Question about Music
Gibson SG Standard I have too mutch feedback wen i play laud... wen i push the guitar i have a feedback wen i leave the string... can i adjust someting
  • Music Master
  • 5,138 Answers
Adjust your Amp controls ,if you have trible and bass controls on guitar then Buy contact cleaner ,clean controls if this does not fix it then have controls replaced. Do Not Use WD40 Call Mats Electronics for cleaner 1-800-628-1118
Posted on Nov 19, 2009
Gibson serial number check
Gibson 1961-1969 Custom SG reissues since 1997
YYRRRM
Y is the production year
RRR(R) indicates the guitar's place in production for that year.
M is the model being reissued
Reissue model codes:
1= SG Custom and Special
2= SG Standard
3= 1963 Firebird 1
4= 1964 Firebird III
5= 1965 Firebird V & VII
8= 1968 Les Paul Custom
So I think 737582 would mean the guitar was the 758th Custom SG Standard built in 1973. See this... http://www.gibson.com/en-us/Support/SerialNumberSearch/Default.aspx
Jul 15, 2014 | Gibson Custom SG Standard Guitar Electric
Date of manufacture ?
our guitar was made at the
Nashville Plant, TN, USA
September 15th, 2004
Production Number: 6
May 14, 2014 | Gibson Custom SG Standard Guitar Electric
The D string on my new J-45 standard sounds unmusical , as if there are no rich overtones . I can tune the string with my electronic tuner but it never sounds musical. I think it has Gibson Premium...
Hi. Your guitar may not be intonated properly. You might want to try to level and balance the height and strings all throughout the neck. The level at the rear half (close to the soundhole) can be slightly higher than the front half (near the headstock). This can be done be adjusting the truss rod, nut and/or saddle.
Note: You may want to get a guitar luthier to do the trussrod, nut and saddle adjustments as these are very delicate procedures.
May 13, 2011 | Gibson Guitar Gibson SAG MB11 Masterbuilt...
Information and pricing on a gibson sg guitar serial # 029960375
Try here: http://www.jedistar.com/jedistar_vintage_guitar_dating_gibson.htm
Jun 18, 2010 | Gibson SG Standard Electric Guitar
I have a 1966, 1969 Gibson Guitar. Serial # 83272012. How much is it worth? What model? Confirm year? etc.?
According to Gibson's website, your guitar is a 1983 model year guitar made on the 272nd day, in the Kalamazoo plant. If what you have here is a pic of the actual guitar, it is a Gibson SG. How much it's worth is determined by the condition it is in, the rarity of the model, and much more than can be said without a close inspection.
Here is a link to the Gibson website:
Jun 04, 2010 | Gibson SG Standard Electric Guitar with...
Gibson Les Paul wont stay in tune
That's the problem; you're using light gauge guitar strings. Chances are that if you are not used to playing strings that light, you're fretting hand will hit the strings with more force than is neccesary to fret them, thereby forcing them out of tune. You can solve this problem by adding more winds around the string post (three or more winds should do it), or you can switch to a heavier gauge of string.
If they're true locking tuners, they should have a notch on the back of the gear housing that you turn with a nickel to engage the locking mechanism once tuning has been established.
Also; check the intonation of the guitar itself on an electronic tuner. If it tunes right but sounds out of tune when played, this is an intonation issue, and can be solved by adjusting a small set screw that moves the individual saddle back and forth in the tune-o-matic style bridge. You can check this by tuning the string to the correct note, then playing the same string at the 12th fret and checking it against your tuner. If it rings in true, you're fine, if it comes up flat or sharp, every note on the fretboard is going to be off by that much, and you'll have to adjust accordingly (turn the screw to the right to add length and lower a sharp note, turn the screw to the left to subtract length and raise a flat note, if I remember right).
Hope that helps.
May 12, 2009 | Gibson Music
Which string used for epiphone gibson lea paul special II guitar
This is really a personal choice as long as the strings are made for an electric guitar there are hundreds of different kinds, it mostly has to do with the thickness of the strings and how the thinner the string the easier it is to manulipulate, you should go to a good music store and tell them what type of music you play and they will give you some choices.
Mar 23, 2009 | Epiphone Les Paul 100 Electric Guitar
Old yamaha electric guitar
Santana's had quite a few guitars, take your pick:
1972 - Gibson Les Paul / Gibson SG Special with Humbuckers / Gibson L-6S
1975 - Gibson SG Special with P90 pickup (Woodstock Festival)
1976 - Yamaha SG 175B / Gibson SG Special with 3 Open Coils
1982 - Paul Reed Smith (PRS) Custom
1988 - PRS Santana II with PRS Santana III nickel-plated pickups and .009-.042 D'Addario strings
Nov 10, 2008 | Yamaha Electric Guitar
Music Logo
29 people viewed this question
Top Music Experts
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
