Question about Canon Pixma iP2600 Photo InkJet Printer
I have only used my printer 7 times and now no matter what i do it pulls the paper in crooked and bent
    Scholar:
  • 83 Answers
  • Step 1 Inspect the paper trays to make sure they are not overloaded. To determine if this is the problem, do a test print with only one piece of paper loaded in the paper tray. (If this turns out to be the problem, keep the paper tray half-full in the future.)
  • Step 2 Check that the type of paper being used falls within the printer manufacturer's recommendations. For example, paper designed for ink-jet printers doesn't necessarily work well in laser printers. High-quality, bonded paper will cause paper jams in some printers; look for bonded paper that is "laser and ink-jet compatible."
  • Step 3 If someone has recently printed labels on this printer, check to see if a label has come unglued from a sheet and become stuck inside the printer.
  • Step 4 Check the gears and rollers for stuck shreds of torn paper from previous jams. Turn off the printer before you attempt to remove the bits of paper.
  • Step 5 If you have a laser printer, inspect the printer's paper rollers. They should be smooth but not shiny. Rollers that are cracked or glazed are a frequent cause of paper jams and should be replaced by a technician.
  • Step 6 If you have a laser printer, try cleaning the printer's paper rollers with a lint-free cloth and isopropyl alcohol (available at electronics shops or drugstores).
  • Step 7 Try changing the toner or ink cartridge.
  • Step 8 If you hear a clinking sound during printing, your printer probably has a broken gear and needs to be serviced by a technician.
Posted on Nov 19, 2009
Prints crooked
The paper is not being pulled into the printer straight.
There are small sliders that rest next to the paper in the loading tray, you are required to push these so that they slide over and rest directly next to the stack of paper. This will guide the paper into the printer straight so that the paper does not get pulled in crooked.
Feb 28, 2011 | HP DeskJet 5550 InkJet Printer
The paper is being pulled in crooked every time
You might want to try using rubbing alcohol with a soft pad on the rollers near the ink cartridges...I've found that the ink can make the rollers 'sticky' and cause the paper to be pulled to one side. Hope this works for you!
Dec 09, 2010 | Canon MX300 Office All-In-One Printer
Hp deskjet 5550 is grabing the paper but paper prints crooked
You may have a paper jam (small paper cut) in the feeder ytry to check it and see if you can clean it...or you may bent the feeder...open it and let me know
Sep 13, 2009 | Office Equipment & Supplies
Copies crooked
make sure back stop and side guides are against all edges of the paper in the drawers, ADF edge guides..same thing. does this happen out of all drawers? if so there is a registration roller (long and usually hard rubber) that has to be pressed evenly across to pull paper straight, usually has springs bent around both ends. If it is not drawers or ADF has to be in the path from drawer but before Fuser (hot area) best bet is reg roller.
Aug 04, 2009 | Konica Minolta bizhub C250 All-In-One...
My Epson CX5800F is pulling the paper into the printer crooked
I had the same exact problem. Get a piece of fine grit sand paper run it though face up a coupe of times. It works!!! My printer now is great. A friend told me this because a printer repair person told her.
Jun 12, 2009 | Epson Stylus CX5800F All-In-One InkJet...
Paper feeder is not straight
Push the copy button with the cover up and no paper on the glass. Is the light bar straight up and down, or is it crooked? I can't imagine how paper could go thru the machine crooked, but check it out if you can. If the paper is too thin, it may not be getting grabbed by the rollers right.
Mar 04, 2009 | Brother MFC 7420 All-In-One Laser Printer
Paper ALWAYS feed crooked.
Defective rollers or you have something stuck in a corner...look carefully or try cleaning the rollers with robbing alchool (remouves grease)
Feb 27, 2009 | Dell 924 All-in-One InkJet Printer
Every time I go to make a copy the printer pulls the paper in crooked and it jams
One of the biggest reasons for the paper feeding in crooked is that the platen (what the actual paper feeds across to be typed on) gets really slick. All in all that platen and anything that handles the paper needs to be cleaned with isopropyl alcohol. It will restore the texture to all the parts that actually handle the paper going through. That is all there is to that problem. God bless.
Jan 12, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Samsung SCX-4200 manual feed prints crooked
You need to change the pick up rollers for your printer if it pulling the paper unevenly... but first check to see that the paper size adjuster on the tray i self is set to your paper likeness.....adjust to the correct paper size if not...
Please don't forget to vote!
Cheers!
Nov 13, 2008 | Samsung SCX 4200 All-In-One Laser Printer
Printer will not allow paper to flow freely; it jams on the left side and prints crooked.
first cancel all the prints going on and switch off and on the printer and keep the paper slowly
Aug 07, 2008 | Canon PIXMA MX310 All-In-One Printer
Canon Pixma iP2600 Photo InkJet Printer Logo
177 people viewed this question
old marine
old marine
