I have a lenmarx x5150 printer and have no manual with instructions.How do I use it and replace ink?
    Scholar:
  • 83 Answers
  • Press the "Power" button to turn on your Lexmark
  • Step 2 Open the top portion of the printer to reveal the ink cartridges.
  • Step 3 Lift the gray plastic cover on the left. Remove the empty black ink cartridge. Next, lift the purple plastic cover on the right and remove the empty color ink cartridge.
  • Step 4 Remove the new black ink refill cartridge from its packaging. Tear the protective strip of paper from the cartridge's sensor. Now, remove the new color ink refill cartridge from its packaging and tear the protective strip of paper from the cartridge's sensor.
  • Step 5 Turn the cartridges so that you can read the label. This is the way the cartridges should face when being put into the printer.
  • Step 6 Slide the black cartridge into the slot on the left side and push it down. Slide the color cartridge into the slot on the right side and push down.
  • Step 7 Push the gray plastic cover down over the cartridge until it clicks closed. Push the purple plastic cover down over the cartridge until it clicks closed.
  • Step 8 Close the top portion of the printer. Your new ink cartridges are installed, and your printer is ready to use.
Posted on Nov 19, 2009
My lexmark printer doesn't regognize ink cartridge
Hello Chris,
Please visit the link provided below :
http://www.lexmark.com/publications/pdfs/x5150/eng/ug.pdf
Download the printer manual from the above link.
Please visit the page 38 in pdf manual to troubleshoot.
Aug 25, 2011 | Lexmark X5150 All-In-One InkJet Printer
I can't figure out how to replace the ink cartridge. How do you remove the old ink cartridge and put in a new one?
Here's an article in the Lexmark website that will guide you on how to replace the ink cartridges on your Lexmark X5150 printer. Just click on this link: http://bit.ly/bKZ15F. Follow the instructions carefully. By the way, in some cases, the ink cartridge carrier doesn't move in the loading position even when the printer is on when you lift the scanner unit open. If that happens, unplug the printer from the power source. With the scanner unit open, hold the solid white tape you see in the printer. Slowly slide the cartridge carrier to the center for easy access. Replace the cartridges. Close the cover, close the scanner unit. Plug the printer back to the power source. Hope this helps. If you need more assistance, just place a comment so I can get back to it.
Apr 19, 2010 | Lexmark X5150 All-In-One InkJet Printer
Can you give me instructions in how to use it and how to replace the ink?
Download the manual from here, if you don't already have one. Read it! It will answer your questions.
http://www.devicemanuals.com/guide/Printers/Lexmark/All-In-One-Multifunction-Lexmark-X5150-User%27s-TWpjM05EWT.html
Nov 19, 2009 | Lexmark X5150 All-In-One InkJet Printer
Hardware error o504
It shows color cartridge is missing because either the cartridge is not well placed or it is not there.
When you try to run the Clean option from the Ink Cartridge menu, the following message may appear: Hardware Error 0504.
To resolve this issue:
  1. Take both cartridges out of the printer.
  2. Switch off the printer using the power button.
  3. Disconnect the power cable from the back of the Lexmark X5150.
  4. Leave the power cable disconnected for 30 seconds.
  5. Reconnect the power cable and switch the printer on again.
  6. Reinstall the cartridges. (Follow the instructions on the LCD screen or refer to the following document: How to Install the Cartridges in the Lexmark X5150)
Jan 11, 2009 | Lexmark X5150 All-In-One InkJet Printer
Lexmark x4550
the lexmark ink station mechanism wont allow you to use a differnt ink..try to use lexmark ink or else printer will go bad.
Nov 27, 2008 | Lexmark X5150 All-In-One InkJet Printer
Lexmark x5150
Your ink cartridges have dried out. Replace the black to confirm this prognostication and, if black works, replace color also. If you are into refilling ink cartridges youself try soaking the black one in 91% rubbing alcohol in a small ziploc type bag for several days. when the alcohol becomes ink colored, remove the cartridge from the baggie, dry it with tissue paper, reinstall it in the printer and up to 3 times run a clean the nozzles page until it prints a solid black line. Repeat with the color cartridge. Good luck.
qwester1
Apr 02, 2008 | Lexmark X5150 All-In-One InkJet Printer
60 people viewed this question
jasbo
jasbo
