Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Remotes have poor range
The remotes on all 3 of my new openers work poor at best. I can sit in the vehicle in front of the door with no reception of the signal by the receiver located on the operator. I took the remote cover off and noticed an adjustable part on top of the board labeled "C2" which may be a capacitor to only change frequency. Is there a way to increase the range by soldering a piece of wire to the transmitting IC's transmit pin or something to that effect?
  • Anonymous Apr 21, 2009
    Same problem. 3 garage doors and 8 openers. Range on all is terrible.
  • marty metzger May 11, 2010
    What age or medel you talking about. Try new batteries. Are they 390 or 315 mz
    President:
  • 3,197 Answers
Here is some information that may help you.
Limited range of your remote controls could be related to radio frequency interference that comes from something in your home or in the surrounding environment. Certain electrical devices can radiate interference; this could be almost anything that is plugged into an electrical outlet.
Please keep in mind that the device can be brand new, or can be an item that has been in use for quite a while. Also, the item may continue to function properly as far as you are able to tell. The only problem with the item may be that it has started to broadcast the interference, with no other symptoms noted.
Some devices are more likely to generate interference than others. This includes TV cable, cable amplifiers, surge protectors, fluorescent lights, battery charging devices (power tools, golf carts, etc.), anything that utilizes a timer (sprinkler systems, lights, alarm systems, etc.), and a myriad of others. If the problem seems sporadic, we can safely assume that the device responsible for the interference is only being operated during these times. Again, please keep in mind that the age of the device does not determine if it is capable of broadcasting unwanted interference. Any electrical device can be the source of the problem.
The first step is replacing the battery in your remote. If the range on your remote does not improve, remove the wall control wires from the overhead unit. If the range does not improve you will likely need to replace the remote control. After replacing the remote, or if you have other remotes programmed in to the opener, and the range problem still exists, please proceed to the Power Down test.
Multiple garage doors:
If you have two garage door units and one is working just fine, you will need to start by unplugging the good unit. This will help determine if the unit with no range starts to function properly. If the range comes back to the bad unit then you will need to replace the logic board on the unit that was unplugged as it is emitting an RF signal that is over powering the other garage door opener. If the range doesn not improve after the “good” unit has been unplugged, replace the batteries and try programming some additional remotes to determine if the existing remotes are the issue. If the extra remotes do not have any range then you would need to replace the receiver logic board in the “bad” unit.
Power Down test:
To isolate potential sources of interference, turn the circuit breaker off to the garage and plug the garage door opener into an extension cord from another room. If the range improves, then the interference is coming from a device in the garage. If no improvement is seen follow the same procedure, this time turning off the circuit breakers to your home, with the exception of the garage and test the remote controls. If improvement is noted, turn the circuit breakers back on, one by one, until the range problem resurfaces. This will allow you to narrow down what room the problem device is in. You will have to go from there to isolate it further, by unplugging and re-plugging the items in that room.
Posted on Dec 29, 2009
Neither my remotes nor keypad will close the door. Only the wall mounted interior pad works.
Check the two antenna wires on the garage opener itself. Loose (or missing) wires means no reception. If the wires are missing, add 2 feet of speaker wires, or even old "lamp cord" wires, just hanging down from the opener will regain reception. (Ps... I am assuming you already tried putting new batteries in both the remote and the keypad).
Oct 16, 2015 | Building Materials
How do I fix
(Repeat answer):
Digidoor remote
"Another reason is problems with the radio frequency of the remote control system used, some older systems use frequencies that are liable to interference from various sources such as police and fire department radios and military communications. The effects of this interference are many for example, the garage door may open and close on its own or the operating range of your remote control may become so poor you cannot open or close the door with your remote control even whilst standing next to it."
source
Jul 29, 2013 | Audio Players & Recorders
I have 3 garage door openers. Two of them have week signals. Only works on very short range (does not work after you get more than 3 ft. away), no long range signal period. I have replaced the logic...
because the remotes are new I recommend that you bring them back to sears and have them adjust the transmit gains to increase the transmssion .wattage on the remotes. that should do the trick
May 09, 2011 | Kitchen Ranges
We have Craftsman 139.53684 gargage door opener with 2 remotes. Both remotes programmed and respond. Issue is after programming the 2 remotes, the homelink in the vehicles no longer respond. Can you not...
You must have an older vehicle or the homelink has reverted to an earlier technology and you will have exactly the situation you describe. You will just have to use the remotes that came with the opener.
Nov 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
Our remotes do not work when the garage door is closed, but they do work to shut the garage door when it is open. help
There are two possibilities here. One is the remotes batteries are weak and need to be replaced. The other is the receiver is going bad. If new batteries don't increase the range of the remotes then you will need to replace the logic board.
Aug 07, 2009 | Sears Craftsman LiftMaster Chamberlain...
Poor remote control range
have you changed the battery inside the remote yet?
Apr 26, 2017 | Chamberlain Powerdrive PD422D 1/2 HP...
2 different openers stopped working by remote at the same time
Both the older genie and a newer chamberlain (3-4 yrs old) both run on 390Mhz frequency. sounds like you will have to change your receivers on both operators (365LM 315Mhz) then get 3 button remote so you can program both doors on one remote.
Jan 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears garage door remotes
Tilt antenna different direction. Call Liftmaster for advice
Oct 02, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
1,488 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
