Question about Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k
Craftsman compressor won't start
It just hums when turned on
  • 530 Answers
There are several things that can cause your problem. Using an extension cord of insufficient rating, a failed capacitor, a failed motor and last a faulty unloader valve.
The extension cord is easy to check so I'll skip it.
The unloader valve is easy to check. It will cause this problem when the unload fails to discharge the pressure remaining between the tank check valve and the cylinder. It is the sudden release of pressure when the tank has reached it's max psi. If it doesn't release the piston has to work against the max psi. from a dead start. Most of the time a compressor will run really slowly then trip the breaker but your compressor is well please don't take this personally it's a girlie compressor.
Simply loosen one of the fittings on the tubing that run between the compressor head and the switch to bleed off any pressure manually.
If you have no pressure release then most likely it's the starting capacitor.
Below is a link where you should be able to get a new capacitor.
However I would like you to remember this your compressor is not built to last. In fact it is commonly referred to as a throw away. So before you spend anything you might want to ask yourself how much do you use it. If you use it a lot now or are planning on using it more in the future you may want to replace it with something a little better built.
Hope this helps
http://www.mastertoolrepair.com/921153101-p-24902.html
Posted on Nov 19, 2009
Fan won't run / won't cool
It may have a faulty compressor relay or overload, best to change both at the same time. It's either that or a bad compressor.
Jan 06, 2018 | Kenmore 73055 Air Conditioner
I have a 33 gal craftsman compressor when I turn on the relay switch hums but the motor doesn't spin?
I would check the capacitor since it appears that the motor is not locked up. Here is a how to on testing capacitors;
how-to-check-capacitor
May 16, 2012 | Craftsman 33 gal Air Compressor 6 hp...
I have a 30 gal 5.5 hp oil free Craftsman air compressor. It was brand new several years ago but never used it. It set in the original box in the garage. Went to use it today and when plugged in to start...
Are you a mechanical type person? There is a fast and easy way to test the motor but it is not recommended for anyone who doesn't do this for a living. I have replaced 4 shaded pole motors in the last 3 years that did the same thing and never had a problem with a capacitor start or capacitor start/run motor. If the motor hums, it is trying to run. Try giving the stator help getting started while the motor is humming. Use a small piece of wood or soft plastic. Any non-conductor will do. Look inside the rear of the motor and you will see the field coils around the outside surface and the stator is the round thing in the middle of the motor that rotates. Use the non-conductor to start it turning in the direction it would normally run while the motor is humming. If the motor starts and runs ontill the pressure switch shuts it off, the motor is bad. If it has a capacitor on it, try replacing that first. Please let me know how this works out for you.
Apr 02, 2011 | Craftsman 33 gal Air Compressor 6 hp...
My Craftsman air compressor is locked up. When you turn the switch on it just makes a humming noise and thw motor will not come on.
1. While the compressor is unplugged, see if you can turn the motor freely with a screwdriver or something to determine that the motor is not jammed 2. If there is a removable cover, check to see if the brushes are worn, (replace if needed). 3. There is also a relay that tells the motor to start located near the pressure adjustment. If this relay is defective or the contacts are burnt, you may need to replace the relay. Good Luck!
Nov 15, 2010 | Craftsman 1 Hp, 4 Gal. Air Compressor
Motor hums dont start
sears craftsman air compressor motor hums. replaced start capacitor still hums
Mar 13, 2010 | Clarke Power Products Inc AC2001 2HP 4...
Craftsman air compressor is hums but the compressor will not fire up
IF THE COMPRESSOR IS 208/ 230/ 240 VOLTS CHECK THE VOLTAGE FROM HOT TO GROUND AND MAKE SURE YOU HAVE BOTH LEGS COMMING IN ARE HOT. IF SINGLE PHASE 120 YOU MIGHT WANT TO CHECK THE CAPACITOR IF IT IS CAPCITOR START
Sep 27, 2009 | Craftsman Air Tools & Compressors
Sears Craftsman 3-Gallon, 1.5 HP Air Compressor Hums
YES IT MAY BE THE CAPACITOR . IT COULD ALSO BE THE WIREING IN THE MTR, THE PUNP ITSELF.
Nov 10, 2008 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k Logo
1,689 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
