Question about Panasonic CT-36SX12 36" TV
I can't find a 6.3 125v fuse
Could i use a 6.3 250v fuse instead?
If you look on the board that the fuse sits on you will see printed it states 6amp 125 Volt / 3amp 250Volt. This means that you can use either one. I think that is why the fuse states E.6.3 125Volt... I think it means either 6 amp (125 Volt) or 3 amp (250 volt). I noticed on the back of a fuse package that I bought that it stated these were interchangable so I put two and two together.
Posted on May 08, 2009
  • 589 Answers
Radio Shack has pretty much any fuse you need (although you may have to buy a pack of 5 of them).
Do NOT use a higher amperage rating that required. It has that rating for a reason.
If the fault occurs again, and you had a higher rated fuse in it, it will have too much resistance and possibly damage another component.
Posted on Jan 11, 2008
I have a tv that doesnt turn on I opened it I noticed the fuse was out it uses a 6.3 amp 125 v fuse went to radio shack to try to buy it they didnt have it so I baught 5amp 125 v fuse I tryed it 2 times but they blew if i get the correct amount will it work or if these blew it mean the right one will blow
Posted on Sep 10, 2009
  • 2,427 Answers
A LIGHTER AMPERAGE FUSE WILL BURN OUT,, A HIGHER AMP FUSE MAY DESTROY YOUR EQUIPTMENT,,, Use Radio shack as Nitrotrike Suggested.. Get the exact same fuse,, however in the event you cant, get another fuse with similar vales and a fuse holder, then just wire the fuse holder to the contacts on the holder with the fuse you are attempting to replace,,
BTW something always causes the fuse to blow,, if you dont know what has caused it chances are it will happen again if you dont get that fixed..
Posted on Jan 15, 2008
Same fuse problem.
250v i tried it'll blow as soon as you press power.
special shops or computer repair places might have one.
http://www.nexttronics.com/catalog/sony/9/990998001.htm
this place has one for a sony vaio
but it's five bucks and it's too small for my house stereo...but i'll
fix that.
but if you are going to go cheap use a 6amp and keep the voltage 125. it could make the lights dimmer or speakers weaker so i wouldn't recommend ever using the wrong fuse...especially on a tv or camera
Posted on Oct 24, 2008
IKnow does not know what he is talking about. Using a higher amperage fuse can damage your device.
Posted on Sep 21, 2008
    New Friend:
Can I use a 6amp 125 volt on a Sony tv
Posted on Dec 12, 2015
  • 68 Answers
No, you may use a higher amperage (6.3a or higher) fuse (not lower) but the voltage 125v has to be the same
3 Suggested Answers
SOURCE: 6.3 slow-blow fuse
This worked for me. My set has a little panel around the power cord with a single screw; the real trick is fitting my hand in there to change the fuse. I guess they make the opening for monkeys or small children or something.
  • 1694 Answers
SOURCE: 6.3a slow-blow 125v fuse
It will work, the amp rating is most important, 125v / 250v does
not matter.......note: if you blow the fuse again, the TV will
need service.................T.
Posted on Dec 08, 2007
On my onkyo ht-r592 receiver on the 3 glass tube fuses 1 8A125V, 2 10A125V is it OK to use 250V instead of 125V
NNNNNOOOOOOO!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! USE THE EXACT ONE OR BURN UP YOUR TV!!!
May 17, 2015 | Onkyo Audio Players & Recorders
How do you test a fuse
How do you test a fuse?
• for RCA FL231
(400ma, 125V) +40V Supply Power Supply/Deflection PCB
OEM RCA FUSE RCA259213 FL231 400MA 125V 3960400000 ...
• for
FL221 (1.25, 125V) -13V Supply Power Supply/Deflection PCB
FL251 (1.25A, 125V) +13V Supply Power Supply/Deflection PCB
FP400 (6A, 125V) AC Input Mains Input Doubler PCB
FP602 (1A, 250V) DVD Power Supply Mains Input Doubler PCB
here are some links to guide you:
http://www.electronicrepairguide.com/how-to-test-a-fuse.html
http://www.dinosaurelectronics.com/Test_Fuse.htm
hope these helps,
thanks for choosing fixya for assistance!
Aug 25, 2012 | RCA HD52W59 HDTV Projection Television
I have a pair of Technics SL-1200MK@ Turntables and I blew the fuses on the curcuit boards. I'm having trouble finding a discontinued fuse. If you know anyone selling them, please post some links for...
Any decent electrical shop should have those fuses. They tend to come in 20mm and 30mm lengths. You will need to know which. Also there are fast blow and slow blow fuses. If you have the originals and you can see the remains of a coil then you want slow blow. Otherwise just replace them with fast ones. The 1.2 amp fuse can be replaced with a 250 volt fuse.
So you want a 250ma 250v fuse.
and a 1.2A 250v fuse.
Oct 07, 2017 | Audio Players & Recorders
Can't find 2A 125v fuse replacement for on-off will 250v be OK?
There is no difference between a 125v and 250v fuse. The most important thing is the 2Amp. This fuse is probably the line fuse and could be the only trouble and may have blow with a line surge. Make sure the 2A you use is a Fast Blow Type. If it does blow again you most likely have a internal power supply failure.
Apr 19, 2009 | Sharp Aquos LC-20B2U 20 in. LCD Television
Pelco Spectra III PTZ camera wrong fuse?
It is replaceable, as long as no harm has come to the rest of the camera.
Mar 14, 2009 | Pelco SD53C22 Smw 0 Spectra III Se White...
Hi, If the fuse physically fits into your unit then it will work. However- - - WARNING! Although 6.3 amps on a 250v fuse will allow the current to flow it will not afford you the circuit protection you require for a 125v circuit. If the circuit develops a fault then there is a danger that you burn out the circuit before the fuse. As you have already blown one fuse I would suggest tracking down the fault before you do any thing else.
The Scrivener.
Oct 12, 2017 | Pioneer VSX-D458 Receiver
Dec 08, 2007 | Panasonic CT-36SX12 36" TV
6.3 slow-blow fuse
Important parameter is 6.3 amp slow-blow,voltage rating = 125v
or 250v OK, No Worries.............................T,
Panasonic CT-36SX12 36" TV Logo
6,815 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
