Question about Hitachi CML154XW (Beige) 15" LCD Monitor
My hitachi 15.4 inch laptop monitor is not working, i can read and see everything but its very dark so what is the problem and how can i read it clearly?
    President:
  • 1,149 Answers
Hi:
You should first try to increase the screen brightness by holding down your function key and hitting the screen brightness key. If you have tried that, borrow a computer monitor, and connect it up to the VGA output connector on your laptop. If you toggle to an external monitor, by holding the function key, then the monitor key, you should be able to tell if the video is bright on the external monitor. If it is ok, then your laptop has either a bad LCD inverter, or backlight bulb.
Posted on Nov 19, 2009
I own a Hitachi 10CFR Table Saw. My question is: Can I load a Dado Stack onto the Arbor of this table saw to create a 3/4 dado cut? I've read everything from "Yes" to "Absolutely Not"...
After doing some research, I found that hitachi only recommends up to a 1/2 dado for this machine with most of the users agreeing that it probably does not have the stability or power to run a 3/4 inch safely. Meaning you probably can run the 3/4 but at you own risk.
Mar 03, 2011 | Hitachi C10FR 10" Job-Site Table Saw 15...
The laser stopped working on Hitachi 12'dual compund mitr saw,are there batteries that can be replaced or does the unit need to go to a tech? The laser only worked for a month and the saw is only 3 months...
The laser modules in saws are usually powered by induction from the spinning saw blade. Since your saw is only three months old hopefully you either registered it with Hitachi when you bought it or you still have your receipt as this type of failure would be covered under warranty. Call Hitachi, they may send the part to you if you are comfortable with doing the repair or they will tell you where the nearest Authorized Service Center is for warranty work. Hitachi's number is: 800-706-7337 or 770-925-1774.
Jan 27, 2011 | Hitachi C12FDH 15 Amp 12Inch Dual Bevel...
I have model LCM-19v1 SL monitor and I need to know what type of power cord I need for it. and possible a picture
hi,
these are the specs for you monitor
Upgrade your desktop display in size and style with this Westinghouse LCM-19v1 19-inch LCD monitor! Its advanced HD-Grade flat panel technology lets you enjoy crisp, vibrant images while working on spreadsheets, writing email, watching movies, playing games and surfing the web.
Some key features include 1280 x 1024 native resolution, 600:1 contrast ratio, and a fast 21 ms response time. Its thin, sleek and sophisticated design will complement any office. Get yours today!
By law, California shipments of this product are subject to an $8.00
Electronic Waste Recycling Fee
Features/Specifications:
  • Westinghouse LCM-19v1 19-Inch TFT LCD Flat Panel Monitor
  • General Features:
  • Silver Cabinet color
  • 19" diagonal screen size
  • Native/Optimum Resolution: 1280 x 1024 16.7 million colors
  • Compatible Modes: VGA, SVGA, XGA, SXGA
  • Contrast Ratio: 600:1
  • Brightness (Nits): 300 cd/m2
  • Response Time: 21 ms
  • Viewing Angle: 170 degree Horizontal, 170 degree Vertical
  • Built-in stereo speakers
  • Connectors: 3.5 mm stereo mini-jack. VGA-in, DC-in
  • DC Input: 19V - 3.1A
  • EnergyStar compliant
  • Regulatory Approvals:
  • FCC
  • UL
Package Includes:
  • Westinghouse LCM-19v1 19-inch TFT LCD Flat Panel Monitor
  • Power Supply (100-24V 50~60Hz)
  • Power Cord
  • Stand
  • VGA cable
  • Audio cable
  • User's Manual
Additional Information:
  • Requirements:
  • Available power outlet
  • VGA adapter
  • Notes:
  • LCD displays may have cosmetic imperfections that appear as small bright or dark spots. This is common to all LCD displays used in products by all vendor and is not specific to any vendor or brand. Below are the acceptable amounts of "dot defects" for LCD displays that we sell:
  • 17-Inch to 18-Inch:
  • Total Defects: 8
  • Bright or Dark Dots (random): 4
  • Bright or Dark Dots (2 adjacent): 2
  • Bright or Dark Dots (3 adjacent): 0
  • Minimum distance between defects: 15 mm (bright to bright dots); 5 mm (dark to dark dots
for the adapter, already inserted the picture of it
Hope this will help... Your response is very much appreciated....
Jan 20, 2011 | Computers & Internet
Colors are very dark
you can download a utility like rivatuner to adjust the videocards gamma up to the brightness your looking for if the monitor will not adjust brighter with the controls on the front of your monitor. rivatuner can be downloaded free (just google or yahoo "rivatuner downlaod".
To be honest with you, I would replace this with a 17 inch LCD monitor, which you can found at tigerdirect.com for 89 bucks.
If you do have issues with this older monitor, it would be less expensive to replace it than fix it..
May 18, 2009 | LG Studioworks 57I 15" CRT Monitor
Screen went black
sounds like your monitor is shot or one of the connections in the back hope this helps regards Jim
Apr 20, 2009 | Computers & Internet
Screen went black
I don't know. I've never actually replaced parts in a monitor. If the bulb is expensive, it might be best to buy a new monitor. They're cheap nowadays. Or you can check if there's warranty on the monitor and it can probably be fixed for free.
Apr 20, 2009 | Acer X221WSD Monitor
Dark screen on me laptop
the LCD backlight has failed, you will need to replace the LCD assy (about $200)
Jan 18, 2009 | Dell Inspiron 5150 Notebook
Dark screen
click on start>control pannal>adobe gamma> set ur
Dell inspiron 5150 dark screen, faint image in background
If it showed a pinkish tint on the screen before it went out it could be the backlite. If you can see a faint screen when you turn the room lights out it chuld be the inverter. Inverters are cheap ... a used one for around $8 on ebay. Try that first. Make sure that you buy the EXACT model that is presently in your laptop.
Jan 14, 2009 | Dell Inspiron 5150 Notebook
Hitachi CML154XW (Beige) 15" LCD Monitor Logo
67 people viewed this question
Top Hitachi Computers & Internet Experts
AJMAL KHAN
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
