Question about Jacuzzi EH85-959 Real Whirlpool Bath 6 -White
NOTHING TURNS ON, PLUG IS OK SAID ELECTRICAN
IT WAS INSTALLED 8 MONTHS AGO IN A BRAND NEW HOUSE AND HAS NEVER WORKED. I PLUG IT IN AND THE MOTOR MAKES A SOUND BUT TURNS OFF AND NOTHING HAPPENS. I PLUGGED THE MOTOR IN DIRECT TO AN OUTLET(WITH WATER IN THE TUB) AND THE JETS CAME ON SO THE MOTOR IS OK. WHAT COULD BE ANOTHER PROBLEM. THE PLUMBER SAID IT SEEMS TO BE THE CONTOL MODULE MIGHT BE BAD
    Scholar:
  • 35 Answers
If you have plugged the tub into another outlet and the jets work fine, it is not a control module problem. The tub should be plugged into a gfci outlet. If it is, there may be a reset switch on the plug it is plugged into, or there may be a switch somewhere else in your bathroom that has the reset switch on it. You can buy a tester for about $3 or $4 that plugs into your outlet to test if it has power. Hope this helps.
Posted on Nov 19, 2009
Refrigerator was bought 5yrs ago(brand new)it worked perfectly until then....put it in storage 4 six months...when i moved it into my house i plugged it up...can hear it on but yet to get cold....left it...
Hi
Is your fridge compressor motor working and can you hear it turn on and off every hour or so. Not to be confused with the sound coming from the fan inside the fridge.
If the motor is working but neither the fridge or freezer compartment are getting cold, then there may have been a rupture during transport and gas has escaped.
Ash
Sep 02, 2011 | Hotpoint Refrigerators
I have a split unit that was installed about 8 months ago. It worked fien until the hot summer came. Suddenly it began to drip on the wooden floor beneath it. I checked the drain outside and it seemed to...
If your unit is only 8 months old, then it should still be under warranty! Suggest you check the drain line to make sure that nothing has decided to make it home.
I would check the level of your unit to make sure that there is a slight grade to the rear of the unit, but I hesitate to tell you to shim it.
Jul 26, 2011 | Mitsubishi MS-A09WA Split System Air...
We are unable to get power to one specific area of the house. I did reset the circuit breaker associated with that area. Nothing works. I do not have power in that area. This is a brand new unit in a brand...
You may have arc fault breakers in this area. Be sure to unplug all devices and try to reset breaker again. Some brush type motors will not work on arc fault breakers. If this is a brand new house then call the builder back and let him get the electrician back in.
Sep 10, 2010 | Cutler Hammer Electrical Supplies
Motor starts, but no electricity...NEW
Make sure the motor is turning the alternator--check the coupling device between them. Is there a circuit breaker on the alternator--reset it? Plug a lamp or something into a socket. If it works, the voltmeter may be in trouble. If still nothing, an inspection of the interior of the alternator is required. If the engine is off, there is no danger of getting shocked. Look for broken wiring anywhere.
Aug 20, 2009 | Electrical Supplies
98 Jeep Wrangler not getting air to the vents.
sounds to me like the foam gasket where the blowermotor housing is was not put in place right and so it is leaking to the heater outlet. need to redo the blower motor install. check also for any vacuum door hose routing being mis routed...
Aug 04, 2009 | Heating & Cooling
Seven months ago, a bosch alled at my house
you will always have this problem in city type of appltcations.there is too much of a flow differation.
Jul 13, 2009 | Bosch 2700ES Natural Gas AquaStar ...
Fan switch not work - Viking 3048SS brand new range hood
There is the on off switch and the blower control that controls the speed of the fan. It is more than likley the blower control that would need replaced.
There could also be a wire disconnected in the hood.
Aug 19, 2008 | Viking VWH3048 Kitchen Hood
Brand new Viking 3048SS hood - fan switch not working
think i would call viking back and ask for refund of inspection fee and go by the bad switch scenerio the electrician said new fan that would be considered flaws in workmanship in most states dont know where you are located but pretty much same anywhere most inspectors for these companies always try to blame problems off on installers hold your ground and make them fix it and refund that" inspection " fee I've been doing electrical work for several (20+) years it takes longer than 5 minutes to troubleshoot something like that good luck
Jacuzzi EH85-959 Real Whirlpool Bath 6 -White Logo
167 people viewed this question
Top Jacuzzi Home Experts
Mike
john h
armylifer
Level 1 Expert
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
