Question about Samsung HCN4727W 47" Rear Projection Television
No Picture I was told the picture came on and then went down, now when you hit the power button the red light flashes several times but it will not turn on....someone told me it might be the board causing the trouble..I hear a click like the power wants to come on but no chime and no component 1 on the screen indicating power.
  • ameder Apr 30, 2008
    same here.
  • Anonymous Jun 15, 2008
    I have the same problem. TV was on then suddenly went blank. Will not turn on with power button pushed. Tried plugging into a different plug but same thing happened. The only light that is on is the "timer" red light that stays on even when I pull the plug. Help!
IS THERE A TEST FOR THIS?
Posted on Jun 17, 2008
  • 4 Answers
See if STK392-110 or similar are good. 2 big chip with cooler
Posted on May 14, 2008
It started 3 days ago the picture started getting darker and darker everyday then last night after turning the tv off which was off for several hours I turned it back on and a few min later there was a...
REPLACE THE LAMP IT IS LOCATED IN THE BACK OF THE TV THERE ARE INSTRUCTIONS IN THE OWNERS MANUAL FOR REPLACEMENT IT IS CONSIDERED CUSTOMER REPLACEABLE ITEM.
PART NUMBER 915B403001 Lamp (180W)
Dec 16, 2010 | Mitsubishi WD-65736 Television
The picture will go black and the sound will go out. At the same time, the green power inicator will flash. Then the picture and sound will come back on for several seconds and then it will go out again....
My TV had the same problem. I called Sony yesterday and they told me to reset the TV. I did so yesterday, and it seemed to work. Here is the transcript with instructions:
Please turn ON the TV. While holding down the RESET button on the Remote control, press the POWER button on the TV. The TV will turn itself OFF, then back ON again. Release the RESET button.The TV will go thru the initial setup, and should work normal.
Aug 02, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Powershot A540 flash does not work
Hi. I had the same problem. I called Canon and they told me to reset the camera, and it worked. The camera is back to normal. To reset, hit the "menu" button and then scroll over to the tab with the tools icon. Scroll down until you see "Reset All". Hit "set" then highlight OK and hit "set" again. It will say "busy" if it was reset correctly. I had to do it twice for it to work, but it seems to be working fine now. Hope that helps.
Jun 07, 2009 | Canon PowerShot A540 Digital Camera
Plasma Hyundai 42'' TV ,NO SOUND OR PICTURE
most times then not it's the capacitors on your power board that blew there for not supplying the tv with enough power if you open it up and check the capacitors it should be leaking some kind of liquid or the tops have bubbled up. its an easy fix cost>>2 dollars each
May 21, 2009 | Televison & Video
Panasonic PT-53TWD63, TV will not turn on, Red power light blinks
It is most deffinately a convergence chip issue. The die for no reason. They can be bought online for around $10 dollars and anyone with experience with soldering can replace them pretty easily. I have done it.
Feb 03, 2009 | Panasonic PT-53TWD63 53" Rear Projection...
Panasonic PT50LC14 No Sound or Picture
unplug it, and let it set for a minute or 2, then try it again...if it does it again hit the power button again to turn it back on...also once the the tv turns on make sure you reset the counter for the bulb..that will also cause problems...to reset the counter press the (-) volume on the tv while holding down the (-) press spilt,pip on the reomte...the lamp will reset and the indicator will go out
Jan 20, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Sony wega 42inch
Power surge has damaged power supply, have serviced
Apr 22, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
No picture but has sound
My LG TV
switch on no picture but short period of sound then nothing
Jan 20, 2008 | Sony KP-51HW40 51" Rear Projection...
Samsung HCN4727W 47" Rear Projection Television Logo
102 people viewed this question
Jerry Greenberg
Jerry Greenberg
