2009 | Kitchen Ranges
I have an older model Kenmore gas dryer. Model #87681110. It was not putting out heat so I replaced the ignitor. It worked for the first load of laundry but then began acting erratically. This evening...
hi bob,
try replacing the gas valve coils,
they are the hold and asist,
one allows voltage to the ignitor, one
allows voltage from ignitor to open the gas valve/ well actually resistance, but im sure you understand
they are pretty commanly the problem with your diagnosis
Oct 15, 2009 | Dryers
I have a Whirlpool Super Capacity 465 oven Model# SF315PEG. The bake valve was being energized but not opening to allow gas into the burner. Bought a new valve assembly P/N 3195008 and replaced. Problem...
The ignitor is not allowing enough 'current flow' to open the valve. The ignitor , even if it glows, can be 'low current' to valve.
(the ignitor current controls valve)
Sep 03, 2009 | Ovens
Kenmore gas dryer mod.110-73942. burner comes on as normal. After 5-10 minutes running Cycles off, igniter ( new) glows but no burner ign. Also replaced the sensor adjacent the igniter.
The gas valve coil is bad. When the ignitor is glowing the gas valve should open and allow gas in to be ignited. Change the gas valve.
Aug 05, 2009 | Kenmore 63942 Dryer
Oven burners will ignite on broil but not on bake mode. Ignitor is new. Is not allowing gas valve to open but is pulling 2.7 amps through ignitor. Why would gas valve not open to allow ignition?
This is a defective Coil assembly. the coils initiate the opening and closing of the gas valves. you will need to replace the coils. this will correct this issue.
Jun 24, 2009 | Ovens
Thermador Gas Range - Griddle ignition will not spark
I have a Thermador Gas Range PG364GDBS - Oven, 4 burners, and center griddle. All are gas. The four burners and gas oven work fine. The griddle just stopped working, no spark. Turning on the griddle control, the gas valve opens(hear it), gas flows (smell it), but the ignitor will not spark (no loud or faint spark that I can hear). I got a replacement ignition device (mount at the burner) thinking it might be the problem, but still no spark. I checked the AC voltage at the terminal and measured 39 VAC between the terminal and ground. Not sure if that is the correct voltage. Any insights or advice would be great.
Dec 07, 2008 | Thermador SGS36GS Gas Cooktop
Pool & Spa Logo
71 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
