Question about Nikko STIRLING EUROHUNTER RIFLE SCOPE -- 30MM Power: 1.5-6X44 / Reticle: Tr
Adjustment hard to turn - Nikko STIRLING EUROHUNTER RIFLE SCOPE -- 30MM Power: 1.5-6X44 / Reticle: Tr
    President:
  • 2,702 Answers
The nikko stirling scope like most scopes has rubber "O" rings in them and they can go very tight on you at times all you can do is keep twisting it back and for till it frees off (it will in time) a splash of wd 40 mat free it off as well, but not very much if it gets inside the scope its finished
Posted on Nov 20, 2009
HONDA CRF 80 HARD TO FIND NEUTRAL
Hi, Anonymous, a proper clutch adjustment starts by squirting some silicone spray or Brake Kleen into the top of the rubber boot on the clutch cable and sliding it back exposing the cable adjuster. Loosen the jam nut and turn the adjusting screw all the way in. Loosen the jam nut on the clutch pack adjusting screw until light resistance is felt against the clutch rod then back the adjusting screw out 3/4 of a turn and tighten the jam nut. Go back to the clutch cable adjuster and back it out until there is 1/8" free play between the clutch lever and the bracket perch. This is correctly accomplished by pulling the clutch cable end outward with your right hand and pulling the clutch lever in with your left hand and modest pressure on both hands to eyeball the free play. Tighten cable adjuster jam nut and slide rubber boot back to its original position.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Hard to find Neutral
Why is my bike so hard to get into neutral
CRF80F CRF100F service manual repair 2004 2013 CRF80 CRF100 Download... $15
http://www.partsfish.com/page/oem-parts-for-honda
HONDA CRF80F Owner Manual
Dec 01, 2013 | 2005 Honda CRF 80 F
I just put a new carbuator on my troy tiller pony it is 23 years old ,still hard to start and will no idle very well.
There are many problems with small engines that can make them hard to start. The carburetor is one of them. Make certain that you have adjusted the new carburetor correctly. A good place to start is 1 1/2 to 2 turns counterclockwise from the closed position on the main fuel adjustment needle. Adjust in or out to best performance when engine is running. Some carburetors also have a fuel adjustment needle for the idle mixture. Start off with 1 to 1/2 turns counterclockwise from closed and adjust in or out to best idle performance. Other potential problems include bad spark plug, ignition system (points and condenser in your unit?) and a defective intake and/or exhaust valve.
Oct 29, 2013 | Troy-Bilt Garden
Kitchenaid stand mixer 5SSWH 325 watts. How do I adjust the bowl height? Beater is too far from bottom of bowl. Thanks! Cas
There is a screw at the bottom of the motor head (flat head) you usually can't see it because of the top rim of the mixing bowl. hard to see and hard to reach, it may also be hard to turn due to "gunk" from mixing stuff (egg butter flour sugar) turn the screw counter clockwise to lower the motor head clockwise to raise it, you may also have the wrong size beater, it is not an uncommon problem, if you are the original owner and you have the original beater it should fix your problem with the adjusting screw, however I am not clear as to your model a 5SSWH would actually be a K5SSWH, which stands for kitchenaid 5 quart solid state white mixer, if this is your model number and you have the correct beater size then the adjusting screw will work to lower the head down, adjust it down using the stir or slowest speed just untill you can hear the beater "Ding" against the bottom of the bowl, then back it off a quarter turn to adjust properly. Hope this helps, let us know
Apr 17, 2013 | KitchenAid K5SS Heavy Duty Commercial...
It is very hard to turn the adjustable ring that switches from drill to hammer grill
Hi my 925 has had same problem right out the box it must be an allignment thing a find a tap with the old hammer sorts it out
Sep 15, 2012 | Dewalt DC925 Cordless Drill
I have a New Home xr-vii sewing machine, the balance wheel is very hard to turn. The repair shop I took it to said the clutch needed to be adjusted. Got it back 8 months later and it still has the s
if the sewing machine repair shop knew the machine needed a clutch
adjustment, then why didn't they fix it. or if they said they did & it's not
fixed, I'd call them & ask them why the machine is still doing the same
as it did?
May 03, 2012 | Sewing Machines
1996 camry le 6 cylinder. cannot get ignition key to turn to start car. gear is in park and have tried adjusting steering wheel
Hi the steering lock could be causing you the problem try turning the steering wheel hard left whilst turning the key and do the same hard right.
it may be hard to turn but you should find once you have moved it slightly it will unlock allowing you to turn the key so dont adjust the steering wheel turn it to the right as if your trying to turn to the right and if this dont let the key turn turn the wheel to the left it only needs to move slightly to allow the steering lock to free the key,
doing the above should solve you problem
give me a shout back if you have any further problems ok
Aug 15, 2010 | 1996 Toyota Camry
How do i adjust the carburator ? I put a carburator on this car , and ,like an idiot, messed around with the adjusting screws, to keep it running. Now I don't know how to adjust it back.I have a haynes...
Turn the front idle screws in until they bottom out gently. DON'T turn them in hard or you will damage the tapered ends. From there turn them back out 1 and 1/2 turns. That should start the car and you can adjust from there. If you do then do it in 1/4 turns and do both screw at tne same time. Hope this helps.
May 19, 2010 | 1987 Chevrolet Nova
Factory suspension settings
Spring preload FR
To increase the spring preload and
thereby harden the suspension, turn
the adjusting bolt on each fork leg in direction
a. To decrease the spring preload
and thereby soften the
suspension, turn the adjusting bolt on
each fork leg in direction b
NOTE: _
Align the appropriate groove on the adjusting
mechanism with the top of the
front fork cap bolt.
_
CI-10E
Rebound damping force
To increase the rebound damping
force and thereby harden the rebound
damping, turn the adjusting screw on
each fork leg in direction a. To decrease
the rebound damping force and
thereby soften the rebound damping,
turn the adjusting screw on each fork
leg in direction b.
CI-02E
Compression damping force
To increase the compression damping
force and thereby harden the compression
on each fork leg in direction a. To decrease
the compression damping force
and thereby soften the compression
each fork leg in direction b.
CI-02E
1. Current setting
2. Front fork cap bolt
Setting
Minimum (soft) 8
Standard 6
Maximum (hard) 1
1. Rebound damping force adjusting screw
Minimum (soft) 26 clicks in direction b*
Standard 13 clicks in direction b*
Maximum (hard) 1 click in direction b*
* With the adjusting screw fully turned in direction a
1. Compression damping force adjusting screw
Minimum (soft) 20 clicks in direction b*
_
Although the total number of clicks of a
damping force adjusting mechanism
may not exactly match the above specifications
due to small differences in
production, the actual number of clicks
always represents the entire adjusting
range. To obtain a precise adjustment,
it would be advisable to check the number
of clicks of each damping force adjusting
mechanism and to modify the
specifications as necessary
CI-10E
Rebound damping force RR
damping, turn the adjusting screw in direction
a. To decrease the rebound
damping force and thereby soften the
rebound damping, turn the adjusting
screw in direction b.
CI-14E
in direction a. To decrease the compression
soften the compression damping, turn
the adjusting screw in direction b.
CI-14E
Setting
Minimum (soft) 1
Standard 4
Maximum (hard) 9
Whole process where need to turn toward "a" means clockwise and "b" counterclockwise. From Yamaha service manual. Hope this is good enough info to help you out. Good?
May 03, 2010 | 2002 Yamaha YZF-R1
Adjusting mtd carb. i there a set turns for the adjustment screws
Basic screw adjustments to start with are 3/4 of a turn from the farthest "in" setting. Don't tighten down on the screws too hard, turn down just enough intil they stop, then turn out from there. After engine starts, you can fine tune the idle speed and then the high speed crews.
Feb 18, 2010 | Mtd Products Yard Machines 158CC Tiller
Beater is too low in mixing bowl. How do you adjust the height of the mixing head. There is a screw in the pivot, but it does not turn. Does this adjust the height?
The adjustment screw did work for me but I adjusted using the dough mixer instead of Flat Head mixer as specified (only-realized after reading the manual ;o).
After readjusting using the correct flat head, everything is happy again.
- manual, I don't need a stinking manual !!! ;o)
Jan 05, 2008 | KitchenAid K45SS Classic Stand Mixer
Nikko STIRLING EUROHUNTER RIFLE SCOPE -- 30MM Power: 1.5-6X44 / Reticle: Tr Logo
156 people viewed this question
Top Nikko Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a Nikko Optic Expert? Answer questions, earn points and help others
