Question about Canon PowerShot A540 Digital Camera
The lens cover won't open. Camera comes on fine, but lens cover won't open up. Looks like it's been bent or pushed out of track. Can it be fixed? Thanks, Steve
t00nz
  • 4738 Answers
SOURCE: My lens cover can't open and close completely.
Try this as a last resort. This blog post outlines repair procedures for a stuck lens covers. An A400 is used as an example. But for the A620, you might want to extend your zoom all the way out before removing the camera's batteries. Also you'll be applying the ring loosening rubbing alcohol along the barrel's perimeter instead of the front as shown in the procedures.:
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Good luck, and remember do this only as a very last resort. Oh, and please post how it went should you decide to try the repair.
Posted on Nov 24, 2007
  • 1257 Answers
SOURCE: Lens cover only partially opens
There is a very very easy way to fix this problem..
This can happen if...
1.) If the battery dies when the camera lens is open (and you close it manually, or sometimes, even if you dont.)
2.) If you used a AC adapter with too much voltage or not enough. (this can happen even if you used the correct voltage, refrain from using AC adapters at all)
... all together its ethier a voltage or camera lens problem...
TIPS:
1.)NEVER PUSH THE LENS IN AFTER CAMERA DIES, BUY A NEW BATTERY IMMEDIATLY AND TURN IT BACK ON, CLOSING THE LENS!
2.)NEVER USE AN AC ADAPTER, USE A RECHARGEABLE BATTERY OR A REGULAR BATTERY!
..to fix this...
Do as i say..
1.) Remove battery
2.) Remove front plate (screw driver may be needed)
3.) Check all gears, make sure they are correctly fitted in place)
4.) Move the gear manually to make the lens come out.
5.) keep it out, put the front plate back together.
6.) reinsert the battery, turn it on.
or...
1.) Remove the battery.
2.) Wait about 6-8 hours.
3.) Reinsert the battery.
or...
2.) Try hooking it up through AC adapter, put correct voltage.
3.) Try turning it on.
4.) Remove AC adapter, reinsert battery.
5.) Turn it on.
Hopefully all this information helped,
Posted on Jul 10, 2008
SOURCE: Automatic lens cover will not open.
please try resetting your camera to the factory settings..the procedure to reset is found in the instruction manual as well as in the cd that came along with your device. thank you for using fix ya
Posted on May 26, 2009
t00nz
  • 4738 Answers
SOURCE: lens cover won't fully open when camera is turned
This blog post outlines repair procedures for stuck lens covers. A couple of Canon cameras are given as examples. Hope it helps.
Posted on Jan 16, 2010
t00nz
  • 4738 Answers
SOURCE: The lens cover doesn't open fully Canon A630
Sure it is, and repair isn't that hard. See this link for tips on repair of sticky automatic lens covers. Recommend reading the reader's comments section of the link for additional tips. Especially pay attention to the vacuum cleaner tip.
Posted on Feb 08, 2010
Shutters on the lens won't fully open
Stuck automatic lens covers are fairly. But usually it's very easy to fix, without even opening the camera. See this link for troubleshooting steps for this problem.
Dec 14, 2012 | Kodak EasyShare C633 Digital Camera
Lens Cover will not open
Make sure that your device battery was fully charge, or make sure that the unit has a power on it..
thank you
Jun 05, 2008 | Sony Handycam DCR-DVD203 DVD Camcorder
My shutter won't fire using 18-55 lens, either on Manual, P or Auto mode. It is set to AF. But when lens is set to MF, shutter fires. I tried switching to another lens and shutter is perfectly fine.
I could be that your lens isn't focusing. If the Auto focus can't find something to focus on the shutter won't fire. If you are shooting in low light sometimes it has trouble try shooting something that is well lit. also your auto focus point may be somewhere other than the center. there is a button on the top of your camera that looks like this [ ][ ] [ ] [ ]
More or less that will switch where your focus point is. If you look in the view finder and see a red dot when you push on the shutter button that is your focus point. push the above button until the red dot is in the centre. that may fix your problem.
Jul 26, 2011 | Canon EOS 450D Digital Camera with 18-55...
I turn my dmc-fh27 camera and the lens won't come out. it is trying to move but it will not budge and the screen says "System Error (Zoom)".
Warning: This is only a last resort if you no longer have a warranty.
I used a variety of different methods, but here's what worked for my camera. Apparently the lens was just off the track.
1. Turn on the camera, and smack the back against the palm of your hand to get the lens to come out.
2.Hold the lens out until the "error screen" comes up.
3. Take the camera with the lens facing towards you, and use your thumbs to push on the lens.
4. Push firmly until the lens "clicks".
5. Turn off camera, then on again.
6. Hopefully cry tears of joy that you fixed it.
Jun 12, 2011 | Panasonic Lumix DMC-LZ2 Digital Camera
CoolPix L 18 Problem
It probably can be fixed if you can get to them. Most cameras' lens assemblies are replaced as a unit when they go bad, it's just not cost effective to spend the time to tediously take them apart, repair the problem, and reassemble. You sound pretty mechanically inclined to have fixed the gears, so I would say you could probably pull this off if you try. Good luck, it's not what most people should try at home!
Mar 26, 2010 | Nikon COOLPIX L18 Digital Camera
I dropped my Powershot SD 500 and now the lens cover does not cover the lens. It leaves a gap when closed and does not retract all the way when open. It seems that the resolution on some of my photos is...
A bit of gentile persuasion may be necessary.
Have you tried to push the lens into the camera body?
I believe that the camera has lost track of where the lens is in it's range of travel.
use your finger and see if a small amount of pressure will put the lens back ito position.
In the end, this is not a new camera, if it is dead a better replacement can be had for as little as 120 $US
Jul 27, 2009 | Canon PowerShot SD550 / IXUS 750 Digital...
The lens won't open/close and it beeps three times instead
the camera was last on the batteries were either extremely low, or they died and lens could have been kinda off track a little when it happened so it got stuck that way….Put in new batteries and If you lay the camera flat facing up at you and you look down and lens looks a little crooked….Push it slightly in the direction it needs to go to get back on track and when you hear the pop noise it’s fixed. Then when you turn the camera on if it stays on attempt to zoom in and out and the lens will then get back on track…and then TUrn it off and the lens should go back in
Jul 06, 2009 | Samsung Digimax S600 Digital Camera
Lens cover will not full open up help needed
Mine wont open at all. You can hear the lens trying to push it's way out but the cover doesnt move.
Dec 27, 2007 | Olympus Stylus 800 / ? 800 Digital Camera
Lens cover stuck open
I recently had the lens cover stick partly open.  There are 4 segments to the lens cover, and if we number them from the top, number 2 was not closing.
I gently flicked the segments a few times, in case there was a grain of dirt causing it to stick (although the camera has never been in a dirty or dusty environment).  This caused the lens cover to close fully each time, but now it would not open fully, segment 1 would not open, although it would stay open if moved by finger.
Anyway, after a bit of fiddling, I got it working properly again.  The way that the lens cover appears to work is that only segments 2 and 3 are pushed open or shut by springs, segments 1 and 4 are pushed open and shut by tiny tabs that catch on segments 2 and 3.  If the segments somehow get pushed out of alignment, then they either bind (causing the cover not to shut), or they get disconnected (causing the cover not to open fully.
Now I am not sure exactly what I did to get the mechanism form the stuck open state to the not opening state, but from there the way to fix it is to:
-With the lens open...
- Hold segment 2 in the closed position with firm finger pressure (which will tend to push it towards the lens).
- Push segment 1 towards the open position until you can see that it has cleared the edge of segment 2.
- Lift segment 2 way from the lens so that it will rub past segment 1 as you...
- Move segment 1 to the open position.
- Repeat if necessary to get the technique right.
I can't provide any guarantees, and I am not about to repeat the excercise on my camera, but it was a lot easier than sending it off for repair.
Dec 12, 2007 | Panasonic Lumix DMC-TZ3 Digital Camera
Canon PowerShot A540 Digital Camera Logo
29 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
