Question about Maytag Dishwashers
When i close the door i hear it close but i have to put something up against it to keep it washing if i take it away it stop washing
    Sergeant:
  • 172 Answers
Door switch The door switch is important because, if it's defective, the dishwasher won't work at all. To reach it, you need to remove the control panel cover, or sometimes the interior liner of the door. If it's defective, you need to completely replace it.
Latch The latch on many dishwashers is adjustable. If your door is easy to close but difficult to latch, adjust the latch to let the door close more easily. If you can't see any way to adjust the latch, yours may be fixed in a certain position. Check for other reasons for the latching problem. If the latch has worn out in a way that makes it impossible for you to close the door properly, you probably need to replace the latch.
Posted on Nov 19, 2009
The door on the freezer will not keep closed. What could be the problem?
There must be something your not seeing, get an extra set of eyes on it.
Oct 25, 2015 | Frigidaire LFFH17F7HW 16.6 Cubic Feet...
The machine keeps stopping mid rinse cycle, can u help please?
Most washers have a door switch that stops the spin cycle when the door is open. Find the door switch and try to manually engage it. If you can hear a click and the washer starts again, the switch is probably OK. There is something not letting it engage. I have replaced mine for around $30.00 by watching a video on youtube. Put in the Make & Model # & lid switch in the search bar and see if there is a video. If not, you can get good advice at your local appliance store.Good Luck!
Feb 23, 2013 | Washing Machines
Washer. door lock wont lock. I hear a click click, like it's locked, but the indicator lock light is not on, then a couple seconds later I hear another click click like it's unlocking and then...
the actual door lock switch inside the wall of your washer where the door clips in has most likely burnt out or a piece has broken out of it i have found the only way to fix this problem is to replace the door lock switch
Jun 07, 2011 | LG WM-2277HW Front Load Washer
The lights will blink when the door is closed and the start button is pushed
Try a reset. I have a kitchenaid. The reset is to press the sani-rinse, hea-dry, sani-rinse, heat -dry, then close the door. You can hear action the dishwasher doing something. Takes about 2-3 minutes, then stops. At this point I was able to select a wash cycle and start, close the door, and it started. Good luck
Feb 05, 2011 | Kenmore 24 in. 16039 Built-in Dishwasher
Hi I put some laundry in the washing machine (j845) and the door won't lock. It keeps saying error de although the door is very much closed.
de stands for door error.  electronics not sensing door open or shut.  could be bad control pcb or bad door switch ( solenoid ) or wiring harness...
Jul 08, 2010 | Washing Machines
I put some washing in my samsung J845 front loader the door will not lock before the washing can be done. my husband brought a new door latch due to the other one been burnt out and he put it back on the...
Just bang the door again until the error goes away. The door is not lined up and won't latch properly. At least that is what ours does. I usually slam the door on my machine.
Sep 29, 2009 | Samsung Washing Machines
Hotpoint Aquarius WF440 Washing m/c - Door Lock light
You have probably knocked of the connector or the catch (and on these it is very fragile as I have changed the catch 3 times on mine) is broken
Jan 22, 2009 | Hotpoint Aquarius WD63 Front Load...
Dishwashers Logo
238 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
