Question about Epson Stylus C86 InkJet Printer
WHEN I TRY AND CHANGE THE CARTRIDGES THE UNIT REMAINS HIDDEN AWAY ON THE RIGHT SO I CANNOT ACCESS THE UNIT PLEASE ADVISE IF YOU CAN - THANK YOU
    Scholar:
  • 83 Answers
Power supply should be turn ON and some moment should be there when you open the FLAP of the Printer or either manually drag and replace the catridges.
Posted on Nov 19, 2009
    Sergeant:
  • 309 Answers
You should have installed some management software on your PC when you installed the printer. Start that software and find the option "Change cartridges" or something similar. This should move the carriage out of its garage and give you access. If you didn't install the software, check the manual section on changing the cartridge. There are usually some sequence of button presses you can do on the control panel that will also move the carriage out of the garage.
How do I get to the ink cartridge to change itin a canon MX 300
You must have power applied to the unit when you change ink cartridges. The cartridge holder should move to the left side of the carriage when you lift the cover to gain access to the ink cartridges.
Dec 21, 2014 | Canon Office Equipment & Supplies
Changing ink cartridge
This should happen automatically when you open the door to access the cartridges for changing. If they don't, power off the unit. Reach in and drag the head carriage out firmly with your fingers. It will resist a lot at first but once it gets moving it's a breeze. Change the cartridges, close the door, and turn it on. The carriage will recalibrate it's position and it will be ready to go.
Aug 26, 2009 | Canon Office Equipment & Supplies
Using the same cartridges for the HL-4070CDW, I refilled the black yellow cyan and magenta cartridges. when I put them all back into the printer, the RED toner life end comes on saying that cyan, magenta,...
There's a window on each end of the cartridges and light shines thru to show when they're empty, your refill toner may not be the right density. If you put a small piece of electrical tape over the windows on the cartridge, the error will go away, but you have to watch print quality to change or add toner.
Aug 11, 2009 | Brother HL-4070CDW Printer
Alignment problem- says to remove tape from cartridges, not sure what tape or what cartridges.
Did you recently install new ink cartridges?
See below, or go here and enter your model # , choose tech support and search "change print cartridge" for detailed instructions with pictures.
Overview
This article provides general instructions on how to change the cartridges on Lexmark Inkjet and All-In-One printers.
Procedure
1 Ensure the All-In-One printer is powered on. No image.
2 Lift the scanner unit or access door (per right-hand image).
The cartridge holder will move to the center of the Inkjet or All-In-One.
3 Press down on the cartridge carrier latch to raise the carrier lid.
4 Remove the used cartridge. NOTE: If you are removing both cartridges, repeat the preceding two steps for the second cartridge. No image.
5 Remove the protective tape from the back and bottom of the new cartridge(s).
WARNING! Do not touch the gold contact area on the back or the metal nozzles on the bottom of the cartridges.
6a Insert the new cartridges into their respective carriers. The image at right illustrates inserting the color cartridge.
6b The image at right illustrates inserting the black cartridge.
7 Close the carrier lids so that they remain closed. See image above in Step 3. No image.
8 Close the access door or scanner unit, taking care to keep your hands out from underneath the scanner unit as it is being closed. No image.
9 On some All-In-One units, the control panel display will prompt you to load paper and print an alignment page. NOTE: The scanner unit must be closed before you can start a new scan, print, copy, or fax job. No image.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
How to Change the Cartridges on Lexmark Inkjet and All-In-One Printers ID: ENUS32244 Overview
Procedure
NOTE: These instructions are general, and your specific Inkjet or All-In-One may appear different than the pictures below; however, the steps are the same.
Step Action Image 1 Ensure the All-In-One printer is powered on. No image. 2 Lift the scanner unit or access door (per right-hand image).
pattlnk_3232007_1123-01%20open%20scanner%20unit.jpg 3 Press down on the cartridge carrier latch to raise the carrier lid. pattlnk_1202009_209-hw_cartridge_carrier_lids_p.gif 4 Remove the used cartridge. NOTE: If you are removing both cartridges, repeat the preceding two steps for the second cartridge. No image. 5 Remove the protective tape from the back and bottom of the new cartridge(s).
pattlnk_1202009_2013-remove_tape.gif 6a Insert the new cartridges into their respective carriers. The image at right illustrates inserting the color cartridge. pattlnk_1202009_2024-color_install.gif 6b The image at right illustrates inserting the black cartridge. pattlnk_1202009_2016-black_install.gif 7 Close the carrier lids so that they remain closed. See image above in Step 3. No image. 8 Close the access door or scanner unit, taking care to keep your hands out from underneath the scanner unit as it is being closed. No image. 9 On some All-In-One units, the control panel display will prompt you to load paper and print an alignment page. NOTE: The scanner unit must be closed before you can start a new scan, print, copy, or fax job. No image. Still Need Help? If you require additional assistance, please contact Lexmark Technical Support. NOTE: When calling for support, you will need the machine/model type and serial number (SN) of your printer.
Please call from near the computer and printer in case the technician asks you to perform a task on one or both of these devices.
Jul 28, 2009 | Lexmark X5470 All-In-One InkJet Printer
How do i change ink cartridge
open the front panel just lift it u can see the catridges inside that
remove those by just pushing them downwards you can see the instructions of how to remove inside itself in a corner of your printer
try it and buy new catridge and replaceit
or else refil it with the proper advicer
thank you
Apr 22, 2009 | Canon Pixma MP500 All-In-One InkJet...
Changing printer cartridges
please you try a changing a had new and check the your prblem.
and printer use is manual defold.
Dec 21, 2008 | Epson STYLUS CX5900 Printer
Hidden network hawking hi-grain
should be in utilities window in hawking wireless utility under more settings
May 17, 2008 | Hawking Hi-Gain Wireless-G (HWU8DD)
Ink cartridge
The access door for the cartridges in on the front right corner of the printer. Put your hand on the side of the printer, (Just around the corner), you will feel a spot to put your fingers to pull down the access door. It is well hidden, what where they thinking? From there it is really easy to just pull down the printer doors and change the ink cartridges.
Good luck to all!
Tracey
Apr 28, 2008 | Brother Multi-Function Center MFC-240C...
Invlaid region code
Sounds like you are trying to play a DVD of a different region to that of the player.
Worldwide region codes, sumarised:
1 - US / Canada
2 - Europe
3 - Asia
4 - Australia
5 - Africa
6 - China
You can change the region code of the DVDR520H to any region or use region 0, which makes the unit multi-region to play DVDs from any region.
  1. Go into the main menu
  2. Highlight the exit button
  3. Type 2960
    This should give you access to a hidden menu form where you can change the region code.
Feb 20, 2008 | Philips DVDR520H DVD Player/HDD
Epson Stylus C86 InkJet Printer Logo
70 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
