Question about LG WFT1071TP Top Load Washer
Washing machine keep filling in water non-stop
My top load washing machine will not stop drawing in water when I start it. It is an automatic washing machine 10 years old.
What is the name of the part that is likely to be faulty? Any site to view it's pictures?
  • LG Master
  • 5,568 Answers
There is a mixing valve that is normally where you attach the feed hoses.
In US domestic machines, this is an inexpensive ('cause it's a piece of marginal junk) that can be had from nearly any appliance shop and is generally easy to replace once the back panel is removed.
I'm not familiar with your LG machine so the statement above may be useless.
Posted on Jun 29, 2008
I have may tag wash model nu mav5920eww i just hooked it up tried reg wash it filled with water then would not continue to wash went to pause mode
Maytag & Whirlpool washer diagnostic - Fills with water then ...
? 3:03
Jul 11, 2013 - Uploaded by
Troubleshoot your trusty Maytag Washer that has some of the ...washer diagnostic - Fills with water then cycle stops - LAT8014AAE .... Not agitating Maytag 2 belts top load washers - Duration: 26:55. by theapplianceman 23,820 views. 26:55.Washing Machine Keeps Filling With Water and Will Not Agitate ...
Maytag top loading washing machine stopped working & filled with
Dec 02, 2015 | Maytag MAV5920E Top Load Washer
My Kenmore 500 top loading washing machine wont work right. sometimes it will work and other times it wont. I will put a load in it and sometimes when it hits the rinse cycle it seems like it gets stuck...
for the top loading washing machine mostly have drain pump, please check the filter of your drain pump, if clog your drain pump of some hair pins,cotton buds or coins or any small item,that the cause of water stuck,and it will long time draining or totally not running the drain pump.and its cause of stop of cycle of washing machine in rinse time or spin time,because after washing the pump must be on to remove water before start the next cycle.and the unit top load have drain pump you must be up the drain hose up to 90cm from floor lever to make the water lever is make in normal,the water automatically goes out by drain pump.
and for unbalance most of all top loader have problem in unbalance, the main reason is overload or the type of cloth you wash.
Nov 02, 2013 | Kenmore 24032\24036 Top Load Washer
Water stay in conditioner section of draw
Washing machine working fine conditioner being used but water always left in draw washing machine is cold fill only This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Mar 24, 2012 | Hotpoint Aquarius WMA42 Front Load Washer
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
Sep 15, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Kenmore top loading washing machine model 4021092, keeps filling
It is most likely siphoning out. Here is a link that will help explain it and how to correct the problem, let me know if this helps. Thanks
May 03, 2010 | Kenmore Washing Machines
Water over fills and machine does not start washing
put the washer on warn and start to fill,turn washer off,if it keeps filling then you need a new water valve,if it does not stop filling your water level,hose has come loose or the water level switch is bad-mike
Feb 09, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washing machine starts filling then wont go any
there are a lot of questions of a simular nature check the diaphram switch this controls how much water is taken in and wont progress until the switch says so what you dont say is if the machine keeps filling or stops filling and wont progress
Jan 16, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
If you open lid during operation, washer fills all the way to top
if you really want to see, simply stick an object (like flathead screwdriver) into the little hole that the lid presses into to click the switch, hold it there
Aug 29, 2009 | Kenmore Oasis HE 27082 Top Load Washer
My washer machine is filling up with water but will not stop
hi..the problem may be due to two reasons.
one is your washing machine will not be fully
automatic,it may be semi-automatic.In that case
the water will not stop automatically after reaching
its capacity.other problem may be there will be some
short in the wire in an fully automatic machine which
could have lead to this problem.
check it out.
thank u.. rate me..
Feb 05, 2009 | Frigidaire FWS833A Top Load Washer
LG WFT1071TP Top Load Washer Logo
189 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
