Question about Canon Office Equipment & Supplies
We have a Cannon Copier imageRUNNER 5065 and it keeps popping up a message saying SHUT DOWN E000202-0101.
  • 161 Answers
Scanner home position error. the scanning lamp does not move or dirty sensor.
Posted on Nov 22, 2009
What is the username and password for web access to the cannon ir5065 copier
you might have to create your own account if you already own one of these cannon ir 5065 copiers and want some support
hope this helps
May 11, 2011 | Computers & Internet
I need a hard disk drive for a cannon 2200 imagerunner the copier keeps showing a error message
If you have a Service Contract with the local CANON office, call them, and get them to make a service-call to fix your printer.
Jul 17, 2010 | Canon (6981A002AA) for imagerunner 2200,...
ImageRUNNER 5570 is printing slow. If I print the same on our 5065 it is about 10 times as fast.
1. Recommend to change the driver of the printer on local.Connect the printer through cable port USB. The Cable must not be long.
2. Change driver a device on local from computer without network
Nov 02, 2009 | Canon imageRUNNER 5570 Copier
Which one is better to buy IR 5075 or IR 5065
The all above models are same with minor change for speed
You need model as your daily output requirement
All models are heavy duty.
you can select any one for upto 10,000 print or copy per day or for 20,000 & up print/copy select ir 5075
Jun 15, 2009 | Canon imageRUNNER 5000 Copier
Copier ha a message that says replace toner drum.
It means that the internal drum unit is full of waste toner and that the drum is worn out too. The people at cannon made the drum unit to last when the waste toner internal compartment is full.
When you buy a new drum the instructions are in the box and very easy to install.
hope it helps
Mar 24, 2009 | Canon ImageRUNNER 1670F Copier
Canon imageRUNNER C2058 color network printer board-B1 only. Upon power up the display screen indicates "Wait...".
The printer Board B1: you must shut it down by hitting the Options button and then selecting Function >Shut down > Shut down sytem>OK. Then power the machine off with the main switch. If the Customer has not been shutting off the machine properly and you get the please wait message you might try reloading system software first before replacing the hard drive.
Or = remove and reseat the printer board, if that doesn't work then you'll have to reformat the HDD unit and reload system software from a laptop. If the problem remains, the printer board may need to be replaced.
The Color Network Printer Board -B1 has a shut down function. It is for preventing corruption of the HDD. Be sure to turn off the main power switch after performing shutdown.
To properly shut down the Color Network Printer Board -B1:
1. Press the Option key on the control panel if the copier is in copier mode.
2. Make sure that the LCD reads Idle.
3. Select Functions on the LCD.
4. Select Shut Down from the Functions screen.
5. Select Shut Down System from the Shut Down screen.
6. The message 'It is now safe to power off the system' appears on the screen.
7. Power off the main power switch located on the lower right side of the copier.
* Note- After powering off the copier, wait at least five seconds before powering the copier back on.
Jan 25, 2009 | Canon imageRUNNER C2058 Led Printer
Canon Imagerunner 500i finisher problem
between the copier and finisher there have a atuacter to atuact the door sensor, therefor just push finisher perfect contact the machine will resolve your problem.
Dec 10, 2008 | Canon imageRUNNER 5000 Copier
The Cannon Imagepass L1 cannot connect to Imagerunner
set service mode->copier->option->int-face->img-cont = 1
Jul 25, 2008 | Canon imageRUNNER 5000 Copier
964 people viewed this question
old marine
old marine
