Question about GE 24 in. GLD5860LSS Stainless Still Built-in Dishwasher
Our dishwasher has developed a growling sound while in the wash cycle. Does not seem to effect the quality of the wash. Where should I start looking
    President:
  • 635 Answers
Sounds like a spray head has loosened up. Check both for wiggle and adjust any plastic nuts you see a bit tighter. Also sometimes that growl comes from a worn water pump bearing.
Posted on Mar 07, 2010
Lg ldf7932ss growling noise at wash cycle
The LG is known for the main motor bearings (2 small cheap) bearings that are of poor quality and become noisy (growls) after a period of time. I pulled the motor and replaced the Korean bearings with quality German equivalents. This is cheap and solves the problem. (the front bearing closest to the plastic pump is the culprit.
Mar 15, 2013 | LG LDF7932ST Builtin Dishwasher
Ffbd2407lm frigidaire dishwasher stops washing cycle?
Sounds like you need a professional to diagnose the unit for repairs. You are either having a timer issue or a control board communication error.
Aug 24, 2012 | Frigidaire Dishwashers
Why dishwasher started making growling sound all of a sudden?
Possibly something stuck/jammed in the wash or drainpropeller, remove filter mesh at the bottom of the dishwasher. Remove any debris jammed near the propeller caution there may be glassor debris near or where the water drains-out.Removeand clean the spray arms, they may have food debris jammed, rinse in hotrunning waterMaintainerWash Runa wash with a tablespoon of powder, without any dishes on the hottest settinge.g. intensive, 65C, if you have a 70C this will be more effective.Loaddishes and re-check
Apr 09, 2012 | Maytag Dishwashers
Why does my dishwasher make a growling sound when it is washing?
The bearings that the tub spins on might be going bad on a machine that old.
Jan 15, 2012 | Dishwashers
Cloudy looking dishes?
Check water quality. If more of calcium or hardness is present, this situation could occur. As per manufacturers directions fill salt meant for dish washers, in the dispenser provide in the door( Inside). This will improve the quality of the water.
Fill rinse aid liquid as per the directions. Refer user manual.
May 25, 2010 | Kenmore 15922 Built-in Dishwasher
I am using the same quality products to wash the dishes as I have done in the past when I used this machine effectively but now--it doesn't seem to clean the dishes and leaves a film and food residue. My...
Dishwashers have a part usually called a separator or accumulator which traps the dirt from the water during the wash cycles while the water is continuously recycled to clean the dishes. At the end of the cycle the separator is flushed out and the trapped dirt goes down the drain. If it doesn't get flushed out the dirt builds up till it starts showing up on the dishes. Some separators have a hole on top and one on bottom with a valve which stops up one hole or the other depending which cycle it's running. The valve can be stuck or broken causing the problem.
See part 1 on this parts list and diagram. http://www.partselect.com/MultiModels.aspx?ModelNum=kuds03ft&searchTerm=img_6G53WSWK&RefineSearch=0&imgMfg=Whirlpool
May 17, 2010 | KitchenAid Architect? II S SERIES KUDS03FT...
Dish washer 3 1/2 yrs old making a growling/vibrating sound.
The problem is hard water. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info.
Jan 28, 2010 | GE 24 in. Profile PDW9880JSS Built-in...
Buzzing Sound at Base of Unit does not go away
If everything is working as it should - the problem may be with the motor.
Either the starter is starting to fail, or it may have gotten wet. Check for leaks around the base, and be prepared to eventually replace the motor.
If you can deal with the humming, there is no reason to replace it at this time, and there is nothing you can do to quiet the noise.
Thanks for using FixYa!
Nov 02, 2009 | KitchenAid 24 in. KUDI02IR Built-in...
LG Dishwasher LDF7811 Making Growling Noise
Recommendations:
-Switch to a brand name detergent powder - like Electrosol or Cascade and do not fill the dispenser cup full. You will notice the difference immediately.
-Remove the filter assembly one more time and inspect underneath with a flashlight. Look closely for debris and also inspect the impeller to look for damage and that it is spinning freely.
Reassemble and listen for the growling sound. It should not happen. If it continues, you may have a a failing wash motor / motor bearing.
Please report back what you find. OK?
Apr 11, 2009 | LG 24 in. LDF 7811 Built-in Dishwasher
Makes growling noise during the wash cycle. some vibration. unit is 6 or 7 years old. it is a maytag jet II EQ. cannot locate the model number as it is a built in unit. would appreciate any help. thank you
Hi Spacepaint, No manufacturer hides the model/serial number behind the enclosure. Look closely on the side of the door panel edge and on the inside edge of the door jam. You will find the model number there.
Growling that happens on every cycle normaly indicates either debris in the sump area / filter or a failing pump motor. Remove screws and inspect the well area for debris.
Recommend a service call if problem is not resolved by the cleaning.
Mar 29, 2009 | Maytag MDB9600A Jetclean II Built-in...
GE 24 in. GLD5860LSS Stainless Still Built-in Dishwasher Logo
350 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
