Question about Brother FAX-2920 Plain Paper Laser
When I send faxes the person receiving the fax is complaining that there is a solid black line appearing on the fax
  • 75 Answers
Hi there
it seems like there is some dirt or correction fluid on the scanner glass ,flip open the cover where the documents feed in you will see a glass ,clean this glass with a damp soft cloth this should solve the problem
Posted on Nov 19, 2009
I Cannot Receive a Fax - the pages are blank
A second line isn't needed, this wouldn't cause blank pages to be printed. This could cause fax's not to be received if the line is in use. There could be 2 causes of blank fax's. Either the obvious which is the person sending the fax is faxing the document the wrong way up. Or the fax board on your copier has a malfunction. Because of the copier's age, this seems likely, although i hope not. hope this helps.
May 07, 2013 | Sharp AR-M355N Copier
Why our fax sending and receiving solid black
Its a problem with scaner unit. Reports are being printed out, and do not pass trough scaner, because of thath report is Ok.
If the fax is still under warranty, go to warranty provider service.
Next time dont buy "kids toy" for fax machine. Try laser Canon Fax L140.
May 20, 2010 | Canon FAX JX200 Fax / copier Plain Paper...
2" black horizontal line appears on paper when I fax, print,
Check the wondow where the paper passes to be scanned. You will probably find some debris or white out stuck on the glass. That is usually the cause of vertical lines on sent faxes.
Sep 17, 2009 | Office Equipment & Supplies
Solid black line appearing on right hand margin approx 1.8cms wide , how can i sort this please
please specify model no. of the machine & black line comes when u receive faxes or when u copy ? please let me know then i'll be able to provide solution. Thanks
Aug 24, 2009 | Brother Office Equipment & Supplies
When sending a fax, black lines runs thru entire fax, what to do?
Clean off the glass where the paper runs through.You have some dirt or other substance that is blocking the light for copying or faxing.
Apr 20, 2009 | Canon PIXMA MX310 All-In-One Printer
When sending a fax on our Brother Fax-4100 the person on receiving end of the fax says it comes across totally black What is the problem??
If you make a copie. on your fax.
That is the same quality that you are sending over the phone line.
If the copie is total black
lift the document feeder see if there is anything on your optical glass.
But my experience tells me that the lamp has gone out also know en as the scanner asm.
let us know what hapens
Apr 08, 2009 | Brother IntelliFAX 4100 Laser Fax
Sending one printed fax, yet reciever gets additional 3 blank sheets.
Open up the document feeder and look for a trapped down or sluggish switch
Oct 25, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
Receivers complain that the fax is light/unreadable
More than likely (since the problem is with sending and copying only) the mirrors inside the fax machine need cleaning. However, depending on what type of fax machine this is, this could be a pretty involved job. If you are pretty comfortable with taking covers off, you might try it, but if its a pretty expensive fax machine, I would call a professional.
hope this helps!!!
chad
Oct 08, 2008 | Sharp UX 510 Plain Paper Thermal transfer...
We have a black line when sending or receiving a fax
Try to make a copy on your fax. If the print out comes out ok, the person whis is sending has the problem and not you.
Jul 09, 2008 | Panasonic Office Equipment & Supplies
Brother FAX-2920 Plain Paper Laser Logo
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
