Question about SE Electronics SE2200A Professional Microphone
Can you tell me the plug wiring mike end - SE Electronics SE2200A Professional Microphone
    President:
  • 1,138 Answers
It should be standard balanced XLR. The wiring is 1= ground/shield, 2=hot(+ve), 3=cold (-ve). Do not bridge any of the pins especially not 1 and 3 if you are using phantom power with this microphone. Let me know if this helps please.
Posted on Nov 20, 2009
Why, all of a sudden, does it sound as though its misfiring?
  1. Most likely a loose spark plug wire or a vacuum hose is off.
  2. look over the engine while running listen for hiss to find vac leak and look for sparks around plugs and distributor
  3. turn off
  4. plug vac back in and check both ends of the plug wires so there snug
Hope this helps Mike
Mar 12, 2016 | 1994 Buick LeSabre
SSR-EP75 Ingersoll Rand SERIAL # F15525U95286 320 CFM i CONTINUE TO ADD OIL GOES OUT ON HIGH AIREND TEMP. SOMEONE TOLD ME THERE WAS AN ADJUSTMENT FOR THIS. CAN YOU TELL ME WHAT TO...
Mike, an EP 75 Should not use more than 3 to 5 parts per million of oil. Your oil issue sounds like you have a separator that needs replacing or a plugged scavenge line. The separator is located in the oil tank. the scavenge line and orifice come from the bottom of the separator filter to and Thur the oil tank lid. then to the air end. In this line approx. 1ft from the lid should be the orifice. make sure its clean. your high air end temp can be from several different problems. 1- low oil level from separator or scavenge line plugged. 2- A plugged oil cooler. Dirt and debris pushed against the cooler by the the cooling fan. This needs to be cleaned using a pressure washer. Wash in the opposite direction of air flow. Be careful with the pressure washer. You can damage the cooler. Low oil level and dirty coolers are the most common problems when getting high air end discharge temp shutdowns. However you could also have a bad thermal valve located where the three cooler lines come together. you will have to remove one line and 4 bolts. inside is the thermal element. You may also have a bad HAT switch (high air end temperature). It is located in the end of the air end and simply unscrews. I do not know of any adjustment.
Feb 12, 2011 | Air Tools & Compressors
How to fix feedback in radio or squeal
Hi, my name is John. Sounds like you have a wire off the mic. plug and its touching another wire. Try another mike, or take and see if it works on PA. To take the end apart off the mike, remove the tiny screws, should be three(3), careful not to misplace them. Slide the end back, and see if any wires are off or touching another wire, if so, re solder, then put the screws back in place and your done. May have to relocate the unit, to get rid of squeal......hope this was very helpful....
Aug 27, 2010 | Cobra Radio Communications
My coils are freezing . i have replaced the heating elament and timer and its still freezing.
What timer did you replace ? Your refrig uses a control board , not a timer .
Pull the refrig out and remove the 8 " x 10 " panel . Behind this panel , is the main control board . Unplug the refrig . Remove the BLUE plug from the board , with 3 larger wires going to it . Looking at the blue plug , the sequence will be wire1,wire2,space,wire3 . Get a short piece of insulated wire , and strip about 1/4 inch from each end . Insert 1 end into wire2 , and the other into wire3 . Plug the refrig back in . After about 3 min , look in the freezer , at the bottom , behind the crisper , look for a red glow . If no red glow , unplug the refrig , and reassemble the plug and cover . This no glow , indicates a defrost heater WR51X10055 not working or the defrost thermostat ( pt. number WR50X10068 ) not working . To access these parts , you will have to remove the inside rear wall of the freezer . The heater , is at the bottom of the coils , held on with 2 screws , and the thermostat , is the 1 " cylinder , with a blue and pink wire going to it , clipped on the top left of the coils .
If you do get a red glow , then the # 4 thermistor is bad . This tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp and when to cycle off / on .
May 09, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Wont turn on
Is the Mike an electret? Does it need a battery to work. If so try changing it or making sure it's inserted correctly. Does the on off switch feel sloppy and loose? If so it could need looking at. Also the wire for mics tends to take a beating. Check the connections on the plug end and make sure it's all connected OK. Don't forget a fracture can take place halfway along the cable in which case you'll need a multimeter. It will tell you if it's fractured but not exactly where the fracture is. If the mike gets it's voltage from the mixer or amplifier have you switched the phantom power on? If there's a plug and socket on the end of the mic also check that for fractures and again use the multimeter to measure continuity from one end to the other. Usually the braid is OK but check all wires anyway.
Apr 10, 2010 | LeadSinger LS-3000 Consumer Microphone
Trying to wire a 56 for a tristar 120. any ideas?
I think you are talking roadking 56, take the end of mike apart, you will need a 4 pin mike end,solder,steady hand,or small clip vise like I use,it takes just a little dab of solder for each wire,don,t over do it,trim each mike wire one eight inch back,slide the mike end on the cord,do not forget the plastic insulator,then solder the white (audio) to pin 1. then solder the shield and red together to pin 2,then solder the black (receive) wire to pin 3, then solder the blue (transmit) to pin 4. Then put it back together. ..hope this helps..
Mar 28, 2010 | Radio Communications
Excessive line crackling noise
The service manual is at www.akg.com/mediendatenbank2/psfile/datei/19/C4194055d1fa264a7.pdf. You will have to replace the wiring that goes to the cartridge through the gooseneck.
May 25, 2009 | AKG C419L Professional Microphone
SE Electronics SE2200A Professional Microphone Logo
117 people viewed this question
Top SE Electronics Audio Players & Recorders Experts
Michial Gueffroy
Willem.
Willem.
Are you a SE Electronics Audio Player and Recorder Expert? Answer questions, earn points and help others
