Question about BUSlink MP3-SK512 (512 MB) MP3 Player
Flashing hello im having the same problem as linda and nath. had the trouble fixed under warntey but after an hour or so of playing, it happened again.tried the solutions posted; but cant fix. HELP. Wade
0 characters
1 Points
I listen to the music for 1 hour. I turn the lock switch off. The next day the Go gear MP3 has completely discharged. I re charge it on the pc. The screen reads 'Fully charged'. The same thing...
There are two things possible.
1) You have defective re chargeable batteries in your GoGear.
2) There is some short circuit because of which the re chargeable cells are discharging.
Either way you should get the system changed. If you want to confirm if its the battery defect or GoGear. Charge the system fully and play music continuously. If the Go Gear plays for about 4 hours with out break---- its not the battery but the charging system.
Mar 14, 2011 | Philips GoGear SA3020/37 MP3 Player
Im charging up via the computer and car adaptor. It says it takes ten hours but the way i am doing it will it take longer? It keeps flashing red and the green light comes on occasionally. I have tried...
I found a manual in Google by putting in "N13275 manual" It's the first entry.
Check it and see if it's your model.
It says it has to be turned on while charging.
To turn it on (or off) press and hold the play button.
Leave it charging for a day and see if it works.
Jan 28, 2011 | MP3 & Digital Media Players
What softwear needed to convert video that can be played in phillips go gear ipod
IM guessing u want to transfer videos from disk to YOUR Philips SA3025/37 should be able to play mp4,3gp,amr total video converter.that should fix it..or search google for MPGAV TO 3GP CONVERTER OR /MPGAV TO AMR CONVERTER..thynks
Nov 17, 2010 | Philips SA3025/37 Flash MP3 Player
Ipod shuffle
This is not an an common problem, as this Wikipedia article confirms. (scroll down to "Blinking Light Problem")
Go to the Apple website here and check which generation of shuffle you have before trying the fix. In fact, read all the small print before going ahead.
Good luck & let me know how you get on.
Jan 10, 2008 | Apple iPod shuffle MP3 Player
Sasung K3 Im using mix cd's
play on your computer in media player make a new playlist with all of your songs and then download as a complete playlist to your mp3
Dec 28, 2007 | Samsung YP-K3 MP3 Player
Sylvania smpk2021
well if u got the touch screen sylvania mp3 player (4gb) it tells u in the instruction manual to turn on the mp3 player go to settings and then system and then go to touch calibration ur suppose to do that thing with the crosses 3 times... like it shows u three arrows that u have to touch with the touch screen pen... your suppose to do that before using the mp3 player at all.... but whut im having troubles with is how to put games on to it......?????.......
Dec 16, 2007 | iLO MP3 Player
Trouble with my rca
i think its because you have the lock or people call it hold is on u have ti swich it to off and if its not that im sorry
Aug 14, 2007 | RCA TH102 (256MB) MP3 Player
No brand-mp3 mp4 player
well this has never happened to me but mine did freeze o all you have t do (this might work) when it is on try holding down the power button for about 20-30 sec and it restarts it. thTS WHAT HAPPENED FOR MINE WHEN IT FROZE FOR THIS PROBLEM IM NOT SURE IF IT WILL WORK but give it a try
May 23, 2007 | SanDisk Sansa e250 MP3 Player
Green and Orange Lights Making me go Crazy!!!!
download the apple ipod shuffle reset utility from the apple web will flash your ipod and fix the problem
Aug 30, 2006 | Apple iPod shuffle MP3 Player
Player wont switch on
I have the same problem in that nothing happens when I press down the play button on the base unit. However, when I press play on the remote the unit turns on. Not sure if this solution applies to your problem...
Aug 03, 2006 | iRiver iHP-120 MP3 Player
BUSlink MP3-SK512 (512 MB) MP3 Player Logo
14 people viewed this question
Top BUSlink MP3 & Digital Media Players Experts
Are you a BUSlink MP3 and Digital Media Player Expert? Answer questions, earn points and help others
