Question about SATO CL408e Thermal Printer
Sensor error on sato cl408e
Sensor error what can we do so that we can print
  • SATO Master
  • 19,396 Answers
Hi.
Double check that the ribbon is correctly placed on printer.
If you are printing on to thermal paper, ensure you have set the
DSW2-1 to ON to configure the printer for direct thermal print-
ing.
Check that the ribbon is not sticking to the label. This can hap-
pen if the darkness setting is too high. Try lowering darkness settings.
Ensure that the ribbon spindle is rotating freely on the spindle.
If it is not an error message will appear.
Ensure that you are using original ribbons. Ribbons have a mark at the back of label, compatible ribbons from third party may cause problems.
Regards.
Posted on Nov 19, 2009
Sato cl408e - printing over perforations. I tried turning the Pitch(all the way to the right) and Offset(all the way to the left), and this helped a little, but still not right. Because of this, when the...
Reset printer sensor threshold setting.
Turn on printer whilst holding down line key untill printer beeps.
Use feed key to step to Gap in display.
Load label plus backing under sensor and not volts reading.
remove labels and place backing only under sensor and note volts reading.
use following formula
High reading + Low reading / 0.5 = Value to use
e.g 2.8 + 1.4 / 0.5 = 2.1.
use result to change value of input using line key once set press feed key to set.
To change label start position use the pitch menu.
Jun 02, 2011 | SATO CL408e Thermal Printer
Hi, Sato CL408e, it starts printing between the labels. The feed is off by about 0.5cm. Any idea on how I can adgust that?
1) Try to calibrate the printer.
Else
do factory reset ( Press LINE and FEED At same time and switch on the printer.
Else
Change the potentiometer offset (Pitch,print) settings in the front panel.
Rgds
Mohan
Jan 21, 2011 | SATO CL408e Thermal Printer
We have a Sato 480e that prints shipping tickets. It will not print now because it says "Paper End" when there is plenty of paper. I've cleaned the rollers, and changed the paper roll. What else can I try?
check the alignment of the sensor.
If continuous, make sure dip switches are set to continuous.
There are particular settings for a die sut, and continuous label
Dec 11, 2008 | SATO CL408e Thermal Printer
Printer Error(Sato Cl 408 e)
PROBLEMA EN AJUSTAR EL CORTE DE LA ETIQUETA, CUANDO LA IMPRESORA SENSA LA ETIQUETA, ESTA QUE CORRIDA HACIA LA PARTE DE ATRAS DEL CABEZAL HACIENDO NECESARIO UN FEED PARA PODER CORTAR LA ETIQUETA
Jul 05, 2008 | SATO CL408e Thermal Printer
Pare parts in India for SATO CL408e printer
can better you to visit SATO website and get the information you wanted
Dec 27, 2007 | SATO CL408e Thermal Printer
Printer problem
check baud rate on NIC card (pull out NIC), against COM settings on PC. they must match. 9600 usually works
May 22, 2007 | SATO CL408e Thermal Printer
SATO CL408e Thermal Printer Logo
631 people viewed this question
Top SATO Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
mukhtar21 shaikh
mukhtar21 shaikh
Are you a SATO Office Equipment and Supply Expert? Answer questions, earn points and help others
